查看: 4288|回复: 0
RK3568的SDK编译问题,编译buildroot时产生错误ERROR: Neither directory contains a build file meson.build.
2022-2-23
发表于 2025-6-23 18:31:09 | 显示全部楼层 |阅读模式
./build.sh all也就是全部编译命令后:在编译buildroot这一部分时候产生如下LOG:
LOG尾部最终报了个错误编译终止
求个大神帮忙看看我下一步该怎么处理?
==========Start building buildroot==========
TARGET_BUILDROOT_CONFIG=rockchip_rk3568
Top of tree: /home/ars/rk3568_linux_sdk
#TARGET_BOARD=rk3568
#OUTPUT_DIR=output/rockchip_rk3568
#CONFIG=rockchip_rk3568_defconfig
make: Entering directory '/home/ars/rk3568_linux_sdk/buildroot'
  GEN     /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/Makefile
/home/ars/rk3568_linux_sdk/buildroot/build/defconfig_hook.py -m /home/ars/rk3568_linux_sdk/buildroot/configs/rockchip_rk3568_defconfig /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig
BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/buildroot-config/tristate.config BR2_CONFIG=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.config HOST_GCC_VERSION="9" BUILD_DIR=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build SKIP_LEGACY= BR2_DEFCONFIG=/home/ars/rk3568_linux_sdk/buildroot/configs/rockchip_rk3568_defconfig /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/buildroot-config/conf --defconfig=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig Config.in
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:266:warning: override: reassigning to symbol BR2_PACKAGE_ROCKCHIP_MPP
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:267:warning: override: reassigning to symbol BR2_PACKAGE_ROCKCHIP_MPP_ALLOCATOR_DRM
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:269:warning: override: reassigning to symbol BR2_PACKAGE_ROCKCHIP_RGA
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:295:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTP
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:296:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTPMANAGER
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:297:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_GOOD_PLUGIN_RTSP
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:303:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_VIDEORATE
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:304:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_VORBIS
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:305:warning: override: reassigning to symbol BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_OGG
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:308:warning: override: reassigning to symbol BR2_PACKAGE_BLUEZ5_UTILS
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:327:warning: override: reassigning to symbol BR2_PACKAGE_ROCKCHIP_TEST
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:330:warning: override: reassigning to symbol BR2_PACKAGE_RKWIFIBT
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:401:warning: override: reassigning to symbol BR2_PACKAGE_IPERF3
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:406:warning: override: reassigning to symbol BR2_PACKAGE_IW
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:410:warning: override: reassigning to symbol BR2_PACKAGE_ETHTOOL
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:412:warning: override: reassigning to symbol BR2_PACKAGE_EVTEST
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:414:warning: override: reassigning to symbol BR2_PACKAGE_COREUTILS
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:420:warning: override: reassigning to symbol BR2_PACKAGE_DOSFSTOOLS
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:421:warning: override: reassigning to symbol BR2_PACKAGE_DOSFSTOOLS_MKFS_FAT
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:424:warning: override: reassigning to symbol BR2_PACKAGE_CAN_UTILS
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:425:warning: override: reassigning to symbol BR2_PACKAGE_MMC_UTILS
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:430:warning: override: reassigning to symbol BR2_PACKAGE_LIBDRM_INSTALL_TESTS
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:435:warning: override: reassigning to symbol BR2_PACKAGE_WPA_SUPPLICANT_AUTOSCAN
