查看: 1753|回复: 0
rk3568 linux5.10 buildroot fail
2024-5-25
发表于 2024-11-25 22:41:44 | 显示全部楼层 |阅读模式
>>> host-attr 2.5.1 Building
PATH="/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/host/bin:/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin" PKG_CONFIG="/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/host/bin/pkg-config" PKG_CONFIG_SYSROOT_DIR="/" PKG_CONFIG_ALLOW_SYSTEM_CFLAGS=1 PKG_CONFIG_ALLOW_SYSTEM_LIBS=1 PKG_CONFIG_LIBDIR="/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/host/lib/pkgconfig:/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/host/share/pkgconfig"  /usr/bin/make -j3  -C /home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/host-attr-2.5.1/
make[1]: Entering directory '/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/host-attr-2.5.1'
Making all in po
make[2]: Entering directory '/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/host-attr-2.5.1/po'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory '/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/host-attr-2.5.1/po'
make[2]: Entering directory '/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/host-attr-2.5.1'
  CCLD     libattr.la
  CCLD     libmisc.la
./libtool: eval: line 7963: unexpected EOF while looking for matching `''
./libtool: eval: line 7964: syntax error: unexpected end of file
make[2]: *** [Makefile:917: libmisc.la] Error 2
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [Makefile:898: libattr.la] Error 2
make[2]: Leaving directory '/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/host-attr-2.5.1'
make[1]: *** [Makefile:1229: all-recursive] Error 1
make[1]: Leaving directory '/home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/host-attr-2.5.1'
make: *** [package/pkg-generic.mk:314: /home/wyz/linux/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/host-attr-2.5.1/.stamp_built] Error 2
从error 信息来看是 libtool 有点问题,有谁解决了吗?
GMT+8, 2026-10-31 10:53
