查看: 7705|回复: 3
移植sony mipi机芯到rv1126,通过v4l2_ctl抓yuv图报错
2025-8-27
发表于 2025-9-5 09:56:15 | 显示全部楼层 |阅读模式
在rv1126板子上移植sony mipi机芯,通过v4l2_ctl抓图yuv报rkcif_mipi_lvds: rkcif_irq_pingpong ERR: multi fs in oneframe, bak_int:0x0, fs_num:2错误?请大神帮忙看看,非常感谢!
2020-7-25
10 小时
发表于 2025-9-12 21:39:57 | 显示全部楼层
想问一下怎么抓图像的raw格式数据啊?
2025-8-27
 楼主| 发表于 2025-9-17 16:42:06 | 显示全部楼层
[root@ATK-DLRV1126:/]# v4l2-ctl -d /dev/video5 --set-fmt-video=width=1920,height
=1080,pixelformat=YUYV --stream-mmap=3 --stream-skip=3 --stream-to=/mnt/sdcard/c
if888.uyvy --stream-count=1 --stream-poll
[  258.376467] imx9500 1-001a-1: imx9500_power(624) on(1)
[  258.379452] imx9500 1-001a-1: imx9500_init(612)
[  258.414862] rkcif_mipi_lvds: stream[0] start streaming
[  258.417642] rkcif_mipi_lvds: Allocate dummy buffer, size: 0x003f4800
[  258.417764] rockchip-mipi-csi2 ffb10000.mipi-csi2: stream on, src_sd: 6da2b098, sd_name:rockch
[  258.417774] rockchip-mipi-csi2 ffb10000.mipi-csi2: stream ON
[  258.417801] rockchip-mipi-dphy-rx ff4b0000.csi-dphy: stream on:1
[  258.417815] rockchip-mipi-dphy-rx: data_rate_mbps 594
[  258.418850] rockchip-mipi-dphy-rx ff4b0000.csi-dphy: stream on:1
[  258.418865] imx9500 1-001a-1: imx9500_s_stream: on: 1, 1920x1080@30
[  258.418877] imx9500 1-001a-1: imx9500_s_stream() rseset_gpio 0
[  258.436264] imx9500 1-001a-1: imx9500_s_stream() reset_gpio 1
[  261.631711] rkcif_irq_pingpong ERR: multi fs in o<neframe, bak_int:0x0, fs_num:2
[  261.664953] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.698287] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.731683] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.764949] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.798374] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.831622] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.865059] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.898291] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.931617] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.965061] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  261.998395] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.031629] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.064961] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.098490] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.131732] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.165054] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.198380] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.231628] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.265048] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.298361] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.331720] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.365044] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.398341] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.431738] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.465032] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.498365] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.531721] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.565034] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.598388] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.631726] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.665037] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.698393] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.731702] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.765038] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.798350] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.832227] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.865037] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.898397] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.931731] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.965043] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  262.998400] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.031707] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.065080] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.098402] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.131753] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.165088] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.198382] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.231642] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.265050] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.298383] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.331718] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.365051] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.398409] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.431740] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.465054] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.498389] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.531721] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.565079] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.598389] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.631738] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.664996] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.698329] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.731832] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.765059] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.798390] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.832035] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.865062] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.898398] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.931754] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.965064] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  263.998396] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.031761] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.065067] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.098438] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.131758] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.165303] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.198380] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.231777] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.265111] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.298406] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.331741] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.365074] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.398434] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.431752] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.465076] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.498409] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.531780] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.565077] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.598413] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.631766] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.665079] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.698435] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.732207] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.765059] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.798457] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.831998] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.865084] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.898458] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.931774] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.965108] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  264.998420] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.031778] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.065089] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.098463] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.131791] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.165094] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.198425] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.231799] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.265089] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.298449] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.331783] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.365117] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.398406] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.431803] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.465138] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.498471] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.531744] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.565122] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.598457] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.631768] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.665102] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.698476] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.731747] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.765125] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.798439] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.831992] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.865129] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.898481] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.931774] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.965148] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  265.998462] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.031776] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.065111] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.098466] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.131820] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.165145] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.198442] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.231803] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.265157] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.298489] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.331797] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.365141] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.398451] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.431826] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.465097] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.498448] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.531787] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.565162] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.598474] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.631830] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.665124] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.698436] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.731831] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.765165] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.798437] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.832016] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.865105] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.898485] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.931797] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.965129] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  