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:444:warning: override: reassigning to symbol BR2_TARGET_GENERIC_ROOT_PASSWD
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:445:warning: override: reassigning to symbol BR2_TARGET_GENERIC_HOSTNAME
/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.rockchipconfig:519:warning: override: reassigning to symbol BR2_PACKAGE_GDB
# configuration written to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/.config
make: Leaving directory '/home/ars/rk3568_linux_sdk/buildroot'
2025-06-23T18:03:21 >>> host-gettext 0.19.8.1 Building
2025-06-23T18:04:00 >>> host-gettext 0.19.8.1 Installing to host directory
2025-06-23T18:04:17 >>> host-ncurses 6.0 Extracting
2025-06-23T18:04:17 >>> host-ncurses 6.0 Patching
2025-06-23T18:04:17 >>> host-ncurses 6.0 Updating config.sub and config.guess
2025-06-23T18:04:17 >>> host-ncurses 6.0 Patching libtool
2025-06-23T18:04:17 >>> host-ncurses 6.0 Configuring
2025-06-23T18:04:25 >>> host-ncurses 6.0 Building
2025-06-23T18:04:31 >>> host-ncurses 6.0 Installing to host directory
2025-06-23T18:04:45 >>> ncurses 6.0 Extracting
2025-06-23T18:04:45 >>> ncurses 6.0 Patching
2025-06-23T18:04:45 >>> ncurses 6.0 Updating config.sub and config.guess
2025-06-23T18:04:46 >>> ncurses 6.0 Patching libtool
2025-06-23T18:04:46 >>> ncurses 6.0 Configuring
2025-06-23T18:04:52 >>> ncurses 6.0 Building
2025-06-23T18:04:57 >>> ncurses 6.0 Installing to staging directory
2025-06-23T18:04:58 >>> ncurses 6.0 Fixing package configuration files
2025-06-23T18:04:58 >>> ncurses 6.0 Fixing libtool files
2025-06-23T18:04:58 >>> ncurses 6.0 Installing to target
2025-06-23T18:05:00 >>> alsa-utils 1.1.5 Extracting
2025-06-23T18:05:00 >>> alsa-utils 1.1.5 Patching
2025-06-23T18:05:00 >>> alsa-utils 1.1.5 Updating config.sub and config.guess
2025-06-23T18:05:00 >>> alsa-utils 1.1.5 Configuring
2025-06-23T18:05:00 >>> alsa-utils 1.1.5 Gettextizing
2025-06-23T18:05:01 >>> alsa-utils 1.1.5 Autoreconfiguring
2025-06-23T18:05:05 >>> alsa-utils 1.1.5 Patching libtool
2025-06-23T18:05:09 >>> alsa-utils 1.1.5 Building
2025-06-23T18:05:13 >>> alsa-utils 1.1.5 Installing to staging directory
2025-06-23T18:05:14 >>> alsa-utils 1.1.5 Fixing libtool files
2025-06-23T18:05:14 >>> alsa-utils 1.1.5 Installing to target
2025-06-23T18:05:14 >>> expat 2.2.5 Extracting
2025-06-23T18:05:14 >>> expat 2.2.5 Patching
2025-06-23T18:05:14 >>> expat 2.2.5 Updating config.sub and config.guess
2025-06-23T18:05:14 >>> expat 2.2.5 Patching libtool
2025-06-23T18:05:14 >>> expat 2.2.5 Configuring
2025-06-23T18:05:19 >>> expat 2.2.5 Building
2025-06-23T18:05:21 >>> expat 2.2.5 Installing to staging directory
2025-06-23T18:05:21 >>> expat 2.2.5 Fixing libtool files
2025-06-23T18:05:21 >>> expat 2.2.5 Installing to target
2025-06-23T18:05:22 >>> dbus 1.12.2 Extracting
2025-06-23T18:05:22 >>> dbus 1.12.2 Patching
2025-06-23T18:05:22 >>> dbus 1.12.2 Updating config.sub and config.guess
2025-06-23T18:05:22 >>> dbus 1.12.2 Patching libtool
2025-06-23T18:05:22 >>> dbus 1.12.2 Configuring
2025-06-23T18:05:36 >>> dbus 1.12.2 Building
2025-06-23T18:05:43 >>> dbus 1.12.2 Installing to staging directory
2025-06-23T18:05:44 >>> dbus 1.12.2 Fixing libtool files
2025-06-23T18:05:44 >>> dbus 1.12.2 Installing to target
2025-06-23T18:05:44 >>> bzip2 1.0.6 Extracting
2025-06-23T18:05:45 >>> bzip2 1.0.6 Patching
2025-06-23T18:05:45 >>> bzip2 1.0.6 Configuring
2025-06-23T18:05:45 >>> bzip2 1.0.6 Building
2025-06-23T18:05:46 >>> bzip2 1.0.6 Installing to staging directory
2025-06-23T18:05:46 >>> bzip2 1.0.6 Fixing libtool files
2025-06-23T18:05:46 >>> bzip2 1.0.6 Installing to target
2025-06-23T18:05:47 >>> libzlib 1.2.11 Extracting
2025-06-23T18:05:47 >>> libzlib 1.2.11 Patching
2025-06-23T18:05:47 >>> libzlib 1.2.11 Configuring
2025-06-23T18:05:47 >>> libzlib 1.2.11 Building
2025-06-23T18:05:52 >>> libzlib 1.2.11 Installing to staging directory
2025-06-23T18:05:52 >>> libzlib 1.2.11 Fixing libtool files
2025-06-23T18:05:52 >>> libzlib 1.2.11 Installing to target
2025-06-23T18:05:52 >>> zlib  Extracting
