查看: 2490|回复: 0
下面程序DAC通道二怎么不能输出波形
2025-5-3
发表于 2025-5-11 15:59:15 | 显示全部楼层 |阅读模式
#include "./BSP/DAC/dac.h"
extern uint16_t g_dac_sin_buf[4096];
DAC_HandleTypeDef g_dac_dma_handle;
DMA_HandleTypeDef g_dma1_dac_handle;
void dac1_dma_wave_init(void)
          DAC_ChannelConfTypeDef dac_ch_conf;
          __HAL_RCC_DMA1_CLK_ENABLE();
          g_dma1_dac_handle.Instance = DMA1_Stream6;
    g_dma1_dac_handle.Init.Channel = DMA_CHANNEL_7;
    g_dma1_dac_handle.Init.Direction = DMA_MEMORY_TO_PERIPH;
    g_dma1_dac_handle.Init.PeriphInc = DMA_PINC_DISABLE;
    g_dma1_dac_handle.Init.MemInc = DMA_MINC_ENABLE;
    g_dma1_dac_handle.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
    g_dma1_dac_handle.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
    g_dma1_dac_handle.Init.Mode = DMA_CIRCULAR;
    g_dma1_dac_handle.Init.Priority = DMA_PRIORITY_MEDIUM;
    g_dma1_dac_handle.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
          HAL_DMA_Init(&g_dma1_dac_handle);
          __HAL_LINKDMA(&g_dac_dma_handle, DMA_Handle1, g_dma1_dac_handle);
    g_dac_dma_handle.Instance = DAC;
    HAL_DAC_Init(&g_dac_dma_handle);
         dac_ch_conf.DAC_Trigger=DAC_TRIGGER_T6_TRGO  ;
         dac_ch_conf.DAC_OutputBuffer=DAC_OUTPUTBUFFER_DISABLE;
         HAL_DAC_ConfigChannel(&g_dac_dma_handle,&dac_ch_conf,DAC_CHANNEL_2);
         HAL_DMA_Start_IT(&g_dma1_dac_handle,(uint32_t)g_dac_sin_buf,(uint32_t)&DAC->DHR12RD,0);
void HAL_DAC_MspInit(DAC_HandleTypeDef *hdac)
        if(hdac->Instance==DAC)
                GPIO_InitTypeDef gpio_init_struct;
          __HAL_RCC_SPI1_CLK_DISABLE();
          __HAL_RCC_GPIOA_CLK_ENABLE();
                        __HAL_RCC_TIM2_CLK_DISABLE() ;
                __HAL_RCC_TIM6_CLK_ENABLE() ;
                __HAL_RCC_DAC_CLK_ENABLE();
          gpio_init_struct.Pin =GPIO_PIN_5;
          gpio_init_struct.Mode = GPIO_MODE_ANALOG;
                gpio_init_struct.Pull=GPIO_NOPULL;
          HAL_GPIO_Init(GPIOA, &gpio_init_struct);
void dac1_dma_wave_enable( uint16_t ndtr1, uint16_t arr1, uint16_t psc1)
        TIM_MasterConfigTypeDef master_config={0};
        TIM_HandleTypeDef g_timx_chy_handle={0};
        g_timx_chy_handle.Instance = TIM6;
        g_timx_chy_handle.Init.Prescaler=psc1;
        g_timx_chy_handle.Init.Period=arr1;
        g_timx_chy_handle.Init.CounterMode=TIM_COUNTERMODE_UP;
        HAL_TIM_Base_Init(&g_timx_chy_handle);
        master_config.MasterOutputTrigger = TIM_TRGO_UPDATE;
  master_config.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  HAL_TIMEx_MasterConfigSynchronization(&g_timx_chy_handle, &master_config);
        HAL_DAC_Stop_DMA(&g_dac_dma_handle,  DAC_CHANNEL_2 );
  HAL_DAC_Start_DMA(&g_dac_dma_handle,  DAC_CHANNEL_2,(uint32_t *)g_dac_sin_buf, ndtr1, DAC_ALIGN_12B_R );
        HAL_TIM_Base_Start_IT(&g_timx_chy_handle);
GMT+8, 2026-10-31 05:36
