查看: 20528|回复: 2
rk3568编译buildroot时报错,怎么解决啊,ubuntu版本是22.04
2024-9-24
发表于 2024-10-12 17:31:42 | 显示全部楼层 |阅读模式
2024-10-12T17:26:26 >>> host-perl 5.26.1 Building
2024-10-12T17:26:26 PATH="/home/zkb/linux/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/bin:/home/zkb/linux/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/sbin:/home/zkb/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/home/zkb/tools/platform-tools" PKG_CONFIG="/home/zkb/linux/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/bin/pkg-config" PKG_CONFIG_SYSROOT_DIR="/" PKG_CONFIG_ALLOW_SYSTEM_CFLAGS=1 PKG_CONFIG_ALLOW_SYSTEM_LIBS=1 PKG_CONFIG_LIBDIR="/home/zkb/linux/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/lib/pkgconfig:/home/zkb/linux/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/share/pkgconfig" /usr/bin/make -j7 -C /home/zkb/linux/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/host-perl-5.26.1
2024-10-12T17:26:26 makefile:257: warning: ignoring prerequisites on suffix rule definition
2024-10-12T17:26:26 makefile:253: warning: ignoring prerequisites on suffix rule definition
2024-10-12T17:26:26 /usr/bin/gcc -fstack-protector-strong -L/usr/local/lib -o miniperl     opmini.o perlmini.o  gv.o toke.o perly.o pad.o regcomp.o dump.o util.o mg.o reentr.o mro_core.o keywords.o hv.o av.o run.o pp_hot.o sv.o pp.o scope.o pp_ctl.o pp_sys.o doop.o doio.o regexec.o utf8.o taint.o deb.o universal.o globals.o perlio.o perlapi.o numeric.o mathoms.o locale.o pp_pack.o pp_sort.o caretx.o dquote.o time64.o  miniperlmain.o  -lpthread -lnsl -ldl -lm -lcrypt -lutil -lc
2024-10-12T17:26:26 ./miniperl -w -Ilib -Idist/Exporter/lib -MExporter -e '<?>' || sh -c 'echo >&2 Failed to build miniperl.  Please run make minitest; exit 1'
2024-10-12T17:26:26 Attempt to free unreferenced scalar: SV 0x5e15c08db388.
2024-10-12T17:26:26 Segmentation fault (core dumped)
2024-10-12T17:26:26 Failed to build miniperl. Please run make minitest
2024-10-12T17:26:26 make[2]: *** [makefile:364: lib/buildcustomize.pl] Error 1
2024-10-12T17:26:26 make[1]: *** [package/pkg-generic.mk:231: /home/zkb/linux/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/host-perl-5.26.1/.stamp_built] Error 2
2024-10-12T17:26:26 make: *** [/home/zkb/linux/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/Makefile:16: _all] Error 2
Command exited with non-zero status 1
you take 0:06.10 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 717:
    /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
2024-6-30
发表于 2024-11-17 15:42:48 | 显示全部楼层
内存不足
2019-7-26
发表于 2025-2-24 22:28:49 | 显示全部楼层
processing option: rootfs
==========Start building buildroot==========
TARGET_BUILDROOT_CONFIG=rockchip_rk3566
Top of tree: /home/lckfb
#TARGET_BOARD=rk3566
#OUTPUT_DIR=output/rockchip_rk3566
#CONFIG=rockchip_rk3566_defconfig
make: Entering directory '/home/lckfb/buildroot'
  GEN     /home/lckfb/buildroot/output/rockchip_rk3566/Makefile
/home/lckfb/buildroot/build/defconfig_hook.py -m /home/lckfb/buildroot/configs/rockchip_rk3566_defconfig /home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig
BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/home/lckfb/buildroot/output/rockchip_rk3566/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/lckfb/buildroot/output/rockchip_rk3566/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/lckfb/buildroot/output/rockchip_rk3566/build/buildroot-config/tristate.config BR2_CONFIG=/home/lckfb/buildroot/output/rockchip_rk3566/.config HOST_GCC_VERSION="7" BUILD_DIR=/home/lckfb/buildroot/output/rockchip_rk3566/build SKIP_LEGACY= BR2_DEFCONFIG=/home/lckfb/buildroot/configs/rockchip_rk3566_defconfig /home/lckfb/buildroot/output/rockchip_rk3566/build/buildroot-config/conf --defconfig=/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig Config.in
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:256:warning: override: reassigning to symbol BR2_PACKAGE_ROCKCHIP_MPP
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:257:warning: override: reassigning to symbol BR2_PACKAGE_ROCKCHIP_MPP_ALLOCATOR_DRM
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:259:warning: override: reassigning to symbol BR2_PACKAGE_ROCKCHIP_RGA
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:284:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTP
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:285:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTPMANAGER
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:286:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTSP
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:292:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_VIDEORATE
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:293:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_VORBIS
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:294:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_OGG
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:297:warning: override: reassigning to symbol BR2_PACKAGE_BLUEZ5_UTILS
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:316:warning: override: reassigning to symbol BR2_PACKAGE_ROCKCHIP_TEST
/home/lckfb/buildroot/output/rockchip_rk3566/.rockchipconfig:319:warning: override: reassigning to symbol BR2_PACKAGE_RKWIFIBT
