查看: 7826|回复: 0
打印 上一主题 下一主题
T113-i 无法设置spi为 slave 模式?
2020-6-21
27 小时
跳转到指定楼层
楼主
发表于 2025-9-29 09:18:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
20金钱
按照相关教程
1、设置board-atk-commo.dtsi的spi1节点为:
&spi1 {
        clock-frequency = <100000000>;
        pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
        pinctrl-1 = <&spi1_pins_c>;
        pinctrl-names = "default", "sleep";
        spi_slave_mode = <1>;//设置为从机模式
        spi1_cs_number = <1>;
        spi1_cs_bitmap = <1>;
        status = "okay";
        spidev@0{
              compatible = "rohm,dh2228fv";
              device_type= "spi_board1";
              reg=<0x0>;
              spi-max-frequency=<0x989680>;//10MHz
2、关闭led的PB8
    leds {
                compatible = "gpio-leds";
                status = "disabled";
        led@0 {
                        label = "heartbeat";
                        gpios = <&pio PB 8 GPIO_ACTIVE_HIGH>;
                        linux,default-trigger = "heartbeat";
3、关闭dmic
&dmic {
        pinctrl-names   = "default","sleep";
        pinctrl-0       = <&dmic_pins_a>;
        pinctrl-1       = <&dmic_pins_b>;
开发板开机显示:
[    0.565010] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[    0.573585] sunxi_spi_probe()2852 - Unable to allocate SPI slave
[    0.579985] spi: probe of 4026000.spi failed with error -12
问题:
1)、spi1的spi_slave_mode = <1>,设置为从机模式时,编译后,在dev中看不到spidev1.0这个spi设备,但是设置为主机却能看到。现在我想设置为从机模式,不知道需要设置哪里?有没有高手帮解答一下?
根据开发板开机提示,定位到驱动spi-sunxi.c的2852行附近的代码
/* create spi slave */
           master = spi_alloc_slave(&pdev->dev, sizeof(struct sunxi_spi));
           if (master == NULL) {
                      SPI_ERR("Unable to allocate SPI slave\n");
                      ret = -ENOMEM;
                      goto err0;
2)、从错误提示和代码来看,应该是分配spi slave 空间不成功,不知道为什么,求指教?另外spi_alloc_slave这个函数在哪个文件中定义?
GMT+8, 2026-10-30 23:30
