查看: 2223|回复: 1
stm32u5 usbx独立模式运行,模拟u盘无法格式化
2020-12-23
发表于 2025-11-28 10:43:38 | 显示全部楼层 |阅读模式
/* USER CODE BEGIN Header */
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "app_usbx_device.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN UX_Device_Memory_Buffer */
/* USER CODE END UX_Device_Memory_Buffer */
#if defined ( __ICCARM__ )
#pragma data_alignment=4
#endif
__ALIGN_BEGIN static UCHAR ux_device_byte_pool_buffer[UX_DEVICE_APP_MEM_POOL_SIZE] __ALIGN_END;
static ULONG storage_interface_number;
static ULONG storage_configuration_number;
static UX_SLAVE_CLASS_STORAGE_PARAMETER storage_parameter;
/* USER CODE BEGIN PV */
extern PCD_HandleTypeDef            hpcd_USB_OTG_FS;
__ALIGN_BEGIN USB_MODE_STATE        USB_Device_State_Msg   __ALIGN_END;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
static UINT USBD_ChangeFunction(ULONG Device_State);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
  * @brief  Application USBX Device Initialization.
  * @param  none
  * @retval status
UINT MX_USBX_Device_Init(VOID)
   UINT ret = UX_SUCCESS;
  UCHAR *device_framework_high_speed;
  UCHAR *device_framework_full_speed;
  ULONG device_framework_hs_length;
  ULONG device_framework_fs_length;
  ULONG string_framework_length;
  ULONG language_id_framework_length;
  UCHAR *string_framework;
  UCHAR *language_id_framework;
  UCHAR *pointer;
  /* USER CODE BEGIN MX_USBX_Device_Init0 */
  /* USER CODE END MX_USBX_Device_Init0 */
  pointer = ux_device_byte_pool_buffer;
  /* Initialize USBX Memory */
  if (ux_system_initialize(pointer, USBX_DEVICE_MEMORY_STACK_SIZE, UX_NULL, 0) != UX_SUCCESS)
    /* USER CODE BEGIN USBX_SYSTEM_INITIALIZE_ERROR */
    return UX_ERROR;
    /* USER CODE END USBX_SYSTEM_INITIALIZE_ERROR */
  /* Get Device Framework High Speed and get the length */
  device_framework_high_speed = USBD_Get_Device_Framework_Speed(USBD_HIGH_SPEED,
        &device_framework_hs_length);
  /* Get Device Framework Full Speed and get the length */
  device_framework_full_speed = USBD_Get_Device_Framework_Speed(USBD_FULL_SPEED,
        &device_framework_fs_length);
  /* Get String Framework and get the length */
  string_framework = USBD_Get_String_Framework(&string_framework_length);
  /* Get Language Id Framework and get the length */
  language_id_framework = USBD_Get_Language_Id_Framework(&language_id_framework_length);
  /* Install the device portion of USBX */
  if (ux_device_stack_initialize(device_framework_high_speed,
                                 device_framework_hs_length,
                                 device_framework_full_speed,
                                 device_framework_fs_length,
                                 string_framework,
                                 string_framework_length,
                                 language_id_framework,
                                 language_id_framework_length,
                                 USBD_ChangeFunction) != UX_SUCCESS)
    /* USER CODE BEGIN USBX_DEVICE_INITIALIZE_ERROR */
    return UX_ERROR;
    /* USER CODE END USBX_DEVICE_INITIALIZE_ERROR */
  /* Initialize the storage class parameters for the device */
  storage_parameter.ux_slave_class_storage_instance_activate   = USBD_STORAGE_Activate;
  storage_parameter.ux_slave_class_storage_instance_deactivate = USBD_STORAGE_Deactivate;
  /* Store the number of LUN in this device storage instance */
  storage_parameter.ux_slave_class_storage_parameter_number_lun = STORAGE_NUMBER_LUN;
  /* Initialize the storage class parameters for reading/writing to the Flash Disk */
  storage_parameter.ux_slave_class_storage_parameter_lun[0].