2025-06-23T18:05:52 >>> zlib  Patching
2025-06-23T18:05:52 >>> zlib  Configuring
2025-06-23T18:05:52 >>> zlib  Building
2025-06-23T18:05:52 >>> zlib  Installing to target
2025-06-23T18:05:52 >>> libpng 1.6.37 Extracting
2025-06-23T18:05:52 >>> libpng 1.6.37 Patching
2025-06-23T18:05:52 >>> libpng 1.6.37 Updating config.sub and config.guess
2025-06-23T18:05:52 >>> libpng 1.6.37 Patching libtool
2025-06-23T18:05:52 >>> libpng 1.6.37 Configuring
2025-06-23T18:05:55 >>> libpng 1.6.37 Building
2025-06-23T18:05:59 >>> libpng 1.6.37 Installing to staging directory
2025-06-23T18:05:59 >>> libpng 1.6.37 Fixing package configuration files
2025-06-23T18:05:59 >>> libpng 1.6.37 Fixing libtool files
2025-06-23T18:05:59 >>> libpng 1.6.37 Installing to target
2025-06-23T18:05:59 >>> freetype 2.10.1 Extracting
2025-06-23T18:05:59 >>> freetype 2.10.1 Patching
2025-06-23T18:05:59 >>> freetype 2.10.1 Updating config.sub and config.guess
2025-06-23T18:05:59 >>> freetype 2.10.1 Patching libtool
2025-06-23T18:05:59 >>> freetype 2.10.1 Configuring
2025-06-23T18:06:03 >>> freetype 2.10.1 Building
2025-06-23T18:06:08 >>> freetype 2.10.1 Installing to staging directory
2025-06-23T18:06:08 >>> freetype 2.10.1 Fixing package configuration files
2025-06-23T18:06:08 >>> freetype 2.10.1 Fixing libtool files
2025-06-23T18:06:08 >>> freetype 2.10.1 Installing to target
2025-06-23T18:06:08 >>> host-gperf 3.0.4 Extracting
2025-06-23T18:06:08 >>> host-gperf 3.0.4 Patching
2025-06-23T18:06:08 >>> host-gperf 3.0.4 Updating config.sub and config.guess
2025-06-23T18:06:08 >>> host-gperf 3.0.4 Patching libtool
2025-06-23T18:06:09 >>> host-gperf 3.0.4 Configuring
2025-06-23T18:06:12 >>> host-gperf 3.0.4 Building
2025-06-23T18:06:13 >>> host-gperf 3.0.4 Installing to host directory
2025-06-23T18:06:14 >>> util-linux-libs 2.37.2 Extracting
2025-06-23T18:06:14 >>> util-linux-libs 2.37.2 Patching
2025-06-23T18:06:14 >>> util-linux-libs 2.37.2 Updating config.sub and config.guess
2025-06-23T18:06:14 >>> util-linux-libs 2.37.2 Patching libtool
2025-06-23T18:06:14 >>> util-linux-libs 2.37.2 Configuring
2025-06-23T18:06:29 >>> util-linux-libs 2.37.2 Building
2025-06-23T18:06:40 >>> util-linux-libs 2.37.2 Installing to staging directory
2025-06-23T18:06:41 >>> util-linux-libs 2.37.2 Fixing libtool files
2025-06-23T18:06:41 >>> util-linux-libs 2.37.2 Installing to target
2025-06-23T18:06:41 >>> fontconfig 2.13.1 Extracting
2025-06-23T18:06:42 >>> fontconfig 2.13.1 Patching
2025-06-23T18:06:42 >>> fontconfig 2.13.1 Updating config.sub and config.guess
2025-06-23T18:06:42 >>> fontconfig 2.13.1 Configuring
2025-06-23T18:06:42 >>> fontconfig 2.13.1 Autoreconfiguring
2025-06-23T18:06:49 >>> fontconfig 2.13.1 Patching libtool
2025-06-23T18:06:56 >>> fontconfig 2.13.1 Building
2025-06-23T18:07:02 >>> fontconfig 2.13.1 Installing to staging directory
2025-06-23T18:07:03 >>> fontconfig 2.13.1 Fixing libtool files
2025-06-23T18:07:03 >>> fontconfig 2.13.1 Installing to target
2025-06-23T18:07:04 >>> host-expat 2.2.5 Extracting
2025-06-23T18:07:04 >>> host-expat 2.2.5 Patching
2025-06-23T18:07:04 >>> host-expat 2.2.5 Updating config.sub and config.guess
2025-06-23T18:07:04 >>> host-expat 2.2.5 Patching libtool
2025-06-23T18:07:04 >>> host-expat 2.2.5 Configuring
2025-06-23T18:07:08 >>> host-expat 2.2.5 Building
2025-06-23T18:07:11 >>> host-expat 2.2.5 Installing to host directory
2025-06-23T18:07:12 >>> host-libffi 3.2.1 Extracting
2025-06-23T18:07:12 >>> host-libffi 3.2.1 Patching
2025-06-23T18:07:12 >>> host-libffi 3.2.1 Updating config.sub and config.guess
2025-06-23T18:07:12 >>> host-libffi 3.2.1 Configuring
2025-06-23T18:07:12 >>> host-libffi 3.2.1 Autoreconfiguring
2025-06-23T18:07:18 >>> host-libffi 3.2.1 Patching libtool
2025-06-23T18:07:22 >>> host-libffi 3.2.1 Building
2025-06-23T18:07:23 >>> host-libffi 3.2.1 Installing to host directory
2025-06-23T18:07:24 >>> host-libzlib 1.2.11 Extracting
2025-06-23T18:07:24 >>> host-libzlib 1.2.11 Patching
2025-06-23T18:07:24 >>> host-libzlib 1.2.11 Configuring
2025-06-23T18:07:24 >>> host-libzlib 1.2.11 Building
2025-06-23T18:07:29 >>> host-libzlib 1.2.11 Installing to host directory
