查看: 1010|回复: 0
Apollo STM32F429板子LCD黑屏+ST-LINK连接不上
2025-7-31
发表于 2025-8-6 19:28:47 | 显示全部楼层 |阅读模式
Windows电脑通过STM32CubeIDE软件运行下面代码,电脑通过ST-LINK/V2连接的Apollo STM32F429核心板(母板是Apollo STM32F4/F7/H7 BOARD V1.7):/* USER CODE BEGIN Header *//**  ******************************************************************************  * @file           : main.c  * @brief          : Main program body  ******************************************************************************  * @attention  *  * Copyright (c) 2023 STMicroelectronics.  * All rights reserved.  *  * This software is licensed under terms that can be found in the LICENSE file  * in the root directory of this software component.  * If no LICENSE file comes with this software, it is provided AS-IS.  *  ******************************************************************************  *//* USER CODE END Header *//* Includes ------------------------------------------------------------------*/#include "main.h"#include "rtc.h"#include "usart.h"#include "gpio.h"/* Private includes ----------------------------------------------------------*//* USER CODE BEGIN Includes */#include <los_task.h>#include <usart.h>#include  <stdio.h>/* USER CODE END Includes *//* Private typedef -----------------------------------------------------------*//* USER CODE BEGIN PTD *//* USER CODE END PTD *//* Private define ------------------------------------------------------------*//* USER CODE BEGIN PD *//* USER CODE END PD *//* Private macro -------------------------------------------------------------*//* USER CODE BEGIN PM *//* USER CODE END PM *//* Private variables ---------------------------------------------------------*//* USER CODE BEGIN PV *//* USER CODE END PV *//* Private function prototypes -----------------------------------------------*/void SystemClock_Config(void);/* USER CODE BEGIN PFP *//* USER CODE END PFP *//* Private user code ---------------------------------------------------------*//* USER CODE BEGIN 0 */int __io_putchar(int ch){        HAL_UART_Transmit(&huart1,(uint8_t*)&ch,1,2000);        HAL_UART_Transmit(&huart3,(uint8_t*)&ch,1,2000);        return 1;}static void *hello_task(UINT32 arg){        while(1)        {                printf("Hello,world!\r\n");                LOS_TaskDelay(LOS_MS2Tick(1000));        }        return NULL;}UINT32 taskid;static UINT32 create_hello_task(){        UINT32 ret=LOS_OK;        TSK_INIT_PARAM_S task_init_param={0};        task_init_param.pcName="hello";        task_init_param.usTaskPrio=5;        task_init_param.uwStackSize=4096;        task_init_param.pfnTaskEntry=hello_task;        ret=LOS_TaskCreate(&taskid, &task_init_param);        return ret;}static void *inspire_task(UINT32 arg){        while(1)        {                printf("No pains,no gains!\r\n");                LOS_TaskDelay(LOS_MS2Tick(2000));        }        return NULL;}UINT32 taskid1;static UINT32 create_inspire_task(){        UINT32 ret=LOS_OK;        TSK_INIT_PARAM_S task_init_param={0};        task_init_param.pcName="inspire";        task_init_param.usTaskPrio=5;        task_init_param.uwStackSize=4096;        task_init_param.pfnTaskEntry=inspire_task;        ret=LOS_TaskCreate(&taskid1, &task_init_param);        return ret;}static void *king_task(UINT32 arg){        while(1)        {                printf("Other tasks cannot run when I am running because my priority is higer than others!!\r\n");//                LOS_TaskDelay(LOS_MS2Tick(2000));                //思&#65533;?&#65533;:为什么不用LOS_TaskDelay呢?                for(int i=0;i<0xffffff;i++);        }        return NULL;}UINT32 taskid2;static UINT32 create_king_task(){        UINT32 ret=LOS_OK;        TSK_INIT_PARAM_S task_init_param={0};        task_init_param.pcName="inspire";        task_init_param.usTaskPrio=3;        task_init_param.uwStackSize=4096;        task_init_param.pfnTaskEntry=king_task;        ret=LOS_TaskCreate(&taskid2, &task_init_param);        return ret;}/* USER CODE END 0 *//**  * @brief  The application entry point.  * @retval int  */int main(void){  /* USER CODE BEGIN 1 */  /* USER CODE END 1 */  /* MCU Configuration--------------------------------------------------------*/  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */  HAL_Init();  /* USER CODE BEGIN Init */  /* USER CODE END Init */  /* Configure the system clock */  SystemClock_Config();  /* USER CODE BEGIN SysInit */  /* USER CODE END SysInit */  /* Initialize all configured peripherals */  MX_GPIO_Init();  MX_RTC_Init();  MX_USART1_UART_Init();  MX_USART3_UART_Init();  /* USER CODE BEGIN 2 */        LOS_KernelInit();        create_hello_task();        create_inspire_task();        create_king_task();        LOS_Start();  /* USER CODE END 2 */  /* Infinite loop */  /* USER CODE BEGIN WHILE */        while (1)  {    /* USER CODE END WHILE */    /* USER CODE BEGIN 3 */  }  /* USER CODE END 3 */}/**  * @brief System Clock Configuration  * @retval None  */void SystemClock_Config(void){  RCC_OscInitTypeDef RCC_OscInitStruct = {0};  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};  /** Configure the main internal regulator output voltage  */  __HAL_RCC_PWR_CLK_ENABLE();  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);  /** Initializes the RCC Oscillators according to the specified parameters  * in the RCC_OscInitTypeDef structure.  */  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE|RCC_OSCILLATORTYPE_LSE;  RCC_OscInitStruct.HSEState = RCC_HSE_ON;  RCC_OscInitStruct.LSEState = RCC_LSE_ON;  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;  RCC_OscInitStruct.PLL.PLLM = 15;  RCC_OscInitStruct.PLL.PLLN = 216;  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;  RCC_OscInitStruct.PLL.PLLQ = 4;  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)  {    Error_Handler();  }  /** Activate the Over-Drive mode  */  if (HAL_PWREx_EnableOverDrive() != HAL_OK)  {    Error_Handler();  }  /** Initializes the CPU, AHB and APB buses clocks  */  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)  {    Error_Handler();  }}/* USER CODE BEGIN 4 *//* USER CODE END 4 *//**  * @brief  Period elapsed callback in non blocking mode  * @note   This function is called  when TIM1 interrupt took place, inside  * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment  * a global variable "uwTick" used as application time base.  * @param  htim : TIM handle  * @retval None  */void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim){  /* USER CODE BEGIN Callback 0 */  /* USER CODE END Callback 0 */  if (htim->Instance == TIM1) {    HAL_IncTick();  }  /* USER CODE BEGIN Callback 1 */  /* USER CODE END Callback 1 */}/**  * @brief  This function is executed in case of error occurrence.  * @retval None  */void Error_Handler(void){  /* USER CODE BEGIN Error_Handler_Debug */  /* User can add his own implementation to report the HAL error return state */  __disable_irq();  while (1)  {  }  /* USER CODE END Error_Handler_Debug */}#ifdef  USE_FULL_ASSERT/**  * @brief  Reports the name of the source file and the source line number  *         where the assert_param error has occurred.  * @param  file: pointer to the source file name  * @param  line: assert_param error line source number  * @retval None  */void assert_failed(uint8_t *file, uint32_t line){  /* USER CODE BEGIN 6 */  /* User can add his own implementation to report the file name and line number,     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */  /* USER CODE END 6 */}#endif /* USE_FULL_ASSERT */运行结果如下:STMicroelectronics ST-LINK GDB server. Version 7.3.0Copyright (c) 2023, STMicroelectronics. All rights reserved.Starting server with the following options:        Persistent Mode            : Disabled        Logging Level              : 1        Listen Port Number         : 61234        Status Refresh Delay       : 15s        Verbose Mode               : Disabled        SWD Debug                  : Enabled        InitWhile                  : EnabledWaiting for debugger connection...Debugger connectedWaiting for debugger connection...Debugger connectedWaiting for debugger connection...      -------------------------------------------------------------------                       STM32CubeProgrammer v2.13.0                        -------------------------------------------------------------------Log output file:   C:\Users\16610\AppData\Local\Temp\STM32CubeProgrammer_a15480.logST-LINK SN  : 31FF71064D55333950201743ST-LINK FW  : V2J46S7Board       : --Voltage     : 3.22VSWD freq    : 4000 KHzConnect mode: Under ResetReset mode  : Hardware resetDevice ID   : 0x419Revision ID : Rev 5/BDevice name : STM32F42xxx/F43xxxFlash size  : 1 MBytesDevice type : MCUDevice CPU  : Cortex-M4BL Version  : 0x91Memory Programming ...Opening and parsing file: ST-LINK_GDB_server_a15480.srec  File          : ST-LINK_GDB_server_a15480.srec  Size          : 37.33 KB   Address       : 0x08000000 Erasing memory corresponding to segment 0:Erasing internal memory sectors [0 2]Download in Progress:File download completeTime elapsed during download operation: 00:00:01.242Verifying ...Download verified successfully Shutting down...Exit.运行该段代码之前LCD显示屏能正常显示界面和APP,运行完LCD显示屏黑屏了。过了几天没启动板子,STM32F429开发板重新通上电源后按启动键,电源键PWR蓝灯和输入输出的DSO红灯亮和DSI黄灯亮都正常,就是LCD显示屏不显示。再次运行上面代码,黑屏还没解决,又出现新问题(ST-LINK也连接不上了):Starting server with the following options:        Persistent Mode            : Disabled        Logging Level              : 1        Listen Port Number         : 61234        Status Refresh Delay       : 15s        Verbose Mode               : Disabled        SWD Debug                  : Enabled        InitWhile                  : EnabledTarget no device foundError in initializing ST-LINK device.Reason: No device found on target.目前就是LCD黑屏+ST-LINK连接不上,这是代码问题?(小白按配套程序运行的,开局就两眼一黑,求助大佬~~)
GMT+8, 2026-10-22 09:46
