查看: 17616|回复: 3
[XILINX] 领航者Zynq7020的PL端网口配置不出来
2025-8-22
发表于 2025-12-4 17:37:47 | 显示全部楼层 |阅读模式
我打算配置PL端网口,但是不知道哪里设置的不对:
这是BD框图,MIO配置和约束文件:
这是设备树system-user.dtsi的内容:
/include/ "system-conf.dtsi"
    /* 1. 基础信息 */
    model = "Alientek Navigator Zynq Development Board";
    compatible = "xlnx,zynq-zc702", "xlnx,zynq-7000";
    aliases {
        ethernet0 = &gem0;
        ethernet1 = &gem1;
        serial0 = &uart1;
    chosen {
        bootargs = "console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait uio_pdrv_genirq.of_id=generic-uio";
    usb_phy0: phy0@e0002000 {
        compatible = "ulpi-phy";
        #phy-cells = <0>;
        reg = <0xe0002000 0x1000>;
        view-port = <0x0170>;
        drv-vbus;
   GRU 加速器
&gru_accel_0 {
    compatible = "generic-uio";
    interrupt-parent = <&intc>;
    interrupts = <0 29 4>;
   PS 网口 (eth0)
&gem0 {
    status = "okay";
    local-mac-address = [00 0a 35 00 00 01];
    phy-mode = "rgmii-id";
    phy-handle = <&ethernet_phy0>;
    mdio {
        #address-cells = <1>;
        #size-cells = <0>;
        ethernet_phy0: ethernet-phy@0 {
            reg = <0>;
            device_type = "ethernet-phy";
   PL 网口 (eth1)
&gem1 {
    status = "okay";
    local-mac-address = [00 0a 35 00 00 02];
    phy-handle = <&phy1>;
    // clocks = <&clkc 31>, <&clkc 31>, <&clkc 14>;
    // clock-names = "pclk", "hclk", "tx_clk", "rx_clk";
    /* 引用自动生成的标签 */
    gmii2rgmii-phy-handle = <&gmii_to_rgmii_0>;
    mdio {
        #size-cells = <0>;
        /* 1. 修正 PHY 节点 */
        phy1: ethernet-phy@4 {
            reg = <4>;  /* 地址为 4 */
            reset-gpios = <&gpio0 54 1>;
            reset-delay-us = <10000>;
            reset-deassert-us = <20000>;
   2. 单独修正 gmii_to_rgmii_0 节点
   这里直接引用标签 &gmii_to_rgmii_0,而不是在 mdio 里面重新定义。
   这样是在原节点基础上进行“打补丁”,而不是新建冲突节点。
&gmii_to_rgmii_0 {
    reg = <8>;          /* 修正地址为 8 */
    phy-handle = <&phy1>; /* 确保指向正确的 PHY */
   其他外设
&uart1 { u-boot,dm-pre-reloc; status = "okay"; };
&sdhci0 { u-boot,dm-pre-reloc; status = "okay"; };
&usb0 {
    dr_mode = "host";
    usb-phy = <&usb_phy0>;
    status = "okay";
现象是开发板sd卡启动后,PL端网口不亮,并且:
root@ZYNQ-7020:~# ls /proc/device-tree/amba/ethernet@e000c000/mdio/#address-cells     ethernet-phy@4     name#size-cells        gmii_to_rgmii_0@8  phandleroot@ZYNQ-7020:~# dmesg | grep e000c000xgmiitorgmii e000c000.ethernet-ffffffff:04: Couldn't find phydevmdio_bus e000c000.ethernet-ffffffff: MDIO device at address 4 is missing.root@ZYNQ-7020:~#
2025-8-22
 楼主| 发表于 2025-12-5 10:06:43 | 显示全部楼层
[img]D:\Backup\桌面\BD.pngD:\Backup\桌面\xdc.png[/img]
113
725
725
2021-8-3
167 小时
发表于 2025-12-5 11:34:42 | 显示全部楼层
可以和资料盘出厂程序的内核源码里的pl网口设备树对比一下,看哪里不一样,还有vivado工程也对比一下
113
725
725
2021-8-3
167 小时
发表于 2025-12-5 11:35:04 | 显示全部楼层
GMT+8, 2026-10-25 03:22