2025-06-23T18:07:29 >>> host-zlib  Extracting
2025-06-23T18:07:29 >>> host-zlib  Patching
2025-06-23T18:07:29 >>> host-zlib  Configuring
2025-06-23T18:07:29 >>> host-zlib  Building
2025-06-23T18:07:29 >>> host-zlib  Installing to host directory
2025-06-23T18:07:30 >>> host-python3 3.8.6 Extracting
2025-06-23T18:07:31 >>> host-python3 3.8.6 Patching
2025-06-23T18:07:32 >>> host-python3 3.8.6 Updating config.sub and config.guess
2025-06-23T18:07:32 >>> host-python3 3.8.6 Configuring
2025-06-23T18:07:32 >>> host-python3 3.8.6 Autoreconfiguring
2025-06-23T18:07:36 >>> host-python3 3.8.6 Patching libtool
2025-06-23T18:08:00 >>> host-python3 3.8.6 Building
2025-06-23T18:08:30 >>> host-python3 3.8.6 Installing to host directory
2025-06-23T18:08:35 >>> host-ninja v1.8.2 Extracting
2025-06-23T18:08:35 >>> host-ninja v1.8.2 Patching
2025-06-23T18:08:35 >>> host-ninja v1.8.2 Configuring
2025-06-23T18:08:35 >>> host-ninja v1.8.2 Building
2025-06-23T18:08:57 >>> host-ninja v1.8.2 Installing to host directory
2025-06-23T18:08:58 >>> host-python3-setuptools 44.0.0 Extracting
2025-06-23T18:08:58 >>> host-python3-setuptools 44.0.0 Patching
2025-06-23T18:08:58 >>> host-python3-setuptools 44.0.0 Configuring
2025-06-23T18:08:58 >>> host-python3-setuptools 44.0.0 Building
2025-06-23T18:08:58 >>> host-python3-setuptools 44.0.0 Installing to host directory
2025-06-23T18:08:59 >>> host-meson 0.60.3 Extracting
2025-06-23T18:09:00 >>> host-meson 0.60.3 Patching
2025-06-23T18:09:00 >>> host-meson 0.60.3 Configuring
2025-06-23T18:09:00 >>> host-meson 0.60.3 Building
2025-06-23T18:09:00 >>> host-meson 0.60.3 Installing to host directory
2025-06-23T18:09:02 >>> libpthread-stubs 0.4 Extracting
2025-06-23T18:09:02 >>> libpthread-stubs 0.4 Patching
2025-06-23T18:09:02 >>> libpthread-stubs 0.4 Updating config.sub and config.guess
2025-06-23T18:09:02 >>> libpthread-stubs 0.4 Patching libtool
2025-06-23T18:09:02 >>> libpthread-stubs 0.4 Configuring
2025-06-23T18:09:04 >>> libpthread-stubs 0.4 Building
2025-06-23T18:09:04 >>> libpthread-stubs 0.4 Installing to staging directory
2025-06-23T18:09:04 >>> libpthread-stubs 0.4 Fixing libtool files
2025-06-23T18:09:04 >>> libpthread-stubs 0.4 Installing to target
2025-06-23T18:09:04 >>> libffi 3.2.1 Extracting
2025-06-23T18:09:04 >>> libffi 3.2.1 Patching
2025-06-23T18:09:04 >>> libffi 3.2.1 Updating config.sub and config.guess
2025-06-23T18:09:04 >>> libffi 3.2.1 Configuring
2025-06-23T18:09:04 >>> libffi 3.2.1 Autoreconfiguring
2025-06-23T18:09:10 >>> libffi 3.2.1 Patching libtool
2025-06-23T18:09:16 >>> libffi 3.2.1 Building
2025-06-23T18:09:16 >>> libffi 3.2.1 Installing to staging directory
2025-06-23T18:09:16 >>> libffi 3.2.1 Fixing libtool files
2025-06-23T18:09:17 >>> libffi 3.2.1 Installing to target
2025-06-23T18:09:17 >>> mpdecimal 2.4.1 Extracting
2025-06-23T18:09:17 >>> mpdecimal 2.4.1 Patching
2025-06-23T18:09:17 >>> mpdecimal 2.4.1 Updating config.sub and config.guess
2025-06-23T18:09:17 >>> mpdecimal 2.4.1 Configuring
2025-06-23T18:09:17 >>> mpdecimal 2.4.1 Autoreconfiguring
2025-06-23T18:09:19 >>> mpdecimal 2.4.1 Patching libtool
2025-06-23T18:09:21 >>> mpdecimal 2.4.1 Building
2025-06-23T18:09:23 >>> mpdecimal 2.4.1 Installing to staging directory
2025-06-23T18:09:23 >>> mpdecimal 2.4.1 Fixing libtool files
2025-06-23T18:09:24 >>> mpdecimal 2.4.1 Installing to target
2025-06-23T18:09:24 >>> libopenssl 1.1.1m Extracting
2025-06-23T18:09:24 >>> libopenssl 1.1.1m Patching
2025-06-23T18:09:24 >>> libopenssl 1.1.1m Configuring
2025-06-23T18:09:26 >>> libopenssl 1.1.1m Building
2025-06-23T18:09:51 >>> libopenssl 1.1.1m Installing to staging directory
2025-06-23T18:09:52 >>> libopenssl 1.1.1m Fixing libtool files
2025-06-23T18:09:52 >>> libopenssl 1.1.1m Installing to target
2025-06-23T18:09:54 >>> openssl  Extracting
2025-06-23T18:09:54 >>> openssl  Patching
2025-06-23T18:09:54 >>> openssl  Configuring
2025-06-23T18:09:54 >>> openssl  Building
2025-06-23T18:09:54 >>> openssl  Installing to target
2025-06-23T18:09:54 >>> readline 7.0 Extracting
2025-06-23T18:09:54 >>> readline 7.0 Patching
2025-06-23T18:09:54 >>> readline 7.0 Updating config.sub and config.guess
