查看: 1924|回复: 0
STM32F103串口3初始化失败
2024-12-18
发表于 2025-7-9 20:53:01 | 显示全部楼层 |阅读模式
2金钱
串口3无法初始化,求求各位大佬帮忙看看!串口3的初始化配置:
.c文件(部分):
int fputc(int ch, FILE *f)
  if(usart == 0){                        /* 如果当前没有设置USART句柄,则返回EOF表示错误 */
    return EOF;
  /* 根据当前设置的USART句柄,选择对应的USART外设发送字符 */
  if(usart == 1){
        while ((USART1->SR & 0X40) == 0);                 /* 等待USART1发送完成,然后发送字符 */
        USART1->DR = (uint8_t)ch;                                 /* 将要发送的字符 ch 写入到DR寄存器 */
  else if(usart == 2){
        while ((USART2->SR & 0X40) == 0);                 /* 等待USART2发送完成,然后发送字符 */
        USART2->DR = (uint8_t)ch;                                 /* 将要发送的字符 ch 写入到DR寄存器 */
  else if(usart == 3){
        while ((USART3->SR & 0X40) == 0);                 /* 等待USART3发送完成,然后发送字符 */
        USART3->DR = (uint8_t)ch;                                 /* 将要发送的字符 ch 写入到DR寄存器 */
  return ch;        /* 返回发送的字符 */
#if USART3_EN == 1
        __HAL_RCC_GPIOB_CLK_ENABLE();
        __HAL_RCC_USART3_CLK_ENABLE();
        gpio_initstructure.Pin = GPIO_PIN_10;
        gpio_initstructure.Mode = GPIO_MODE_AF_PP;
        gpio_initstructure.Speed = GPIO_SPEED_FREQ_HIGH;
        HAL_GPIO_Init(GPIOB,&gpio_initstructure);
        gpio_initstructure.Pin = GPIO_PIN_11;
        gpio_initstructure.Mode = GPIO_MODE_AF_INPUT;
        gpio_initstructure.Pull = GPIO_PULLUP;
        usart3_initstructure.Instance = USART3;
        usart3_initstructure.Init.BaudRate = USART3_BAUD;
        usart3_initstructure.Init.WordLength = UART_WORDLENGTH_8B;
        usart3_initstructure.Init.StopBits = UART_STOPBITS_1;
        usart3_initstructure.Init.Parity = UART_PARITY_NONE;
        usart3_initstructure.Init.Mode = UART_MODE_TX_RX;
        usart3_initstructure.Init.HwFlowCtl = UART_HWCONTROL_NONE;
        HAL_UART_Init(&usart3_initstructure);
        HAL_NVIC_SetPriority(USART3_IRQn,3,3);
        HAL_NVIC_EnableIRQ(USART3_IRQn);
        HAL_UART_Receive_IT(&usart3_initstructure,(uint8_t*)rx_buffer3,rx_size);
#endif
.h文件(部分):
#if USART3_EN == 1
        #define USART3_BAUD 115200
        #define USART3_RX_BUF_SIZE 256
        extern uint8_t g_USART3_Rxbuf[USART3_RX_BUF_SIZE];
        extern uint16_t g_USART3_RecPos;
#endif
仿真时发现程序卡死在while ((USART3->SR & 0X40) == 0); 且串口3寄存器没有数据如图
GMT+8, 2026-10-31 03:50