    ux_slave_class_storage_media_last_lba = USBD_STORAGE_GetMediaLastLba();
    ux_slave_class_storage_media_block_length = USBD_STORAGE_GetMediaBlocklength();
    ux_slave_class_storage_media_type = UX_SLAVE_CLASS_STORAGE_MEDIA_FAT_DISK;
    ux_slave_class_storage_media_removable_flag = STORAGE_REMOVABLE_FLAG;
    ux_slave_class_storage_media_read_only_flag = STORAGE_READ_ONLY;
    ux_slave_class_storage_media_read = USBD_STORAGE_Read;
    ux_slave_class_storage_media_write = USBD_STORAGE_Write;
    ux_slave_class_storage_media_flush = USBD_STORAGE_Flush;
    ux_slave_class_storage_media_status = USBD_STORAGE_Status;
    ux_slave_class_storage_media_notification = USBD_STORAGE_Notification;
  /* USER CODE BEGIN STORAGE_PARAMETER */
  /* USER CODE END STORAGE_PARAMETER */
  /* Get storage configuration number */
  storage_configuration_number = USBD_Get_Configuration_Number(CLASS_TYPE_MSC, 0);
  /* Find storage interface number */
  storage_interface_number = USBD_Get_Interface_Number(CLASS_TYPE_MSC, 0);
  /* Initialize the device storage class */
  if (ux_device_stack_class_register(_ux_system_slave_class_storage_name,
                                     ux_device_class_storage_entry,
                                     storage_configuration_number,
                                     storage_interface_number,
                                     &storage_parameter) != UX_SUCCESS)
    /* USER CODE BEGIN USBX_DEVICE_STORAGE_REGISTER_ERROR */
    return UX_ERROR;
    /* USER CODE END USBX_DEVICE_STORAGE_REGISTER_ERROR */
  /* USER CODE BEGIN MX_USBX_Device_Init1 */
  USBX_APP_Device_Init();
  /* USER CODE END MX_USBX_Device_Init1 */
  return ret;
  * @brief  _ux_utility_interrupt_disable
  *         USB utility interrupt disable.
  * @param  none
  * @retval none
ALIGN_TYPE _ux_utility_interrupt_disable(VOID)
  UINT interrupt_save;
  /* USER CODE BEGIN _ux_utility_interrupt_disable */
  interrupt_save = __get_PRIMASK();
  __disable_irq();
  /* USER CODE END _ux_utility_interrupt_disable */
  return interrupt_save;
  * @brief  _ux_utility_interrupt_restore
  *         USB utility interrupt restore.
  * @param  flags
  * @retval none
VOID _ux_utility_interrupt_restore(ALIGN_TYPE flags)
  /* USER CODE BEGIN _ux_utility_interrupt_restore */
  __set_PRIMASK(flags);
  /* USER CODE END _ux_utility_interrupt_restore */
  * @brief  _ux_utility_time_get
  *         Get Time Tick for host timing.
  * @param  none
  * @retval time tick
ULONG _ux_utility_time_get(VOID)
  ULONG time_tick = 0U;
  /* USER CODE BEGIN _ux_utility_time_get */
        return HAL_GetTick();
  /* USER CODE END _ux_utility_time_get */
  return time_tick;
  * @brief  USBD_ChangeFunction
  *         This function is called when the device state changes.
