查看: 1180|回复: 2
求助,H743单片机的MPU保护设置与SCT文件的问题
2019-9-24
发表于 2025-9-29 10:57:39 | 显示全部楼层 |阅读模式
我用SCT文件去管理内存,以及设置了MPU保护,目前我设置的AXI RAM,SRAM4都能正常写入数值,就SRAM1~SRAM2的不行。 以下是MPU代码和SCTstatic void MPU_Config( void ){
        MPU_Region_InitTypeDef MPU_InitStruct;
        /* 禁止 MPU */
        HAL_MPU_Disable();
    /* 配置DTCM 的MPU属性 */
        MPU_InitStruct.Enable           = MPU_REGION_ENABLE;
        MPU_InitStruct.BaseAddress      = 0x20000000;
        MPU_InitStruct.Size             = MPU_REGION_SIZE_128KB;
        MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
        MPU_InitStruct.IsBufferable     = MPU_ACCESS_BUFFERABLE;
        MPU_InitStruct.IsCacheable      = MPU_ACCESS_CACHEABLE;
        MPU_InitStruct.IsShareable      = MPU_ACCESS_NOT_SHAREABLE;
        MPU_InitStruct.Number           = MPU_REGION_NUMBER0;
        MPU_InitStruct.TypeExtField     = MPU_TEX_LEVEL0;
        MPU_InitStruct.SubRegionDisable = 0x00;
        MPU_InitStruct.DisableExec      = MPU_INSTRUCTION_ACCESS_ENABLE;
        HAL_MPU_ConfigRegion(&MPU_InitStruct);
        /* 配置AXI SRAM的MPU属性为Write back, No write allocate */
        MPU_InitStruct.BaseAddress      = 0x24000000;
        MPU_InitStruct.Size             = MPU_REGION_SIZE_512KB;
        MPU_InitStruct.IsBufferable     = MPU_ACCESS_NOT_BUFFERABLE;
        MPU_InitStruct.IsCacheable      = MPU_ACCESS_NOT_CACHEABLE;
        MPU_InitStruct.Number           = MPU_REGION_NUMBER1;
    /* 配置SRAM1~SRAM2的MPU属性为Write back, No write allocate */
        MPU_InitStruct.BaseAddress      = 0x30000000;
        MPU_InitStruct.Size             = ARM_MPU_REGION_SIZE_256KB;
        MPU_InitStruct.Number           = MPU_REGION_NUMBER2;
    /* 配置SRAM4的MPU属性为Write back, No write allocate */
        MPU_InitStruct.BaseAddress      = 0x38000000;
        MPU_InitStruct.Size             = MPU_REGION_SIZE_64KB;
        MPU_InitStruct.Number           = MPU_REGION_NUMBER3;
        /* 配置FMC的MPU属性 */
        MPU_InitStruct.BaseAddress      = 0x68000000;
        MPU_InitStruct.Size             = ARM_MPU_REGION_SIZE_1MB;
        MPU_InitStruct.Number           = MPU_REGION_NUMBER4;
    /* 配置NAND FLASH区域 */
        MPU_InitStruct.BaseAddress      = 0x80000000;
        MPU_InitStruct.Size             = MPU_REGION_SIZE_256MB;
        MPU_InitStruct.Number           = MPU_REGION_NUMBER5;
        MPU_InitStruct.DisableExec      = 1;
        /*使能 MPU */
        HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
2019-9-24
 楼主| 发表于 2025-9-29 10:58:06 | 显示全部楼层
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x08000000 0x00200000  {    ; load region size_region
  ER_IROM1 0x08000000 0x00200000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_IRAM1 0x20000000 0x00020000  {  ; RW data - 128KB DTCM
   .ANY (+RW +ZI)
  RW_IRAM2 0x24000000 0x00080000  {  ; RW data - 512KB AXI SRAM
   *(.RAM_AXI)
  RW_IRAM3 0x30000000 0x00040000  {  ; RW data - 128KB SRAM1(0x30000000) + 128KB SRAM2(0x3002 0000)
   *(.RAM_D12)
  RW_IRAM4 0x38000000 0x00010000  {  ; RW data - 64KB SRAM4(0x38000000)
   *(.RAM_D4)
2019-9-24
 楼主| 发表于 2025-9-29 11:00:04 | 显示全部楼层
__attribute__((section(".RAM_AXI"))) int test1[10];
__attribute__((section(".RAM_D12"))) int test2[10];
__attribute__((section(".RAM_D4"))) int test3[10];   这个是我的变量。
GMT+8, 2026-10-31 00:15
