查看: 6804|回复: 0
rk3568 5.10 SDK编译失败问题
39
39
2021-11-18
发表于 2025-5-7 10:06:54 | 显示全部楼层 |阅读模式
请教原子哥, 5.10 sdk编译时报错,http://sources.buildroot.net/qt5 ... d6b7e6b83cb.tar.bz2, 这个包下载失败, 请问要怎么搞
2025-05-06T17:26:52 usr/qml/QtOpcUa/qmldir
2025-05-06T17:26:52
2025-05-06T17:26:52 sent 3,530,487 bytes  received 2,829 bytes  7,066,632.00 bytes/sec
2025-05-06T17:26:52 total size is 3,519,061  speedup is 1.00
2025-05-06T17:26:52 >>> qt5quick3d 1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb Downloading
2025-05-06T17:26:52 wget --passive-ftp -nd -t 3 --no-check-certificate -O '/home/alientek/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/.qtquick3d-1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb.tar.bz2.iRBgHe/output' 'http://sources.buildroot.net/qt5quick3d/qtquick3d-1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb.tar.bz2'
2025-05-06T17:26:52 --2025-05-06 17:26:52--  http://sources.buildroot.net/qt5 ... d6b7e6b83cb.tar.bz2
2025-05-06T17:26:53 Resolving sources.buildroot.net (sources.buildroot.net)... 172.67.72.56, 104.26.0.37, 104.26.1.37, ...
2025-05-06T17:26:53 Connecting to sources.buildroot.net (sources.buildroot.net)|172.67.72.56|:80... connected.
2025-05-06T17:26:53 HTTP request sent, awaiting response... 404 Not Found
2025-05-06T17:26:53 2025-05-06 17:26:53 ERROR 404: Not Found.
2025-05-06T17:26:53
2025-05-06T17:26:53 wget --passive-ftp -nd -t 3 --no-check-certificate -O '/home/alientek/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/.qtquick3d-1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb.tar.bz2.5zB54V/output' 'http://sources.buildroot.net/qtquick3d-1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb.tar.bz2'
2025-05-06T17:26:54 --2025-05-06 17:26:54--  http://sources.buildroot.net/qtq ... d6b7e6b83cb.tar.bz2
2025-05-06T17:26:54 Resolving sources.buildroot.net (sources.buildroot.net)... 104.26.1.37, 104.26.0.37, 172.67.72.56, ...
2025-05-06T17:26:54 Connecting to sources.buildroot.net (sources.buildroot.net)|104.26.1.37|:80... connected.
2025-05-06T17:26:54 HTTP request sent, awaiting response... 404 Not Found
2025-05-06T17:26:54 2025-05-06 17:26:54 ERROR 404: Not Found.
2025-05-06T17:26:54
2025-05-06T17:26:54 wget --passive-ftp -nd -t 3 --no-check-certificate -O '/home/alientek/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/.qtquick3d-1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb.tar.bz2.I5DGf4/output' 'https://invent.kde.org/qt/qt/qtquick3d/-/archive/1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb/qtquick3d-1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb.tar.bz2'
2025-05-06T17:26:54 --2025-05-06 17:26:54--  https://invent.kde.org/qt/qt/qtq ... d6b7e6b83cb.tar.bz2
2025-05-06T17:26:54 Resolving invent.kde.org (invent.kde.org)... 188.40.133.145, 2a01:4f8:221:1dd0::2
2025-05-06T17:26:56 Connecting to invent.kde.org (invent.kde.org)|188.40.133.145|:443... connected.
2025-05-06T17:26:56 Unable to establish SSL connection.
2025-05-06T17:26:56 make[1]: *** [package/pkg-generic.mk:207: /home/alientek/rk3568_linux5.10_sdk/buildroot/output/rockchip_atk_dlrk3568/build/qt5quick3d-1d1420cd7e49dd588b8986952c0bcd6b7e6b83cb/.stamp_downloaded] Error 1
2025-05-06T17:26:56 make: *** [Makefile:110: _all] Error 2
2025-05-06T17:26:56 make: Leaving directory '/home/alientek/rk3568_linux5.10_sdk/buildroot'
请问这个问题怎么解决, 哪位大神知道
GMT+8, 2026-10-30 20:07