  * @param  Device_State: USB Device State
  * @retval status
   UINT status = UX_SUCCESS;
  /* USER CODE BEGIN USBD_ChangeFunction0 */
  /* USER CODE END USBD_ChangeFunction0 */
  switch (Device_State)
    case UX_DEVICE_ATTACHED:
      /* USER CODE BEGIN UX_DEVICE_ATTACHED */
                        printf("device_attached\r\n");
      /* USER CODE END UX_DEVICE_ATTACHED */
      break;
    case UX_DEVICE_REMOVED:
      /* USER CODE BEGIN UX_DEVICE_REMOVED */
                        printf("device_removed\r\n");
      /* USER CODE END UX_DEVICE_REMOVED */
      break;
    case UX_DCD_STM32_DEVICE_CONNECTED:
      /* USER CODE BEGIN UX_DCD_STM32_DEVICE_CONNECTED */
                        printf("device_connected\r\n");
      /* USER CODE END UX_DCD_STM32_DEVICE_CONNECTED */
      break;
    case UX_DCD_STM32_DEVICE_DISCONNECTED:
      /* USER CODE BEGIN UX_DCD_STM32_DEVICE_DISCONNECTED */
                        printf("device_disconnected\r\n");
      /* USER CODE END UX_DCD_STM32_DEVICE_DISCONNECTED */
      break;
    case UX_DCD_STM32_DEVICE_SUSPENDED:
      /* USER CODE BEGIN UX_DCD_STM32_DEVICE_SUSPENDED */
                        printf("device_suspended\r\n");
      /* USER CODE END UX_DCD_STM32_DEVICE_SUSPENDED */
      break;
    case UX_DCD_STM32_DEVICE_RESUMED:
      /* USER CODE BEGIN UX_DCD_STM32_DEVICE_RESUMED */
                        printf("device_resumed\r\n");
      /* USER CODE END UX_DCD_STM32_DEVICE_RESUMED */
      break;
    case UX_DCD_STM32_SOF_RECEIVED:
      /* USER CODE BEGIN UX_DCD_STM32_SOF_RECEIVED */
                        printf("device_received\r\n");
      /* USER CODE END UX_DCD_STM32_SOF_RECEIVED */
      break;
    default:
      /* USER CODE BEGIN DEFAULT */
      /* USER CODE END DEFAULT */
      break;
  /* USER CODE BEGIN USBD_ChangeFunction1 */
  /* USER CODE END USBD_ChangeFunction1 */
  return status;
/* USER CODE BEGIN 1 */
VOID USBX_APP_Device_Init(VOID)
  /* USER CODE BEGIN USB_Device_Init_PreTreatment_0 */
  /* USER CODE END USB_Device_Init_PreTreatment_0 */
  MX_USB_OTG_FS_PCD_Init();
  /* USER CODE BEGIN USB_Device_Init_PreTreatment_1 */
        HAL_PCDEx_SetRxFiFo(&hpcd_USB_OTG_FS, 0x80);
  HAL_PCDEx_SetTxFiFo(&hpcd_USB_OTG_FS, 0, USBD_MAX_EP0_SIZE / 4);
HAL_PCDEx_SetTxFiFo(&hpcd_USB_OTG_FS, 1, USBD_MSC_EPIN_FS_MPS / 2);
        HAL_PCDEx_SetRxFiFo(&hpcd_USB_OTG_FS, 0x80);  // 128字节RX FIFO
  HAL_PCD_Start(&hpcd_USB_OTG_FS);
  /* USER CODE BEGIN USB_Device_Init_PostTreatment */
  /* USER CODE END USB_Device_Init_PostTreatment */
/* USER CODE END 1 */
#include "ux_device_msc.h"
#include "stdio.h"
extern HAL_SD_CardInfoTypeDef card_info;
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
//static UINT handle_scsi_commands(UCHAR *data_pointer, ULONG lba, ULONG number_blocks, ULONG lun);
/* USER CODE END 0 */
  * @brief  USBD_STORAGE_Activate
  *         This function is called when insertion of a storage device.
  * @param  storage_instance: Pointer to the storage class instance.
  * @retval none
VOID USBD_STORAGE_Activate(VOID *storage_instance)
  /* USER CODE BEGIN USBD_STORAGE_Activate */
  UX_PARAMETER_NOT_USED(storage_instance);
  /* USER CODE END USBD_STORAGE_Activate */
  return;
  * @brief  USBD_STORAGE_Deactivate
  *         This function is called when extraction of a storage device.
  * @retval none
VOID USBD_STORAGE_Deactivate(VOID *storage_instance)
  /* USER CODE BEGIN USBD_STORAGE_Deactivate  */
  /* USER CODE END USBD_STORAGE_Deactivate */
  return;
  * @brief  USBD_STORAGE_Read
  *         This function is invoked to read from media.
  * @param  storage_instance : Pointer to the storage class instance.
  * @param  lun: Logical unit number is the command is directed to.
  * @param  data_pointer: Address of the buffer to be used for reading or writing.
  * @param  number_blocks: number of sectors to read/write.
  * @param  lba: Logical block address is the sector address to read.
  * @param  media_status: should be filled out exactly like the media status
  *                       callback return value.
