查看: 13085|回复: 9
根据原子旗舰版TFT初始化移植到F407上初始化不成功
23
83
195
195
2012-10-24
发表于 2014-6-12 22:04:38 | 显示全部楼层 |阅读模式
我使用的是NE1,初始化配置如下,
void LCD_Init(void)
 FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
 FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
 FSMC_NORSRAMTimingInitTypeDef  writeTiming;
  RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE); //使能FSMC时钟
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD,ENABLE);
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE,ENABLE);
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF,ENABLE);
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOG,ENABLE);//使能PORTA,B,C,D,E,F,G时钟
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC);                 //FSMC_D0
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC);                 //FSMC_D1
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);                  //FSMC_D2
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);                  //FSMC_D3
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);                  //FSMC_D4
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC);                  //FSMC_D5
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC);                  //FSMC_D6
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC);                 //FSMC_D7
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC);                 //FSMC_D8
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC);                 //FSMC_D9
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC);                 //FSMC_D10
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC);                 //FSMC_D11
 GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC);                 //FSMC_D12
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC);                  //FSMC_D13
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC);                  //FSMC_D14
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC);                 //FSMC_D15
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource7,GPIO_AF_FSMC);                  //FSMC_NE1
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC);                 //FSMC_A18
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC);                  //FSMC_NWE
 GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC);                  //FSMC_NOE
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 |GPIO_Pin_1 |GPIO_Pin_4 |GPIO_Pin_5 |GPIO_Pin_7 |GPIO_Pin_8 |GPIO_Pin_9 |GPIO_Pin_10 |GPIO_Pin_13 |GPIO_Pin_14 | GPIO_Pin_15;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
 GPIO_Init(GPIOD, &GPIO_InitStructure);                  //配置FSMC口
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 |GPIO_Pin_8 |GPIO_Pin_9 |GPIO_Pin_10 |GPIO_Pin_12 |GPIO_Pin_13 |GPIO_Pin_14 | GPIO_Pin_15;
 GPIO_Init(GPIOE, &GPIO_InitStructure);                                  //配置FSMC口
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
   GPIO_Init(GPIOC, &GPIO_InitStructure);                   //LCD_BL口(LCD背光控制)
   readWriteTiming.FSMC_AddressSetupTime = 0x0f;          //地址建立时间(ADDSET)
    readWriteTiming.FSMC_AddressHoldTime = 0x00;          //地址保持时间(ADDHLD)模式A未用到
    readWriteTiming.FSMC_DataSetupTime = 0xff;           //数据保存时间
    readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
    readWriteTiming.FSMC_CLKDivision = 0x00;
    readWriteTiming.FSMC_DataLatency = 0x00;
    readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;  //模式A
   writeTiming.FSMC_AddressSetupTime = 0x0f;              //地址建立时间(ADDSET)
    writeTiming.FSMC_AddressHoldTime = 0x00;              //地址保持时间
    writeTiming.FSMC_DataSetupTime = 0x0f;               //数据保存时间
    writeTiming.FSMC_BusTurnAroundDuration = 0x00;
    writeTiming.FSMC_CLKDivision = 0x00;
    writeTiming.FSMC_DataLatency = 0x00;
    writeTiming.FSMC_AccessMode = FSMC_AccessMode_A;      //模式A
    FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;//  这里我们使用NE1 ,也就对应BTCR[0],[1]。
    FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; // 不复用数据地址
    FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM;  //SRAM
    FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
    FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
   FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
    FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; //  存储器写使能
    FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable; // 使能扩展模式
    FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; //读写时序
    FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &writeTiming;  //写时序
    FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //初始化FSMC配置
    FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);  // 使能BANK1
我LCD_BASE定义如下
#define LCD_BASE        ((u32)(0x60000000 | 0x0007FFFE))
   因为用NE1,所以HADDR[27,26]=00,我用A18作为命令数据区分线
感觉我的初始化配置没什么问题,为了能成功读出DI,我把地址建立时间和数据保持时间都加大了不少,读ID和初始化命令都是移植原子的,发现初始化没成功
   我用jtag跟踪了下,最后LCD_Clear(RED);这个指令执行了,可是屏幕没有变色
23
83
195
195
2012-10-24
 楼主| 发表于 2014-6-12 22:15:25 | 显示全部楼层
我跟踪了下,貌似ID没有读出来
165779
165779
发表于 2014-6-12 23:04:40 | 显示全部楼层
回复【2楼】颓废ю小寶:
论坛有网友发过407驱动我们的LCD模块代码,你搜索参考下.
读ID,把读时间参数都设置到最大试试.
120
7861
12011
12011
2013-9-10
427 小时
发表于 2014-6-13 08:04:38 | 显示全部楼层
#define LCD_BASE        ((u32)(0x60000000 | 0x0007FFFE))这里应该是这样的吧#define LCD_BASE        ((u32)(0x60000000 | 0x0003FFFE))
35
35
2014-6-8
发表于 2014-6-13 10:56:43 | 显示全部楼层
其实你可以不用读id,,根据型号直接配置lcd屏的寄存器。然后发现可以显示图片等等。。
23
83
195
195
2012-10-24
 楼主| 发表于 2014-6-13 19:36:38 | 显示全部楼层
回复【4楼】Badu_Space:
不是说数据宽度16b的话,HADDR[25:1]对应外部存储器地址A[24:0],这时HADDR第0位不用嘛?
23
83
195
195
2012-10-24
 楼主| 发表于 2014-6-13 19:38:34 | 显示全部楼层
回复【5楼】superlink1:
我就是怕FSMC并没有启动成功而导致的读ID错误。我用mini板烧了TFT例程进去,发现复位和断电,都会导致芯片不跑程序(就像不启振了),我试着换第一个流水灯的例程也是如此,所以我不清楚TFT的ID是什么
165779
165779
发表于 2014-6-13 22:56:12 | 显示全部楼层
回复【7楼】颓废ю小寶:
你下载我们mini板例程,然后按复位,串口就会输出一次LCD ID的.
23
83
195
195
2012-10-24
 楼主| 发表于 2014-6-17 11:59:06 | 显示全部楼层
 回复【8楼】 正点原子 :
原子哥,我已经知道我的ID了,我不用读ID程序,直接运行初始化程序,发现也是不成功。
   我感觉我FSMC配置都没问题,而且命令数据的RS地址位我也右移1位对齐了,我初始化后执行了一个LCD_Clear(BLUE);我按无数次STM32复位键后(这个复位键是和tft屏接到一起的),会有几次出现如下图片情况
根据设置扩展模式A的读写时序中建立地址时间和数据保持时间的不同,蓝色块出现的位置有时会出现在不同的位置。如果把这2个时间设置最大值,则屏幕会变黑屏。由于TFT出现蓝色块,说明了执行了LCD_Clear(BLUE)清屏部分成功了,既然清屏部分成功了,从而我确定我的FSMC的配置应该没问题的。我估计问题是不是在于设置读写时序中 建立地址时间和数据保存时间 上的问题。现在我把FSMC对应GPIO口的AF设置语句位置调整了下,现在又出现了如下图片情况,我复位了很多次,都没出现上面图片的蓝色块
这个不是LCD_BL的白色背光,而是闪烁很快的暗白色。
     求教下原子哥,看看我有什么地方遗漏的。我搞了1个星期来了,都没头绪
165779
165779
发表于 2014-6-17 23:18:32 | 显示全部楼层
回复【9楼】颓废ю小寶:
把写时序搞慢点试试.
GMT+8, 2026-10-24 22:42
