查看: 3571|回复: 2
Linux环境中如何为lvgl工程添加用户文件?
115
115
2023-6-8
31 小时
发表于 2024-9-17 15:20:03 | 显示全部楼层 |阅读模式
2金钱
例如我现在有一个LVGL V8.2的工程,已经移植完毕。可以编译并在板子上跑出官方历程。但是怎么给项目添加自己的文件呢?毕竟不能再mian.c中直接写上几百行程序代码吧。加入我在工程文件夹下新建了一个ui的文件夹,向其中添加了一个userUI.c userUI.h文件。如何在工程的main.c中引用这个文件?
我尝试直接添加之后,由于Makefile没有修改,所以无法编译通过。所以问题在于如何修改makefile让程序通过编译.
89
89
2016-11-22
61 小时
发表于 2024-9-25 10:32:07 | 显示全部楼层
这是我的makefile,可以参考一下
# Makefile
CC = arm-linux-gnueabihf-gcc
LVGL_DIR_NAME ?= lvgl
LVGL_DIR ?= .#${shell pwd}
BUILD_DIR := ./build
CFLAGS ?= -O3 -g0 -I$(LVGL_DIR)/ -I /home/wangsuwei/linux/tool/tslib/include/ -I /home/wangsuwei/linux/tool/mjpeg/include#-Wall -Wshadow -Wundef -Wmissing-prototypes -Wno-discarded-qualifiers -Wall -Wextra -Wno-unused-function -Wno-error=strict-prototypes -Wpointer-arith -fno-strict-aliasing -Wno-error=cpp -Wuninitialized -Wmaybe-uninitialized -Wno-unused-parameter -Wno-missing-field-initializers -Wtype-limits -Wsizeof-pointer-memaccess -Wno-format-nonliteral -Wno-cast-qual -Wunreachable-code -Wno-switch-default -Wreturn-type -Wmultichar -Wformat-security -Wno-ignored-qualifiers -Wno-error=pedantic -Wno-sign-compare -Wno-error=missing-prototypes -Wdouble-promotion -Wclobbered -Wdeprecated -Wempty-body -Wtype-limits -Wshift-negative-value -Wstack-usage=2048 -Wno-unused-value -Wno-unused-parameter -Wno-missing-field-initializers -Wuninitialized -Wmaybe-uninitialized -Wall -Wextra -Wno-unused-parameter -Wno-missing-field-initializers -Wtype-limits -Wsizeof-pointer-memaccess -Wno-format-nonliteral -Wpointer-arith -Wno-cast-qual -Wmissing-prototypes -Wunreachable-code -Wno-switch-default -Wreturn-type -Wmultichar -Wno-discarded-qualifiers -Wformat-security -Wno-ignored-qualifiers -Wno-sign-compare
LDFLAGS ?= -lpthread -ljpeg -lm -lts -L /home/wangsuwei/linux/tool/tslib/lib/ -L /home/wangsuwei/linux/tool/mjpeg/lib/
BIN = demo
#Collect the files to compile
MAINSRC = ./main.c
include $(LVGL_DIR)/lvgl/lvgl.mk
include $(LVGL_DIR)/lv_drivers/lv_drivers.mk
VPATH += (LVGL_DIR)/ui
VPATH += (LVGL_DIR)/ui/images
VPATH += (LVGL_DIR)/ui/fonts
VPATH += (LVGL_DIR)/app
CFLAGS += -I$(CURDIR)/ui
CFLAGS += -I$(CURDIR)/ui/images
CFLAGS += -I$(CURDIR)/ui/fonts
CFLAGS += -I$(CURDIR)/app
UI_CSRCS += $(wildcard ui/*.c)
UI_CSRCS += $(wildcard ui/images/*.c)
UI_CSRCS += $(wildcard ui/fonts/*.c)
UI_CSRCS += $(wildcard app/*.c)
CSRCS += $(UI_CSRCS)
UI_OBJS := $(UI_CSRCS:.c=.o)
OBJS += $(UI_OBJS)
#CSRCS +=$(LVGL_DIR)/mouse_cursor_icon.c
OBJEXT ?= .o
AOBJS = $(ASRCS:.S=$(OBJEXT))
COBJS = $(CSRCS:.c=$(OBJEXT))
MAINOBJ = $(MAINSRC:.c=$(OBJEXT))
SRCS = $(ASRCS) $(CSRCS) $(MAINSRC)
OBJS = $(AOBJS) $(COBJS)
## MAINOBJ -> OBJFILES
all: default
%.o: %.c
        @$(CC)  $(CFLAGS) -c $< -std=c99 -o $@
        @echo "CC $<"
$(BUILD_DIR):
        mkdir -p $@
default: $(AOBJS) $(COBJS) $(MAINOBJ)
        $(CC) -o $(BIN) $(MAINOBJ) $(AOBJS) $(COBJS) $(LDFLAGS)
clean:
        rm -f $(BIN) $(AOBJS) $(COBJS) $(MAINOBJ)
115
115
2023-6-8
31 小时
 楼主| 发表于 2024-11-23 08:37:40 | 显示全部楼层
592924270 发表于 2024-9-25 10:32
这是我的makefile,可以参考一下
# Makefile
谢谢你的回复,我参考一下。
GMT+8, 2026-10-31 03:19