  * @retval status
UINT USBD_STORAGE_Read(VOID *storage_instance, ULONG lun, UCHAR *data_pointer,
                       ULONG number_blocks, ULONG lba, ULONG *media_status)
  /* USER CODE BEGIN USBD_STORAGE_Read */
                int8_t ret;
                UX_PARAMETER_NOT_USED(media_status);
                if (sd_read_disk(data_pointer, lba, number_blocks) != HAL_OK) {
      printf("[USB MSC READ] ERROR at LBA: %lu, Blocks: %lu\r\n", lba, number_blocks);
      *media_status = 1;
      return UX_ERROR;
                *media_status = 0;
                printf("[USB MSC READ] SUCCESS - LBA: %lu, Blocks: %lu\r\n", lba, number_blocks);
  /* USER CODE END USBD_STORAGE_Read */
  return status;
  * @brief  USBD_STORAGE_Write
  *         This function is invoked to write in media.
  * @retval status
UINT USBD_STORAGE_Write(VOID *storage_instance, ULONG lun, UCHAR *data_pointer,
  /* USER CODE BEGIN USBD_STORAGE_Write */
                uint8_t ret;
                 if (sd_write_disk(data_pointer, lba, number_blocks) != HAL_OK) {
        printf("[USB MSC WRITE] ERROR!\n");
                                *media_status = 1;  // 错误状态
        return UX_ERROR;
         *media_status = 0;  // 成功状态
         printf("[USB MSC WRITE] SUCCESS - LBA: %lu, Blocks: %lu\r\n", lba, number_blocks);
  /* USER CODE END USBD_STORAGE_Write */
  return status;
  * @brief  USBD_STORAGE_Flush
  *         This function is invoked to flush media.
  * @retval status
UINT USBD_STORAGE_Flush(VOID *storage_instance, ULONG lun, ULONG number_blocks,
  /* USER CODE BEGIN USBD_STORAGE_Flush */
  UX_PARAMETER_NOT_USED(lun);
  UX_PARAMETER_NOT_USED(lba);
  /* USER CODE END USBD_STORAGE_Flush */
  return status;
  * @brief  USBD_STORAGE_Status
  *         This function is invoked to obtain the status of the device.
  * @param  media_id: is not currently used.
  * @retval status
UINT USBD_STORAGE_Status(VOID *storage_instance, ULONG lun, ULONG media_id,
  /* USER CODE BEGIN USBD_STORAGE_Status */
  UX_PARAMETER_NOT_USED(media_id);
        // 返回设备就绪状态
  *media_status = 0;
  /* USER CODE END USBD_STORAGE_Status */
  return status;
  * @brief  USBD_STORAGE_Notification
  *         This function is invoked to obtain the notification of the device.
  * @param  notification_class: specifies the class of notification.
  * @param  media_notification: response for the notification.
  * @param  media_notification_length: length of the response buffer.
  * @retval status
UINT USBD_STORAGE_Notification(VOID *storage_instance, ULONG lun, ULONG media_id,
                               ULONG notification_class, UCHAR **media_notification,
                               ULONG *media_notification_length)
  /* USER CODE BEGIN USBD_STORAGE_Notification */
  UX_PARAMETER_NOT_USED(notification_class);
  UX_PARAMETER_NOT_USED(media_notification);
  UX_PARAMETER_NOT_USED(media_notification_length);
  /* USER CODE END USBD_STORAGE_Notification */
  return status;
  * @brief  USBD_STORAGE_GetMediaLastLba
  *         Get Media last LBA.
  * @param  none
  * @retval last lba
ULONG USBD_STORAGE_GetMediaLastLba(VOID)
  ULONG LastLba = 0U;
  /* USER CODE BEGIN USBD_STORAGE_GetMediaLastLba */
        LastLba = (ULONG)(card_info.BlockNbr - 1);
  /* USER CODE END USBD_STORAGE_GetMediaLastLba */
  return LastLba;
  * @brief  USBD_STORAGE_GetMediaBlocklength
  *         Get Media block length.
  * @param  none.
  * @retval block length.
