查看: 6931|回复: 1
新手寻求帮助IMX6阿尔法linux,正点的核心板,用自己做的底板,运行灯正常,系统卡在进度条位置。插到正点底板上,功能都正常。
37
37
2019-9-9
14 小时
发表于 2026-1-3 18:01:31 | 显示全部楼层 |阅读模式
37
37
2019-9-9
14 小时
 楼主| 发表于 2026-1-8 08:05:39 | 显示全部楼层
I.MX6UL无法进入主界面,日志如下,
硬件问题会不会影响启动???=~=~=~=~=~=~=~=~=~=~=~= MobaXterm log 2026.05.05 08:42:39 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot 2016.03-g0ae7e33 (Aug 14 2022 - 19:42:45 +0800)
CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 37C
Reset cause: POR
Board: I.MX6U ALPHA|MINI
I2C:   ready
DRAM:  512 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc1(part 0) is current device
Net:   FEC1
Error: FEC1 address not set.
Normal Boot
Hit any key to stop autoboot:  1  0
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6781264 bytes read in 221 ms (29.3 MiB/s)
Booting from mmc ...
reading imx6ull-14x14-emmc-7-1024x600-c.dtb
39459 bytes read in 23 ms (1.6 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0x677950 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Using Device Tree in place at 83000000, end 8300ca22
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.1.15 (alientek@ubuntu16) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Sun Oct 13 17:34:28 CST 2024
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Freescale i.MX6 ULL 14x14 EVK Board
[    0.000000] Reserved memory: created CMA memory pool at 0x98000000, size 128 MiB
[    0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 12 pages/cpu @97b8f000 s16780 r8192 d24180 u49152
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 375264K/524288K available (8552K kernel code, 449K rwdata, 2964K rodata, 528K init, 452K bss, 17952K reserved, 131072K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xa0800000 - 0xff000000   (1512 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xa0000000   ( 512 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x80b47284   (11517 kB)
[    0.000000]       .init : 0x80b48000 - 0x80bcc000   ( 528 kB)
[    0.000000]       .data : 0x80bcc000 - 0x80c3c7e0   ( 450 kB)
[    0.000000]        .bss : 0x80c3f000 - 0x80cb00c4   ( 453 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] Additional per-CPU info printed with stalls.
[    0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] mxc_clocksource_init 3000000
[    0.000000] Switching to timer-based delay loop, resolution 333ns
[    0.000015] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[    0.000056] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[    0.002925] Console: colour dummy device 80x30
[    0.002964] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.003000] pid_max: default: 32768 minimum: 301
[    0.003227] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.003258] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.004640] CPU: Testing write buffer coherency: ok
[    0.005136] /cpus/cpu@0 missing clock-frequency property
[    0.005177] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005289] Setting up static identity map for 0x80008280 - 0x800082d8
[    0.041185] Brought up 1 CPUs
[    0.041223] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.041244] CPU: All CPU(s) started in SVC mode.
[    0.042340] devtmpfs: initialized
[    0.059594] device-tree: Duplicate name in lcdif@021c8000, renamed to "display#1"
[    0.066229] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.067136] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.077236] pinctrl core: initialized pinctrl subsystem
[    0.079987] NET: Registered protocol family 16
[    0.097802] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.121745] cpuidle: using governor ladder
[    0.151810] cpuidle: using governor menu
[    0.202496] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.202532] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.207035] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.207849] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[    0.279719] mxs-dma 1804000.dma-apbh: initialized
[    0.286876] SCSI subsystem initialized
[    0.288248] usbcore: registered new interface driver usbfs
[    0.288435] usbcore: registered new interface driver hub
[    0.288661] usbcore: registered new device driver usb
[    0.291653] i2c i2c-0: IMX I2C adapter registered
[    0.291700] i2c i2c-0: can't use DMA
[    0.294049] i2c i2c-1: IMX I2C adapter registered
[    0.294095] i2c i2c-1: can't use DMA
[    0.294434] Linux video capture interface: v2.00
[    0.294644] pps_core: LinuxPPS API ver. 1 registered
[    0.294670] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.294749] PTP clock support registered
[    0.297799] MIPI CSI2 driver module loaded
[    0.298492] Advanced Linux Sound Architecture Driver Initialized.
