查看: 7542|回复: 0
rv1126 开发板,上跑 lvgl v9.2 滑动控件时卡顿,cup暂用达97%
2025-7-16
发表于 2025-9-13 16:59:25 | 显示全部楼层 |阅读模式
显存刷新不是用framerbuff 而是使用的是 drm ,屏幕使用rgv旋转90度,gui应用工程使用的是gui_guider 创建
跑的example 为官网 示例:不滑动,正常显示时有 30 fps,cpu占用 7%,但是滑动控件时只有5FPS,cup占用高达 97%,请大神帮忙看一下
static void scroll_event_cb(lv_event_t *e)
    lv_obj_t *cont = lv_event_get_target(e);
    lv_area_t cont_a;
    lv_obj_get_coords(cont, &cont_a);
    int32_t cont_y_center = cont_a.y1 + lv_area_get_height(&cont_a) / 2;
    int32_t r = lv_obj_get_height(cont) * 7 / 10;
    uint32_t i;
    uint32_t child_cnt = lv_obj_get_child_count(cont);
    for (i = 0; i < child_cnt; i++)
        lv_obj_t *child = lv_obj_get_child(cont, i);
        lv_area_t child_a;
        lv_obj_get_coords(child, &child_a);
        int32_t child_y_center = child_a.y1 + lv_area_get_height(&child_a) / 2;
        int32_t diff_y = child_y_center - cont_y_center;
        diff_y = LV_ABS(diff_y);
        /*Get the x of diff_y on a circle.*/
        int32_t x;
        /*If diff_y is out of the circle use the last point of the circle (the radius)*/
        if (diff_y >= r)
            x = r;
            /*Use Pythagoras theorem to get x from radius and y*/
            uint32_t x_sqr = r * r - diff_y * diff_y;
            lv_sqrt_res_t res;
            lv_sqrt(x_sqr, &res, 0x8000); /*Use lvgl's built in sqrt root function*/
            x = r - res.i;
        /*Translate the item by the calculated X coordinate*/
        lv_obj_set_style_translate_x(child, x, 0);
        /*Use some opacity with larger translations*/
        lv_opa_t opa = lv_map(x, 0, r, LV_OPA_TRANSP, LV_OPA_COVER);
        lv_obj_set_style_opa(child, LV_OPA_COVER - opa, 0);
* Translate the object as they scroll
static void lv_example_scroll_6(void)
    lv_obj_t *cont = lv_obj_create(guider_ui.screen_title); // screen_title screen_feedback
    lv_obj_set_size(cont, 500, 500);
    lv_obj_center(cont);
    lv_obj_set_flex_flow(cont, LV_FLEX_FLOW_COLUMN);
    lv_obj_add_event_cb(cont, scroll_event_cb, LV_EVENT_SCROLL, NULL);
    lv_obj_set_style_radius(cont, LV_RADIUS_CIRCLE, 0);
    lv_obj_set_style_clip_corner(cont, true, 0);
    lv_obj_set_scroll_dir(cont, LV_DIR_VER);
    lv_obj_set_scroll_snap_y(cont, LV_SCROLL_SNAP_CENTER);
    lv_obj_set_scrollbar_mode(cont, LV_SCROLLBAR_MODE_OFF);
    uint32_t i;
    for (i = 0; i < 20; i++)
        lv_obj_t *btn = lv_button_create(cont);
        lv_obj_set_width(btn, lv_pct(100));
        lv_obj_t *label = lv_label_create(btn);
        lv_label_set_text_fmt(label, "Button %" LV_PRIu32, i);
    /*Update the buttons position manually for first*/
    lv_obj_send_event(cont, LV_EVENT_SCROLL, NULL);
    /*Be sure the fist button is in the middle*/
    lv_obj_scroll_to_view(lv_obj_get_child(cont, 0), LV_ANIM_OFF);
GMT+8, 2026-10-30 20:07
