查看: 7500|回复: 0
1126的AIdemo程序摄像头错误提示
2025-8-29
发表于 2025-9-1 10:14:59 | 显示全部楼层 |阅读模式
本人用的是1126 335摄像头的开发板。在测试提供的AIdemo程序出现如下提示:
#Rkaiq XML DirPath: /etc/iqfiles
#bMultictx: 0
ID: 0, sensor_name is m00_f_imx335 1-001a-1, iqfiles is /etc/iqfiles
[08:29:22.108541][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6920: calib_check_getID_by_name(6920): subtag: focusInfPosition from parent tag: zoomfocus_tbl is unknown, assert!!!
[08:29:22.110238][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6998: calib_check_tag_attrs(6998): parent_tag_id:439 tag_id:1201 --- tag id is is wrong: min:0 max:1201
[08:29:22.111227][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7044: calib_check_tag_attrs(7044): parent_tag_id:439 parent_tag_name:zoomfocus_tbl  tag_id:1201 tag_name:unknown --- ASSERT!!!
[08:29:22.112591][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7188: calib_check_tag_mark(7188): parent_tag_id:439 tag_id:1201 --- tag_id is wrong:  min:0 max:1201
[08:29:22.113829][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6920: calib_check_getID_by_name(6920): subtag: focusMacroPosition from parent tag: zoomfocus_tbl is unknown, assert!!!
[08:29:22.115136][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6998: calib_check_tag_attrs(6998): parent_tag_id:439 tag_id:1201 --- tag id is is wrong: min:0 max:1201
[08:29:22.116335][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7044: calib_check_tag_attrs(7044): parent_tag_id:439 parent_tag_name:zoomfocus_tbl  tag_id:1201 tag_name:unknown --- ASSERT!!!
[08:29:22.117727][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7188: calib_check_tag_mark(7188): parent_tag_id:439 tag_id:1201 --- tag_id is wrong:  min:0 max:1201
[08:29:22.473511][XCORE]:XCAM ERROR v4l2_device.cpp:196: open device() failed
[08:29:22.477978][CAMHW]:XCAM ERROR LensHw.cpp:199: get vcm cfg failed
[08:29:22.506287][XCORE]:XCAM ERROR CamHwIsp20.cpp:3751: |||set DC-Iris PwmDuty: 100
[08:29:22.506760][CAMHW]:XCAM ERROR LensHw.cpp:411: iris is not supported
[08:29:22.507259][XCORE]:XCAM ERROR v4l2_device.cpp:657: device(/dev/video15) start failed
[08:29:22.507887][CAMHW]:XCAM ERROR CamHwIsp20.cpp:3319: prepare isp params dev err: -9
查找论坛后,有一篇帖子说zoomfocus_tbl 标签这个错误,我把xml中这个标签删了。但是删了之后程序死了。请问怎么处理。谢谢
GMT+8, 2026-10-30 20:07