266.998486] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.031798] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.065132] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.098466] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.131840] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.165157] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.198496] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.231823] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.265137] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.298471] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.331804] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.365140] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.398512] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.431848] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.465141] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.498475] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.531848] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.565142] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.598502] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.631812] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.665164] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.698479] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.731834] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.765147] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.798481] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.831826] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.865171] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.898484] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.931839] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.965188] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  267.998486] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.031797] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.065176] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.098510] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.131799] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.165183] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.198489] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.231849] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.265180] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.298523] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.331826] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.365160] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.398493] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.431829] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.465184] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.498533] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.531862] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.565162] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.598498] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.631855] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.665191] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.698501] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.731834] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.765169] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.798503] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.831983] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.865181] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.898537] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.931839] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.965173] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  268.998529] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.031861] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.065199] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.098540] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.131843] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.165177] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.198535] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.231847] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.265218] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.298538] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.331848] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.365182] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.398515] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.431849] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.465225] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.498624] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.531868] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.565122] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.598458] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.631785] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.665120] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.698458] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.731962] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.765255] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.798452] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.831789] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.865216] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.898527] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.931861] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.965217] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  269.998567] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.031840] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.065191] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.098551] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.131797] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.165208] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.198462] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.231805] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.265241] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.298511] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.331958] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.365135] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.398475] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.431804] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.465137] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.498471] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.531805] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.565203] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.598563] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.631898] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.665220] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.698480] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.731810] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.765163] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.798484] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.831811] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.865151] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.898481] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.931820] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.965153] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  270.998486] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.031881] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.065240] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.098529] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.131885] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.165218] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.198586] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.231913] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.265248] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.298579] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.331922] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.365223] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.398559] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.431895] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.465226] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.498560] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.531894] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.565228] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.598563] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.631897] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.665230] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.698569] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.731898] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.765254] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.798566] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.831912] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.865233] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.898569] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.931917] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.965237] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  271.998548] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.031913] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.065238] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.098596] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.131908] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.165238] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.198577] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.231916] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
<<<[  272.365196] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.398530] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.431896] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
[  272.465230] rkcif_mipi_lvds: not active buffer, skip current frame, mipi/lvds stream[0]
<[  272.478755] rkcif_mipi_lvds: stream[0] start stopping
[  272.498759] rockchip-mipi-csi2 ffb10000.mipi-csi2: stream off, src_sd: 6da2b098, sd_name:rockc
[  272.498831] rockchip-mipi-csi2 ffb10000.mipi-csi2: stream OFF
[  272.498874] rockchip-mipi-dphy-rx ff4b0000.csi-dphy: stream
on:0
[  272.499978] rockchip-mipi-dphy-rx ff4b0000.csi-dphy: stream on:0
[  272.500036] imx9500 1-001a-1: imx9500_s_stream: on: 0, 1920x1080@30
[  272.500080] imx9500 1-001a-1: imx9500_s_stream() reset_gpio 1
[  272.500531] rkcif_mipi_lvds: stream[0] stopping finished
[  272.502528] imx9500 1-001a-1: imx9500_power(624) on(0)
38
38
2022-12-8
发表于 2025-12-3 21:51:03 | 显示全部楼层
从log上看 看下是否是修改什么了 buffer 没有了 显示lvds 木有buffer 来显示帧数据,最后停止出图了。检查流程。
GMT+8, 2026-10-30 19:59
