查看: 2869|回复: 0
imx6ull下2.4寸TFT以及触摸驱动设置
89
89
2016-11-22
61 小时
发表于 2024-7-30 11:07:06 | 显示全部楼层 |阅读模式
分享6ull下的TFT2.4寸小屏显示的相关驱动及设置,屏幕启动ILI9341,触摸驱动XPT2046,
显示驱动和触摸驱动使用同一个SPI口,还外接一个AHT21温湿度传感器
QT界面显示温湿度以及RTC时间,一个按钮控制板子上的红色指示灯
1、dts的相关设置
&ecspi1{
       fsl,spi-num-chipselects= <2>;
       cs-gpios= <&gpio4 26 0
                            &gpio423 0>;
    pinctrl-names = "default";
    pinctrl-0 =<&pinctrl_ecspi1>;
    status = "okay";
      ili9341@0{
                 compatible =  "ilitek,ili9341";
                 reg = <0>;
                 dc-gpios = <&gpio4 22 GPIO_ACTIVE_HIGH>;
                 reset-gpios = <&gpio4 21 GPIO_ACTIVE_HIGH>;
                 spi-max-frequency = <32000000>;
                 rotation = <270>;
                 bgr;
                     fps= <30>;
                 buswidth= <8>;
                     debug= <0>;
              xpt2046@1{
                 compatible =  "ti,tsc2046";
                 reg = <1>;
                     pinctrl-0= <&pinctrl_tsc>;
                     interrupt-parent= <&gpio1>;
                     interrupts= <9 0>;
                     interrupt-gpios= <&gpio1 9 GPIO_ACTIVE_LOW>;
                     spi-max-frequency= <1000000>;
                     pendown-gpio= <&gpio1 9 0>;
                     vcc-supply= <&#174;_can_3v3>;
                     ti,x-min= /bits/ 16 <0>;
                     ti,x-max= /bits/ 16 <240>;
                     ti,y-min= /bits/ 16 <0>;
                     ti,y-max= /bits/ 16 <320>;
                     //ti,x-plate-ohms= /bits/ 16 <0>;
                     //ti,pressure-max= /bits/ 16 <255>;
                     linux,wakeup;
              pinctrl_ecspi1:ecspi1
                    fsl,pins = <
                MX6UL_PAD_CSI_DATA04__ECSPI1_SCLK        0x000010B1
                MX6UL_PAD_CSI_DATA05__GPIO4_IO26         0x000010B0
                             MX6UL_PAD_CSI_DATA02__GPIO4_IO23         0x000010B0
                MX6UL_PAD_CSI_DATA06__ECSPI1_MOSI        0x000010B1
                MX6UL_PAD_CSI_DATA07__ECSPI1_MISO        0x000010B1
比如CSI也使用了上面的引脚需要屏蔽掉,还有gpio的一些重复引脚需要屏蔽,这里不在贴出来,
具体信息看附件
分享6ull下的TFT4.zip
6.82 MB, 下载次数: 32
GMT+8, 2026-10-31 02:47