# configuration written to /home/lckfb/buildroot/output/rockchip_rk3566/.config
make: Leaving directory '/home/lckfb/buildroot'
2025-02-24T14:21:04 >>> host-libopenssl 1.1.1m Installing to host directory
Done in 8s  (error code: 2)
log saved on /home/lckfb/br.log
2025-02-24T14:21:05 install ./include/openssl/evperr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/evperr.h
2025-02-24T14:21:05 install ./include/openssl/hmac.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/hmac.h
2025-02-24T14:21:05 install ./include/openssl/idea.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/idea.h
2025-02-24T14:21:05 install ./include/openssl/kdf.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/kdf.h
2025-02-24T14:21:05 install ./include/openssl/kdferr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/kdferr.h
2025-02-24T14:21:05 install ./include/openssl/lhash.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/lhash.h
2025-02-24T14:21:05 install ./include/openssl/md2.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/md2.h
2025-02-24T14:21:05 install ./include/openssl/md4.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/md4.h
2025-02-24T14:21:05 install ./include/openssl/md5.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/md5.h
2025-02-24T14:21:05 install ./include/openssl/mdc2.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/mdc2.h
2025-02-24T14:21:05 install ./include/openssl/modes.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/modes.h
2025-02-24T14:21:05 install ./include/openssl/obj_mac.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/obj_mac.h
2025-02-24T14:21:05 install ./include/openssl/objects.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/objects.h
2025-02-24T14:21:05 install ./include/openssl/objectserr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/objectserr.h
2025-02-24T14:21:05 install ./include/openssl/ocsp.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ocsp.h
2025-02-24T14:21:05 install ./include/openssl/ocsperr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ocsperr.h
2025-02-24T14:21:05 install ./include/openssl/opensslconf.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/opensslconf.h
2025-02-24T14:21:05 install ./include/openssl/opensslv.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/opensslv.h
2025-02-24T14:21:05 install ./include/openssl/ossl_typ.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ossl_typ.h
2025-02-24T14:21:05 install ./include/openssl/pem.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/pem.h
2025-02-24T14:21:05 install ./include/openssl/pem2.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/pem2.h
2025-02-24T14:21:05 install ./include/openssl/pemerr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/pemerr.h
2025-02-24T14:21:05 install ./include/openssl/pkcs12.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/pkcs12.h
2025-02-24T14:21:05 install ./include/openssl/pkcs12err.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/pkcs12err.h
2025-02-24T14:21:05 install ./include/openssl/pkcs7.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/pkcs7.h
2025-02-24T14:21:05 install ./include/openssl/pkcs7err.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/pkcs7err.h
2025-02-24T14:21:05 install ./include/openssl/rand.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/rand.h
2025-02-24T14:21:05 install ./include/openssl/rand_drbg.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/rand_drbg.h
2025-02-24T14:21:05 install ./include/openssl/randerr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/randerr.h
2025-02-24T14:21:05 install ./include/openssl/rc2.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/rc2.h
2025-02-24T14:21:05 install ./include/openssl/rc4.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/rc4.h
2025-02-24T14:21:05 install ./include/openssl/rc5.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/rc5.h
2025-02-24T14:21:05 install ./include/openssl/ripemd.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ripemd.h
2025-02-24T14:21:05 install ./include/openssl/rsa.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/rsa.h
2025-02-24T14:21:05 install ./include/openssl/rsaerr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/rsaerr.h
2025-02-24T14:21:05 install ./include/openssl/safestack.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/safestack.h
2025-02-24T14:21:05 install ./include/openssl/seed.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/seed.h
2025-02-24T14:21:05 install ./include/openssl/sha.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/sha.h
2025-02-24T14:21:05 install ./include/openssl/srp.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/srp.h
2025-02-24T14:21:05 install ./include/openssl/srtp.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/srtp.h
2025-02-24T14:21:05 install ./include/openssl/ssl.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ssl.h
2025-02-24T14:21:05 install ./include/openssl/ssl2.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ssl2.h
2025-02-24T14:21:05 install ./include/openssl/ssl3.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ssl3.h