[    0.300784] Bluetooth: Core ver 2.20
[    0.300916] NET: Registered protocol family 31
[    0.300939] Bluetooth: HCI device and connection manager initialized
[    0.300981] Bluetooth: HCI socket layer initialized
[    0.301014] Bluetooth: L2CAP socket layer initialized
[    0.301099] Bluetooth: SCO socket layer initialized
[    0.303731] Switched to clocksource mxc_timer1
[    0.330771] NET: Registered protocol family 2
[    0.332378] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.332512] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.332668] TCP: Hash tables configured (established 4096 bind 4096)
[    0.332802] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.332865] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.333281] NET: Registered protocol family 1
[    0.334144] RPC: Registered named UNIX socket transport module.
[    0.334179] RPC: Registered udp transport module.
[    0.334198] RPC: Registered tcp transport module.
[    0.334219] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.337721] imx rpmsg driver is registered.
[    0.340532] Bus freq driver module loaded
[    0.342771] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.359962] VFS: Disk quotas dquot_6.6.0
[    0.360475] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.366259] NFS: Registering the id_resolver key type
[    0.366361] Key type id_resolver registered
[    0.366384] Key type id_legacy registered
[    0.366601] jffs2: version 2.2. (NAND) ?2001-2006 Red Hat, Inc.
[    0.368527] fuse init (API version 7.23)
[    0.379684] io scheduler noop registered
[    0.379736] io scheduler deadline registered
[    0.380198] io scheduler cfq registered (default)
[    0.381380] imx-weim 21b8000.weim: Driver registered.
[    0.388230] backlight supply power not found, using dummy regulator
[    0.389577] MIPI DSI driver module loaded
[    0.390084] MIPI DSI driver module loaded
[    0.396270] 21c8000.lcdif supply lcd not found, using dummy regulator
[    0.504107] mxsfb 21c8000.lcdif: failed to find mxc display driver
[    0.518467] Console: switching to colour frame buffer device 128x37
[    0.555007] mxsfb 21c8000.lcdif: initialized
[    0.557125] imx-sdma 20ec000.sdma: no event needs to be remapped
[    0.557341] imx-sdma 20ec000.sdma: loaded firmware 3.3
[    0.564785] imx-sdma 20ec000.sdma: initialized
[    0.567102] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 19, base_baud = 5000000) is a IMX
[    1.254705] console [ttymxc0] enabled
[    1.260313] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 233, base_baud = 5000000) is a IMX
[    1.273483] ap3216c 0-001e: ap3216c init failed
[    1.278184] ap3216c: probe of 0-001e failed with error -1
[    1.317964] imx-rng 2284000.rngb: iMX RNG Registered.
[    1.323893] imx sema4 driver is registered.
[    1.328277] [drm] Initialized drm 1.1.0 20060810
[    1.334391] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    1.366204] brd: module loaded
[    1.382247] loop: module loaded
[    1.391052] fsl-quadspi 21e0000.qspi: unrecognized JEDEC id bytes: ff, ff, ff
[    1.398428] fsl-quadspi 21e0000.qspi: Freescale QuadSPI probe failed
[    1.411045] spi_imx 2010000.ecspi: probed
[    1.418082] CAN device driver interface
[    1.425157] flexcan 2090000.can: device registered (reg_base=a0a08000, irq=26)
[    1.434834] 20b4000.ethernet supply phy not found, using dummy regulator
[    1.804913] pps pps0: new PPS source ptp0
[    1.810561] fec 20b4000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[    1.820696] fec 20b4000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 8a:f8:ef:63:dc:8f
[    1.832033] libphy: fec_enet_mii_bus: probed
[    1.838320] fec 20b4000.ethernet eth0: registered PHC device 0
