查看: 18248|回复: 3
STM32F407 ADC采样DMA传送数据到外部SRAM
41
41
2019-11-16
14 小时
发表于 2024-11-6 11:47:13 | 显示全部楼层 |阅读模式
1.定义到内部存储器工作正常,ADC采样的数据可以在内存中看到
2.定义到外部存储器,只有第一个SRAM数据变化一次,数值还不对
3.在main主程序里读写外部SRAM工作正常
4.外部SRAM读写速度18M,ADC采样速度2.4M,应该不是这个问题吧?
哪位大侠能指点迷津一下
extern u16 adc_buf[48000];
//extern u16 adc_buf[48000]__attribute__((at(0X68000000)));
void  Adc_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
        ADC_CommonInitTypeDef ADC_CommonInitStructure;
        ADC_InitTypeDef       ADC_InitStructure;
        DMA_InitTypeDef              DMA_Initfjh;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_DMA2, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1|RCC_APB2Periph_ADC2, ENABLE); //
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;        //
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;//
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;//­
        GPIO_Init(GPIOB, &GPIO_InitStructure);//
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;        //
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,ENABLE);          //               RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,DISABLE);        //
        DMA_Initfjh.DMA_Channel = DMA_Channel_0;
        DMA_Initfjh.DMA_PeripheralBaseAddr =  ADC_CDR_ADDR; //
        DMA_Initfjh.DMA_Memory0BaseAddr = (u32)adc_buf;  //
        DMA_Initfjh.DMA_DIR = DMA_DIR_PeripheralToMemory;
        DMA_Initfjh.DMA_BufferSize = 48000;  //
        DMA_Initfjh.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //
        DMA_Initfjh.DMA_MemoryInc = DMA_MemoryInc_Enable; //
        DMA_Initfjh.DMA_PeripheralDataSize  = DMA_PeripheralDataSize_HalfWord;//
        DMA_Initfjh.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //
        DMA_Initfjh.DMA_Mode = DMA_Mode_Circular;        //
        DMA_Initfjh.DMA_Priority = DMA_Priority_High;//
        DMA_Initfjh.DMA_FIFOMode = DMA_FIFOMode_Enable;//Disable; //
        DMA_Initfjh.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;//
        DMA_Initfjh.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        DMA_Initfjh.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
        DMA_Init(DMA2_Stream0, &DMA_Initfjh);
        DMA_Cmd(DMA2_Stream0, ENABLE);
        ADC_CommonInitStructure.ADC_Mode = ADC_DualMode_RegSimult;//
        ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;//
        ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1; //
        ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;//
        ADC_CommonInit(&ADC_CommonInitStructure);//
        ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;//
        ADC_InitStructure.ADC_ScanConvMode =DISABLE;//
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//
        ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;//
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;//
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//
        ADC_InitStructure.ADC_NbrOfConversion = 1;//
        ADC_Init(ADC1, &ADC_InitStructure);//
        ADC_Init(ADC2, &ADC_InitStructure);//
        ADC_RegularChannelConfig(ADC1,ADC_Channel_8,1,ADC_SampleTime_3Cycles);
        ADC_RegularChannelConfig(ADC2,ADC_Channel_9,1,ADC_SampleTime_3Cycles);
        ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
        //ADC_DMARequestAfterLastTransferCmd(ADC1,ENABLE); //
        //ADC_DMACmd(ADC1, ENABLE);//
        ADC_Cmd(ADC1, ENABLE);//
        ADC_Cmd(ADC2, ENABLE);//
        ADC_SoftwareStartConv(ADC1);//
        ADC_SoftwareStartConv(ADC2);//
41
41
2019-11-16
14 小时
 楼主| 发表于 2024-11-6 11:53:04 | 显示全部楼层
求大神解答
99
483
483
2023-5-29
151 小时
发表于 2024-11-25 09:38:11 | 显示全部楼层
首先ADC初始化配置,你初始化了2个通道,ADC_NbrOfConversion 这里配置只有1个通道, ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);使用的是双重ADC模式,DMA的fifo模式关掉,用不到,DMA外设地址应该是ADC的CDR寄存器,内存地址,看你使用的buf是内部的ram的内存,你把外部内存那个屏蔽了,直接定义外部SRAM作为地址的话不知道可行不,没实操过,使用过的是DMA传内部然后再内部ram把数据写进外部SRAM,没问题
99
483
483
2023-5-29
151 小时
发表于 2024-11-25 09:44:04 | 显示全部楼层
ADC使用双重模式的话,DMA要用模式2,你的代码使用的是1 ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1; 模式1用于三重规则同步
GMT+8, 2026-10-31 10:50