2025-06-23T18:09:54 >>> readline 7.0 Patching libtool
2025-06-23T18:09:54 >>> readline 7.0 Configuring
2025-06-23T18:10:00 >>> readline 7.0 Building
2025-06-23T18:10:01 >>> readline 7.0 Installing to staging directory
2025-06-23T18:10:01 >>> readline 7.0 Fixing libtool files
2025-06-23T18:10:01 >>> readline 7.0 Installing to target
2025-06-23T18:10:01 >>> sqlite 3210000 Extracting
2025-06-23T18:10:01 >>> sqlite 3210000 Patching
2025-06-23T18:10:01 >>> sqlite 3210000 Updating config.sub and config.guess
2025-06-23T18:10:01 >>> sqlite 3210000 Patching libtool
2025-06-23T18:10:02 >>> sqlite 3210000 Configuring
2025-06-23T18:10:05 >>> sqlite 3210000 Building
2025-06-23T18:10:22 >>> sqlite 3210000 Installing to staging directory
2025-06-23T18:10:22 >>> sqlite 3210000 Fixing libtool files
2025-06-23T18:10:22 >>> sqlite 3210000 Installing to target
2025-06-23T18:10:22 >>> xz 5.2.3 Extracting
2025-06-23T18:10:22 >>> xz 5.2.3 Patching
2025-06-23T18:10:23 >>> xz 5.2.3 Updating config.sub and config.guess
2025-06-23T18:10:23 >>> xz 5.2.3 Patching libtool
2025-06-23T18:10:23 >>> xz 5.2.3 Configuring
2025-06-23T18:10:29 >>> xz 5.2.3 Building
2025-06-23T18:10:33 >>> xz 5.2.3 Installing to staging directory
2025-06-23T18:10:34 >>> xz 5.2.3 Fixing libtool files
2025-06-23T18:10:34 >>> xz 5.2.3 Installing to target
2025-06-23T18:10:34 >>> python3 3.8.6 Extracting
2025-06-23T18:10:36 >>> python3 3.8.6 Patching
2025-06-23T18:10:36 >>> python3 3.8.6 Updating config.sub and config.guess
2025-06-23T18:10:36 >>> python3 3.8.6 Configuring
2025-06-23T18:10:36 >>> python3 3.8.6 Autoreconfiguring
2025-06-23T18:10:40 >>> python3 3.8.6 Patching libtool
2025-06-23T18:11:09 >>> python3 3.8.6 Building
2025-06-23T18:11:36 >>> python3 3.8.6 Installing to staging directory
2025-06-23T18:11:38 >>> python3 3.8.6 Fixing libtool files
2025-06-23T18:11:38 >>> python3 3.8.6 Installing to target
2025-06-23T18:11:42 >>> kmod 26 Extracting
2025-06-23T18:11:42 >>> kmod 26 Patching
2025-06-23T18:11:42 >>> kmod 26 Updating config.sub and config.guess
2025-06-23T18:11:42 >>> kmod 26 Configuring
2025-06-23T18:11:42 >>> kmod 26 Autoreconfiguring
2025-06-23T18:11:48 >>> kmod 26 Patching libtool
2025-06-23T18:11:54 >>> kmod 26 Building
2025-06-23T18:11:56 >>> kmod 26 Installing to staging directory
2025-06-23T18:11:56 >>> kmod 26 Fixing libtool files
2025-06-23T18:11:56 >>> kmod 26 Installing to target
2025-06-23T18:11:57 >>> eudev 3.2.7 Extracting
2025-06-23T18:11:57 >>> eudev 3.2.7 Patching
2025-06-23T18:11:57 >>> eudev 3.2.7 Updating config.sub and config.guess
2025-06-23T18:11:57 >>> eudev 3.2.7 Patching libtool
2025-06-23T18:11:57 >>> eudev 3.2.7 Configuring
2025-06-23T18:12:06 >>> eudev 3.2.7 Building
2025-06-23T18:12:12 >>> eudev 3.2.7 Installing to staging directory
2025-06-23T18:12:12 >>> eudev 3.2.7 Fixing libtool files
2025-06-23T18:12:12 >>> eudev 3.2.7 Installing to target
2025-06-23T18:12:13 >>> udev  Extracting
2025-06-23T18:12:13 >>> udev  Patching
2025-06-23T18:12:13 >>> udev  Configuring
2025-06-23T18:12:13 >>> udev  Building
2025-06-23T18:12:13 >>> udev  Installing to target
2025-06-23T18:12:13 >>> valgrind 3.18.1 Extracting
2025-06-23T18:12:17 >>> valgrind 3.18.1 Patching
2025-06-23T18:12:17 >>> valgrind 3.18.1 Updating config.sub and config.guess
2025-06-23T18:12:17 >>> valgrind 3.18.1 Patching libtool
2025-06-23T18:12:17 >>> valgrind 3.18.1 Configuring
2025-06-23T18:12:30 >>> valgrind 3.18.1 Building
2025-06-23T18:13:23 >>> valgrind 3.18.1 Installing to staging directory
2025-06-23T18:13:24 >>> valgrind 3.18.1 Fixing libtool files
2025-06-23T18:13:25 >>> valgrind 3.18.1 Installing to target
2025-06-23T18:13:27 >>> libdrm 2.4.109 Extracting
2025-06-23T18:13:28 >>> libdrm 2.4.109 Patching
2025-06-23T18:13:28 >>> libdrm 2.4.109 Configuring
2025-06-23T18:13:30 >>> libdrm 2.4.109 Building
2025-06-23T18:13:32 >>> libdrm 2.4.109 Installing to staging directory
2025-06-23T18:13:33 >>> libdrm 2.4.109 Fixing libtool files
2025-06-23T18:13:33 >>> libdrm 2.4.109 Installing to target
2025-06-23T18:13:33 >>> host-wayland 1.20.0 Extracting