ULONG USBD_STORAGE_GetMediaBlocklength(VOID)
  ULONG MediaBlockLen = 0U;
  /* USER CODE BEGIN USBD_STORAGE_GetMediaBlocklength */
        MediaBlockLen = (ULONG)card_info.BlockSize;
  /* USER CODE END USBD_STORAGE_GetMediaBlocklength */
  return MediaBlockLen;
#include "main.h"
#define SD_TIMEOUT          ((uint32_t)100000000)       /* 超时时间 */
#define SD_TRANSFER_OK      ((uint8_t)0x00)             /* 传输完成 */
#define SD_TRANSFER_BUSY    ((uint8_t)0x01)             /* 卡正忙 */
extern SD_HandleTypeDef hsd1;
void sys_intx_enable(void)
    __ASM volatile("cpsie i");
void sys_intx_disable(void)
    __ASM volatile("cpsid i");
*    函 数 名: sd_init
*    功能说明: sd卡检测管脚初始化
*    形    参: 无
*    返 回 值: 无
uint8_t sd_init(void)
    uint8_t SD_Error;
    hsd1.Instance = SDMMC1;
    hsd1.Init.ClockEdge = SDMMC_CLOCK_EDGE_RISING;                       /* 上升沿 */
    hsd1.Init.ClockPowerSave = SDMMC_CLOCK_POWER_SAVE_DISABLE;           /* 空闲时不关闭时钟电源 */
    hsd1.Init.BusWide = SDMMC_BUS_WIDE_1B;                               /* 4位数据线 */
    hsd1.Init.HardwareFlowControl = SDMMC_HARDWARE_FLOW_CONTROL_ENABLE;  /* 开启硬件流控 */
    hsd1.Init.ClockDiv = SDMMC_NSPEED_CLK_DIV;                           /* SDMMC时钟分频系数 */
                SD_Error = HAL_SD_Init(&hsd1);
    if (SD_Error != HAL_OK){
                                return 1;
                HAL_SD_GetCardInfo(&hsd1, &card_info);
    return 0;
*    函 数 名: sd_detect_Init
*    功能说明: sd卡检测管脚初始化
*    形    参: 无
*    返 回 值: 无
void sd_detect_init(void)
                GPIO_InitTypeDef sd_detect;
                __HAL_RCC_GPIOA_CLK_ENABLE();        /* 使能GPIOA时钟 */
                sd_detect.Mode = GPIO_MODE_INPUT;                                                        /* 输入模式 */
    sd_detect.Pull = GPIO_NOPULL;        /* 上下拉电阻不使能 */
    sd_detect.Speed = GPIO_SPEED_FREQ_VERY_HIGH;        /* GPIO速度等级 */
    sd_detect.Pin = GPIO_PIN_8;        /* 设置芯片管脚 */
    HAL_GPIO_Init(GPIOA, &sd_detect);                                                 /* 初始化对应的GPIO */
*    函 数 名: sd_check
*    功能说明: 检查sd卡是否插入
*    形    参: 无
*    返 回 值: 0表示sd卡正确插入,1表示未正确插入
uint8_t sd_check(void)
                uint8_t ret;
                sd_detect_init();
                ret = HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_8);
                return ret;
uint8_t get_sd_card_state(void)
                return ((HAL_SD_GetCardState(&hsd1) == HAL_SD_CARD_TRANSFER ) ? SD_TRANSFER_OK : SD_TRANSFER_BUSY);
uint8_t sd_read_disk(uint8_t* buf, uint32_t sector, uint32_t cnt)
    uint8_t sta = HAL_OK;
    uint32_t timeout = SD_TIMEOUT;
    long long lsector = sector;
    sys_intx_disable();
    sta = HAL_SD_ReadBlocks(&hsd1, (uint8_t*)buf,lsector, cnt, SD_TIMEOUT);
    while (get_sd_card_state() != SD_TRANSFER_OK){
        if (timeout-- == 0){
            sta = SD_TRANSFER_BUSY;
            break;
    sys_intx_enable();
    return sta;
uint8_t sd_write_disk(uint8_t *buf, uint32_t sector, uint32_t cnt)
    sys_intx_disable();
    sta = HAL_SD_WriteBlocks(&hsd1, (uint8_t*)buf, lsector, cnt, SD_TIMEOUT);
            break;
    sys_intx_enable();
    return sta;
165779
165779
发表于 2025-12-2 21:22:37 | 显示全部楼层
GMT+8, 2026-10-23 15:03
