查看: 1644|回复: 2
STM32CUBEMX如何用TIM1生成PWM波
99
224
822
822
2014-10-15
193 小时
发表于 2025-8-22 14:00:36 | 显示全部楼层 |阅读模式
先上图
代码:
  1. static void MX_TIM1_Init(void)
  2. {
  3.   /* USER CODE BEGIN TIM1_Init 0 */
  4.   /* USER CODE END TIM1_Init 0 */
  5.   TIM_SlaveConfigTypeDef sSlaveConfig = {0};
  6.   TIM_MasterConfigTypeDef sMasterConfig = {0};
  7.   TIM_OC_InitTypeDef sConfigOC = {0};
  8.   TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
  9.   /* USER CODE BEGIN TIM1_Init 1 */
  10.   /* USER CODE END TIM1_Init 1 */
  11.   htim1.Instance = TIM1;
  12.   htim1.Init.Prescaler = 0;
  13.   htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  14.   htim1.Init.Period = 65535;
  15.   htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  16.   htim1.Init.RepetitionCounter = 0;
  17.   htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  18.   if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
  19.   {
  20.     Error_Handler();
  21.   }
  22.   if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
  23.   {
  24.     Error_Handler();
  25.   }
  26.   sSlaveConfig.SlaveMode = TIM_SLAVEMODE_EXTERNAL1;
  27.   sSlaveConfig.InputTrigger = TIM_TS_ITR0;
  28.   if (HAL_TIM_SlaveConfigSynchro(&htim1, &sSlaveConfig) != HAL_OK)
  29.   {
  30.     Error_Handler();
  31.   }
  32.   sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  33.   sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  34.   if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
  35.   {
  36.     Error_Handler();
  37.   }
  38.   sConfigOC.OCMode = TIM_OCMODE_PWM1;
  39.   sConfigOC.Pulse = 10000;
  40.   sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  41.   sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
  42.   sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  43.   sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  44.   sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  45.   if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
  46.   {
  47.     Error_Handler();
  48.   }
  49.   sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
  50.   sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
  51.   sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
  52.   sBreakDeadTimeConfig.DeadTime = 0;
  53.   sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
  54.   sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
  55.   sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
  56.   if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
  57.   {
  58.     Error_Handler();
  59.   }
  60.   /* USER CODE BEGIN TIM1_Init 2 */
  61.   /* USER CODE END TIM1_Init 2 */
  62.   HAL_TIM_MspPostInit(&htim1);
  63. }
  64. static void MX_GPIO_Init(void)
  65. {
  66.   GPIO_InitTypeDef GPIO_InitStruct = {0};
  67. /* USER CODE BEGIN MX_GPIO_Init_1 */
  68. /* USER CODE END MX_GPIO_Init_1 */
  69.   /* GPIO Ports Clock Enable */
  70.   __HAL_RCC_GPIOC_CLK_ENABLE();
  71.   __HAL_RCC_GPIOH_CLK_ENABLE();
  72.   __HAL_RCC_GPIOA_CLK_ENABLE();
  73.   __HAL_RCC_GPIOB_CLK_ENABLE();
  74.   /*Configure GPIO pin Output Level */
  75.   HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_RESET);
  76.   /*Configure GPIO pin : PB3 */
  77.   GPIO_InitStruct.Pin = GPIO_PIN_3;
  78.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  79.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  80.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  81.   HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  82.         GPIO_InitStruct.Pin = GPIO_PIN_8;
  83.   GPIO_InitStruct.Mode = GPIO_MODE_AF_PP ;
  84.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  85.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  86.   HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  87. /* USER CODE BEGIN MX_GPIO_Init_2 */
  88. /* USER CODE END MX_GPIO_Init_2 */
  89. }
可是无法生成PWM波。请高手指教,谢谢
https://www.waveshare.net/study/article-643-1.html 参考下这个
920
4814
4814
2019-9-4
953 小时
发表于 2025-8-22 14:00:37 | 显示全部楼层
发表于 2025-8-23 12:20:07 | 显示全部楼层
GMT+8, 2026-10-31 01:02