2025-06-23T18:13:34 >>> host-wayland 1.20.0 Patching
2025-06-23T18:13:34 >>> host-wayland 1.20.0 Configuring
2025-06-23T18:13:36 >>> host-wayland 1.20.0 Building
2025-06-23T18:13:37 >>> host-wayland 1.20.0 Installing to host directory
2025-06-23T18:13:39 >>> libxml2 2.9.7 Extracting
2025-06-23T18:13:41 >>> libxml2 2.9.7 Patching
2025-06-23T18:13:42 >>> libxml2 2.9.7 Updating config.sub and config.guess
2025-06-23T18:13:42 >>> libxml2 2.9.7 Patching libtool
2025-06-23T18:13:42 >>> libxml2 2.9.7 Configuring
2025-06-23T18:13:51 >>> libxml2 2.9.7 Building
2025-06-23T18:13:59 >>> libxml2 2.9.7 Installing to staging directory
2025-06-23T18:13:59 >>> libxml2 2.9.7 Fixing package configuration files
2025-06-23T18:13:59 >>> libxml2 2.9.7 Fixing libtool files
2025-06-23T18:13:59 >>> libxml2 2.9.7 Installing to target
2025-06-23T18:14:00 >>> wayland 1.20.0 Extracting
2025-06-23T18:14:00 >>> wayland 1.20.0 Patching
2025-06-23T18:14:00 >>> wayland 1.20.0 Configuring
2025-06-23T18:14:04 >>> wayland 1.20.0 Building
2025-06-23T18:14:05 >>> wayland 1.20.0 Installing to staging directory
2025-06-23T18:14:05 >>> wayland 1.20.0 Fixing libtool files
2025-06-23T18:14:05 >>> wayland 1.20.0 Installing to target
2025-06-23T18:14:06 >>> rockchip-mali master Syncing from source dir /home/ars/rk3568_linux_sdk/buildroot/../external/libmali
2025-06-23T18:15:26 >>> rockchip-mali master Configuring
Done in 12min 14s  (error code: 2)
log saved on /home/ars/rk3568_linux_sdk/br.log
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-util.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-server.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-server-core.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-client.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-client-core.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/cursor/wayland-cursor.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/src/wayland-version.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/meson-private/wayland-scanner.pc to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/pkgconfig
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/meson-private/wayland-server.pc to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/pkgconfig
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/meson-private/wayland-client.pc to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/pkgconfig
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/meson-private/wayland-cursor.pc to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/lib/pkgconfig
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/wayland-scanner.mk to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/share/wayland
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/protocol/wayland.xml to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/share/wayland
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/protocol/wayland.dtd to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/share/wayland
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/wayland-scanner.m4 to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot/usr/share/aclocal
2025-06-23T18:14:05 PATH="/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/bin:/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/sbin:/home/ars/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin"  DESTDIR=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target PYTHONNOUSERSITE=y /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/bin/ninja  -j9 -C /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0//build install
2025-06-23T18:14:05 ninja: Entering directory `/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0//build'
[0/1] Installing files.
2025-06-23T18:14:05 Installing src/wayland-scanner to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/bin
2025-06-23T18:14:05 Installing src/wayland-server-protocol.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing src/wayland-client-protocol.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing src/libwayland-server.so.0.20.0 to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/lib