2025-02-24T14:21:05 install ./include/openssl/sslerr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/sslerr.h
2025-02-24T14:21:05 install ./include/openssl/stack.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/stack.h
2025-02-24T14:21:05 install ./include/openssl/store.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/store.h
2025-02-24T14:21:05 install ./include/openssl/storeerr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/storeerr.h
2025-02-24T14:21:05 install ./include/openssl/symhacks.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/symhacks.h
2025-02-24T14:21:05 install ./include/openssl/tls1.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/tls1.h
2025-02-24T14:21:05 install ./include/openssl/ts.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ts.h
2025-02-24T14:21:05 install ./include/openssl/tserr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/tserr.h
2025-02-24T14:21:05 install ./include/openssl/txt_db.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/txt_db.h
2025-02-24T14:21:05 install ./include/openssl/ui.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/ui.h
2025-02-24T14:21:05 install ./include/openssl/uierr.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/uierr.h
2025-02-24T14:21:05 install ./include/openssl/whrlpool.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/whrlpool.h
2025-02-24T14:21:05 install ./include/openssl/x509.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/x509.h
2025-02-24T14:21:05 install ./include/openssl/x509_vfy.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/x509_vfy.h
2025-02-24T14:21:05 install ./include/openssl/x509err.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/x509err.h
2025-02-24T14:21:05 install ./include/openssl/x509v3.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/x509v3.h
2025-02-24T14:21:05 install ./include/openssl/x509v3err.h -> /home/lckfb/buildroot/output/rockchip_rk3566/host/include/openssl/x509v3err.h
2025-02-24T14:21:05 install libcrypto.a -> /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/libcrypto.a
2025-02-24T14:21:06 install libssl.a -> /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/libssl.a
2025-02-24T14:21:06 link /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/libcrypto.so -> /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/libcrypto.so.1.1
2025-02-24T14:21:06 link /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/libssl.so -> /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/libssl.so.1.1
2025-02-24T14:21:06 install libcrypto.pc -> /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/pkgconfig/libcrypto.pc
2025-02-24T14:21:06 install libssl.pc -> /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/pkgconfig/libssl.pc
2025-02-24T14:21:06 install openssl.pc -> /home/lckfb/buildroot/output/rockchip_rk3566/host/lib64/pkgconfig/openssl.pc
2025-02-24T14:21:06 ***
2025-02-24T14:21:06 *** ERROR: package host-libopenssl installs executables without proper RPATH:
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgfilter
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgexec
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgen
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/xmlcatalog
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/infocmp
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msginit
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/tput
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgattrib
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgcat
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-lto-dump
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msggrep
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgunfmt
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/tic
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msguniq
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgcomm
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/xmlwf
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgcmp
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/clear
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgmerge
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgconv
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/toe
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/msgfmt
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/tabs
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/recode-sr-latin
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/xmllint
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/xgettext
2025-02-24T14:21:06 ***   /home/lckfb/buildroot/output/rockchip_rk3566/host/bin/tset
2025-02-24T14:21:06 package/pkg-generic.mk:238: recipe for target '/home/lckfb/buildroot/output/rockchip_rk3566/build/host-libopenssl-1.1.1m/.stamp_host_installed' failed
2025-02-24T14:21:06 make[1]: *** [/home/lckfb/buildroot/output/rockchip_rk3566/build/host-libopenssl-1.1.1m/.stamp_host_installed] Error 1
2025-02-24T14:21:06 /home/lckfb/buildroot/output/rockchip_rk3566/Makefile:16: recipe for target '_all' failed
2025-02-24T14:21:06 make: *** [_all] Error 2
you take 0:08.46 to build builroot
ERROR: exit code 1 from line 715:
我这个也是吗?怎么看出来的?
GMT+8, 2026-10-30 20:07