[    1.845975] 2188000.ethernet supply phy not found, using dummy regulator
[    2.214796] pps pps1: new PPS source ptp1
[    2.220348] fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[    2.230475] fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: d2:20:cc:6d:96:04
[    2.243051] fec 2188000.ethernet eth1: registered PHC device 1
[    2.250801] PPP generic driver version 2.4.2
[    2.255811] PPP BSD Compression module registered
[    2.260571] PPP Deflate Compression module registered
[    2.265778] PPP MPPE Compression module registered
[    2.270626] NET: Registered protocol family 24
[    2.275430] usbcore: registered new interface driver asix
[    2.281030] usbcore: registered new interface driver ax88179_178a
[    2.287377] usbcore: registered new interface driver cdc_ether
[    2.293373] usbcore: registered new interface driver net1080
[    2.299265] usbcore: registered new interface driver cdc_subset
[    2.305402] usbcore: registered new interface driver zaurus
[    2.311270] usbcore: registered new interface driver cdc_ncm
[    2.317039] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.323608] ehci-mxc: Freescale On-Chip EHCI Host driver
[    2.329487] usbcore: registered new interface driver usb-storage
[    2.335865] usbcore: registered new interface driver usb_ehset_test
[    2.345056] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    2.354397] 2184000.usb supply vbus not found, using dummy regulator
[    2.366525] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    2.371489] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    2.393870] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    2.401492] hub 1-0:1.0: USB hub found
[    2.405554] hub 1-0:1.0: 1 port detected
[    2.411400] 2184200.usb supply vbus not found, using dummy regulator
[    2.421834] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.426989] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[    2.453871] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    2.461514] hub 2-0:1.0: USB hub found
[    2.465571] hub 2-0:1.0: 1 port detected
[    2.472226] mousedev: PS/2 mouse device common for all mice
[    2.479981] input: 20cc000.snvs:snvs-powerkey as /devices/platform/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
[    2.824061] edt_ft5x06 1-0038: touchscreen probe failed
[    2.829410] edt_ft5x06: probe of 1-0038 failed with error -5
[    2.835620] <<-GTP-INFO->> GTP driver installing...
[    2.841209] <<-GTP-INFO->> GTP Driver Version: gt9xx driver Rleased <2021/11/27> Based V2.4
[    2.849751] <<-GTP-INFO->> GTP I2C Address: 0x5d
[    2.854510] <<-GTP-INFO->> Guitar reset
[    2.983792] 1-005d supply vdd_ana not found, using dummy regulator
[    2.990146] 1-005d supply vcc_i2c not found, using dummy regulator
[    2.997993] goodix-ts 1-005d: ID 911, version: 1060
[    3.034136] <<-GTP-INFO->> X_MAX: 1024, Y_MAX: 600, TRIGGER: 0x01
[    3.053783] <<-GTP-INFO->> create proc entry gt9xx_config success
[    3.060533] input: goodix-ts as /devices/virtual/input/input2
[    3.066997] <<-GTP-INFO->> GTP works in interrupt mode.
[    3.076663] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
[    3.085861] i2c /dev entries driver
[    3.092103] IR NEC protocol handler initialized
[    3.096785] IR RC5(x/sz) protocol handler initialized
[    3.101880] IR RC6 protocol handler initialized
[    3.106492] IR JVC protocol handler initialized
[    3.111060] IR Sony protocol handler initialized
[    3.115753] IR SANYO protocol handler initialized
[    3.120757] IR Sharp protocol handler initialized
[    3.125757] IR MCE Keyboard/mouse protocol handler initialized
[    3.131685] IR XMP protocol handler initialized
[    3.141464] pxp-v4l2 pxp_v4l2: initialized
[    3.150833] imx2-wdt 20bc000.wdog: use WDOG_B to reboot.