2025-06-23T18:14:05 Installing src/libwayland-client.so.0.20.0 to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/lib
2025-06-23T18:14:05 Installing cursor/libwayland-cursor.so.0.20.0 to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/lib
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-util.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-server.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-server-core.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-client.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/src/wayland-client-core.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/cursor/wayland-cursor.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/src/wayland-version.h to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/include
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/meson-private/wayland-scanner.pc to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/lib/pkgconfig
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/meson-private/wayland-server.pc to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/lib/pkgconfig
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/meson-private/wayland-client.pc to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/lib/pkgconfig
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/build/meson-private/wayland-cursor.pc to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/lib/pkgconfig
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/wayland-scanner.mk to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/share/wayland
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/protocol/wayland.xml to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/share/wayland
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/protocol/wayland.dtd to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/share/wayland
2025-06-23T18:14:05 Installing /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/wayland-1.20.0/wayland-scanner.m4 to /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/share/aclocal
2025-06-23T18:14:05 rm -rf /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/target/usr/share/wayland
2025-06-23T18:14:06 rsync -au --chmod=u=rwX,go=rX --exclude .svn --exclude .git --exclude .hg --exclude .bzr --exclude CVS /home/ars/rk3568_linux_sdk/buildroot/../external/libmali/ /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/rockchip-mali-master
Refresh index: 100% (126/126), done.45% (57/126)
2025-06-23T18:15:26 M lib/arm-linux-gnueabihf/libmali-bifrost-g52-g2p0-x11.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t76x-r18p0-r0p0-gbm.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t76x-r18p0-r0p0-wayland.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t76x-r18p0-r0p0-x11.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t76x-r18p0-r1p0-gbm.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t76x-r18p0-r1p0-wayland.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t76x-r18p0-r1p0-x11.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t86x-r18p0-gbm.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t86x-r18p0-wayland.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t86x-r18p0-x11.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-midgard-t86x-r18p0.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-utgard-400-r7p0-r1p1-gbm.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-utgard-400-r7p0-r1p1-wayland.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-utgard-400-r7p0-r1p1-x11.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-utgard-400-r7p0-r3p0-wayland.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-utgard-450-r7p0-gbm.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-utgard-450-r7p0-wayland.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-utgard-450-r7p0-x11.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-valhall-g610-g6p0-dummy.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-valhall-g610-g6p0-gbm.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-valhall-g610-g6p0-wayland.so
2025-06-23T18:15:26 D lib/arm-linux-gnueabihf/libmali-valhall-g610-g6p0-x11.so
2025-06-23T18:15:26 D meson.build
