查看: 3037|回复: 3
stm32f407zgt6串口2接收乱码,求助大佬帮忙解决
2023-12-6
发表于 2024-10-27 11:12:17 | 显示全部楼层 |阅读模式
6金钱
void USART2_Init(uint32_t clk, uint32_t baudrate)
        //1.开启GPIOA和USART2的时钟
        RCC->AHB1ENR |= (0x1 << 0);
        RCC->APB1ENR |= (0x1 << 17);
        //2.配置GPIOA的工作模式
        //2.1配置输入/输出模式(PA2-复用推挽输出、PA3-浮空输入)
        GPIOA->MODER &= ~(0x3 << 4);
        GPIOA->MODER |= (0x2 << 4);
        GPIOA->MODER &= ~(0x3 << 6);
        GPIOA->MODER |= (0x2 << 6);
        //2.2配置输出类型(PA2-推挽)
        GPIOA->OTYPER &= ~(0x1 << 2);
        GPIOA->OTYPER &= ~(0x1 << 3);
        //2.3配置输出速度(50MHz)
        GPIOA->OSPEEDR &= ~(0x3 << 4);
        GPIOA->OSPEEDR |= (0x2 << 4);
        GPIOA->OSPEEDR &= ~(0x3 << 6);
        GPIOA->OSPEEDR |= (0x2 << 6);
        //2.4配置复用功能
        GPIOA->AFR[0] &= ~(0xFF << 8);
        GPIOA->AFR[0] |= (0x77 << 8);
        //3.配置USART2
        //3.1配置波特率(9600)
        uint32_t brr = (clk * 1000000 + baudrate / 2) / baudrate;
        USART2->BRR |= brr;
        //3.2选择过采样模式(16倍采样)
        USART2->CR1 &= ~(0x1 << 15);
        //3.3选择字长(1 起始位,8 数据位,n 停止位)
        USART2->CR1 &= ~(0x1 << 12);
        //3.4选择奇偶校验控制(无校验)
        USART2->CR1 &= ~(0x1 << 10);
        //3.5接收中断使能(RXNE)
        USART2->CR1 |= (0x1 << 5);
        //3.6空闲中断使能(IDLE)
        USART2->CR1 |= (0x1 << 4);
        //3.7发射器使能(TE)
        USART2->CR1 |= (0x1 << 3);
        //3.8接收器使能(RE)
        USART2->CR1 |= (0x1 << 2);
        //3.9设置停止位(1位)
        USART2->CR2 &= ~(0x3 << 12);
        //3.10设置NVIC
        NVIC_SetPriority(USART2_IRQn, 6);
        //3.11使能NVIC
        NVIC_EnableIRQ(USART2_IRQn);
        //4.使能USART2
        USART2->CR1 |= (0x1 << 13);
/* 发送一个字节数据 */
void USART2_SendByte(uint8_t byte)
        //1.等待发送寄存器为空
        while((USART2->SR & 0x80) == 0);
        //2.将数据写入DR寄存器
        USART2->DR |= byte;
/* 发送多个字节数据 */
void USART2_SendNByte(uint8_t *buff, uint16_t size)
        //1.循环发送
        for(uint16_t i = 0; i < size; i++)
                //2.等待发送寄存器为空
                //3.将数据写入DR寄存器
                USART2->DR |= buff;
/* 中断服务函数 */
void USART2_IRQHandler(void)
        //1.判断是否为接收中断
        if((USART2->SR & 0x20) == 0x20)
                //2.将数据读入接收缓冲区
                buff[size] = USART2->DR;
                size++;
        //3.判断是否为空闲中断
        else if((USART2->SR & 0x10) == 0x10)
                //4.清楚IDLE中断标志位
                USART2->DR;
                //5.将数据发送到串口显示器
                USART2_SendNByte(buff, size);
                //6.将size清零
                size = 0;
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "buzzer.h"
#include "rs485.h"
/* 全局变量 */
uint8_t buff[100] = {0};
uint16_t size = 0;
/* 主函数入口 */
int main(void)
        /* 中断优先级分组 */
        NVIC_SetPriorityGrouping(4);
        /* 外设初始化 */
        Stm32_Clock_Init(336, 8, 2, 7);
    delay_init(168);
        LED_Init();
        KEY_Init();
        Buzzer_Init();
        USART2_Init(42, 9600);
        printf("串口2测试\n");
                delay_ms(500);
#ifndef __RS485_H
#define __RS485_H
/******************** 头文件引用 ********************/
#include "stm32f4xx.h"
#include "stdio.h"
/******************** 全局变量声明 ******************/
extern uint8_t buff[100];
extern uint16_t size;
/******************** 函数声明 **********************/
/* USART2初始化(RS485) */
void USART2_Init(uint32_t clk, uint32_t baudrate);
/* 发送一个字节数据 */
void USART2_SendByte(uint8_t byte);
/* 发送多个字节数据 */
void USART2_SendNByte(uint8_t *buff, uint16_t size);
/* 重写fputc */
int fputc(int ch, FILE *file);
#endif
已经解决了,原因是发送数据那使用了 |=,应该使用=
2023-12-6
 楼主| 发表于 2024-10-27 11:12:18 | 显示全部楼层
2023-12-6
 楼主| 发表于 2024-10-27 11:17:01 | 显示全部楼层
发送正常,接收乱码
2211
5793
5793
2015-1-10
722 小时
发表于 2024-10-28 11:17:20 | 显示全部楼层
GMT+8, 2026-10-25 07:01