[    3.157216] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[    3.163901] Bluetooth: HCI UART driver ver 2.3
[    3.168482] Bluetooth: HCI UART protocol H4 registered
[    3.173684] Bluetooth: HCI UART protocol BCSP registered
[    3.179116] Bluetooth: HCI UART protocol ATH3K registered
[    3.184948] usbcore: registered new interface driver bcm203x
[    3.191129] usbcore: registered new interface driver btusb
[    3.197222] usbcore: registered new interface driver ath3k
[    3.204611] sdhci: Secure Digital Host Controller Interface driver
[    3.210831] sdhci: Copyright(c) Pierre Ossman
[    3.215355] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.223557] /soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
[    3.230897] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[    3.238290] sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
[    3.286266] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    3.295660] /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
[    3.303965] sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
[    3.310197] sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
[    3.354881] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[    3.412358] usbcore: registered new interface driver usbhid
[    3.418260] usbhid: USB HID core driver
[    3.431956] wm8960 0-001a: Failed to issue reset
[    3.437075] wm8960: probe of 0-001a failed with error -5
[    3.442525] mmc1: MAN_BKOPS_EN bit is not set
[    3.450601] wm8960 1-001a: Failed to issue reset
[    3.455843] wm8960: probe of 1-001a failed with error -5
[    3.470103] fsl-asrc 2034000.asrc: driver registered
[    3.487142] imx-wm8960 sound: failed to find codec platform device
[    3.493408] imx-wm8960: probe of sound failed with error -22
[    3.500431] mmc1: new DDR MMC card at address 0001
[    3.508875] NET: Registered protocol family 26
[    3.514860] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[    3.519751] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[    3.527514] NET: Registered protocol family 10
[    3.533345] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[    3.541244] sit: IPv6 over IPv4 tunneling driver
[    3.546496] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB
[    3.555024] NET: Registered protocol family 17
[    3.559668] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.572934] can: controller area network core (rev 20120528 abi 9)
[    3.581612] NET: Registered protocol family 29
[    3.581777]  mmcblk1: p1 p2
[    3.589289] can: raw protocol (rev 20120528)
[    3.593610] can: broadcast manager protocol (rev 20120528 t)
[    3.605742] can: netlink gateway (rev 20130117) max_hops=1
[    3.611955] Bluetooth: RFCOMM TTY layer initialized
[    3.617216] Bluetooth: RFCOMM socket layer initialized
[    3.622432] Bluetooth: RFCOMM ver 1.11
[    3.626390] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.631733] Bluetooth: BNEP filters: protocol multicast
[    3.637071] Bluetooth: BNEP socket layer initialized
[    3.642084] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.648092] Bluetooth: HIDP socket layer initialized
[    3.653224] 8021q: 802.1Q VLAN Support v1.8
[    3.657732] Key type dns_resolver registered
[    3.692333] dhd_module_init in
[    3.696929] input: gpio_keys@0 as /devices/platform/gpio_keys@0/input/input3
[    3.704738] snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
[    3.727363] gpio_dvfs: disabling
[    3.730634] VSD_3V3: disabling
[    3.733857] can-3v3: disabling
[    3.737204] ALSA device list:
[    3.740187]   No soundcards found.
[    3.768109] kjournald starting.  Commit interval 5 seconds
[    3.773879] EXT3-fs (mmcblk1p2): using internal journal
[    3.779724] EXT3-fs (mmcblk1p2): recovery complete
[    3.784616] EXT3-fs (mmcblk1p2): mounted filesystem with ordered data mode
[    3.791557] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    3.798698] devtmpfs: mounted
[    3.802370] Freeing unused kernel memory: 528K (80b48000 - 80bcc000)
INIT: version 2.88 booting
Starting udev
[    4.511975] udevd[122]: starting version 3.1.5
[    4.521336] random: udevd urandom read with 22 bits of entropy available
bootlogd: cannot allocate pseudo tty: No such file or directory
[    7.727184] FAT-fs (mmcblk1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[    7.754687] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1735: No soundcards found...
Mon Oct 14 20:25:35 UTC 2024
INIT: Entering runlevel: 5
Configuring network interfaces... SIOCSIFFLAGS: No such device
Starting system message bus: dbus.
Starting Xserver
Starting Connection Manager
Starting Dropbear SSH server: dropbear.
Starting rpcbind daemon...done.
Starting watchdog: [  OK  ]
starting statd: done
Starting advanced power management daemon: apmd.
apmd[560]: apmd 3.2.1 interfacing with apm driver 1.13 and APM BIOS 1.2
Starting atd: OK
exportfs: can't open /etc/exports for reading
NFS daemon support not enabled in kernel
Starting system log daemon...0
Starting kernel log daemon...0
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
[ ok ]
Starting Telephony daemon
Starting Linux NFC daemon
* starting FTP Server: vsftpd... done.
Starting crond: OK
Starting nginx: nginx.
Running local boot scripts (/etc/rc.local)SIOCSIFFLAGS: No such device
error
root@ATK-IMX6U:~# [   81.763768] random: nonblocking pool is initialized
是硬件VM8960原因吗?检查硬件电路,发现VM8960用的I2C1_SDA,I2C1_SCL,这里会影响启动吗?
GMT+8, 2026-10-31 01:44