2025-06-23T18:15:26 D meson_options.txt
2025-06-23T18:15:26 D optimize_3
2025-06-23T18:15:26 D optimize_s/aarch64-linux-gnu/libmali-bifrost-g31-g2p0-gbm.so
2025-06-23T18:15:26 D optimize_s/aarch64-linux-gnu/libmali-bifrost-g31-g2p0-only-cl.so
2025-06-23T18:15:26 D optimize_s/aarch64-linux-gnu/libmali-bifrost-g31-g2p0-wayland.so
2025-06-23T18:15:26 D optimize_s/aarch64-linux-gnu/libmali-bifrost-g31-g2p0-without-cl-wayland.so
2025-06-23T18:15:26 D optimize_s/aarch64-linux-gnu/libmali-bifrost-g31-g2p0-x11.so
2025-06-23T18:15:26 D optimize_s/aarch64-linux-gnu/libmali-bifrost-g52-g2p0-dummy-gbm.so
2025-06-23T18:15:26 D optimize_s/aarch64-linux-gnu/libmali-bifrost-g52-g2p0-without-cl-dummy-gbm.so
2025-06-23T18:15:26 D optimize_s/arm-linux-gnueabihf/libmali-bifrost-g52-g2p0-dummy-gbm.so
2025-06-23T18:15:26 D optimize_s/arm-linux-gnueabihf/libmali-bifrost-g52-g2p0-without-cl-dummy-gbm.so
2025-06-23T18:15:26 D overlay/S10libmali_px3se
2025-06-23T18:15:26 D overlay/S10libmali_rk3288
2025-06-23T18:15:26 D overlay/px3seBase
2025-06-23T18:15:26 D scripts/fixup_dummy.sh
2025-06-23T18:15:26 D scripts/fixup_dynsym.py
2025-06-23T18:15:26 D scripts/fixup_nowrap.sh
2025-06-23T18:15:26 D scripts/fixup_nox11.sh
2025-06-23T18:15:26 D scripts/grabber.sh
2025-06-23T18:15:26 D scripts/normalize.sh
2025-06-23T18:15:26 D scripts/parse_name.sh
2025-06-23T18:15:26 D scripts/update_debian.sh
2025-06-23T18:15:26 WARN: /home/ars/rk3568_linux_sdk/buildroot/../external/libmali is dirty!
2025-06-23T18:15:26 rm -rf /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/rockchip-mali-master//build
2025-06-23T18:15:26 mkdir -p /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/rockchip-mali-master//build
2025-06-23T18:15:26 sed -e 's%@TARGET_CROSS@%/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/bin/aarch64-buildroot-linux-gnu-%g' -e 's%@TARGET_ARCH@%aarch64%g' -e 's%@TARGET_CPU@%cortex-a55%g' -e 's%@TARGET_ENDIAN@%little%g' -e "s%@TARGET_CFLAGS@%'-D_LARGEFILE_SOURCE', '-D_LARGEFILE64_SOURCE', '-D_FILE_OFFSET_BITS=64', '-Os'%g" -e "s%@TARGET_LDFLAGS@%%g" -e "s%@TARGET_CXXFLAGS@%'-D_LARGEFILE_SOURCE', '-D_LARGEFILE64_SOURCE', '-D_FILE_OFFSET_BITS=64', '-Os'%g" -e 's%@HOST_DIR@%/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host%g' -e 's%@STAGING_DIR@%/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/aarch64-buildroot-linux-gnu/sysroot%g' -e 's%@STATIC@%false%g' -e "/^[binaries]$/s::" -e "/^[properties]$/s::" package/meson/cross-compilation.conf.in > /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/rockchip-mali-master//build/cross-compilation.conf
2025-06-23T18:15:26 PATH="/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/bin:/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/sbin:/home/ars/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin" CC_FOR_BUILD="/usr/bin/gcc" CXX_FOR_BUILD="/usr/bin/g++"  PYTHONNOUSERSITE=y /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/bin/meson --prefix=/usr --libdir=lib --default-library=shared --buildtype=release --cross-file=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/rockchip-mali-master//build/cross-compilation.conf -Db_pie=false -Dstrip=false -Dbuild.pkg_config_path=/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/host/lib/pkgconfig -Dwith-overlay=true -Dopencl-icd=false -Dkhr-header=true -Dplatform=wayland -Dgpu=bifrost-g52 -Dversion=g2p0 -Dsubversion= /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/rockchip-mali-master/ /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/rockchip-mali-master//build
2025-06-23T18:15:26
2025-06-23T18:15:26 ERROR: Neither directory contains a build file meson.build.
2025-06-23T18:15:27 make[1]: *** [package/pkg-generic.mk:221: /home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/build/rockchip-mali-master/.stamp_configured] Error 1
2025-06-23T18:15:27 make: *** [/home/ars/rk3568_linux_sdk/buildroot/output/rockchip_rk3568/Makefile:16: _all] Error 2
Command exited with non-zero status 1
you take 12:22.42 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 717:
    /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
GMT+8, 2026-10-31 04:29
