查看: 6611|回复: 2
uboot移植,网络ping不通怎么回事啊!!!
2026-1-3
发表于 2026-1-6 12:39:47 | 显示全部楼层 |阅读模式
配置跟着教程来的,试了好几次了,不知道哪里的问题,有没有大佬能给解决一下
U-Boot 2016.03 (Jan 06 2026 - 12:15:51 +0800)
CPU:   Freescale i.MX6ULL rev1.1 69 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 22C
Reset cause: POR
Board: MX6ULL 14x14 EVK
I2C:   ready
DRAM:  512 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
Display: TFT7016 (1024x600)
Video: 1024x600x24
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc0 is current device
Net:   FEC1
Normal Boot
=> ping 192.168.1.25
Using FEC1 device
ARP Retry count exceeded; starting again
ping failed; host 192.168.1.25 is not alive
baudrate=115200
board_name=EVK
board_rev=14X14
boot_fdt=try
bootargs=console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw
bootcmd=mmc dev 1; fatload mmc 1:1 80800000 zImage; fatload mmc 1:1 83000\
000 imx6ull-14x14-emmc-7-1024x600-c.dtb; bootz 80800000 - 83000000;
bootcmd_mfg=run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
bootdelay=3
bootscript=echo Running bootscript from mmc ...; source
console=ttymxc0
ethact=FEC1
ethaddr=b8:ae:1d:01:00:00
ethprime=FEC
fdt_addr=0x83000000
fdt_file=undefined
fdt_high=0xffffffff
fileaddr=80800000
filesize=67a3c8
findfdt=if test $fdt_file = undefined; then if test $board_name = EVK && test $board_rev = 9X9; then setenv fdt_file imx6ull-9x9-evk.dtb; fi; if test $board_name = EVK && test $board_rev = 14X14; then setenv fdt_file imx6ull-14x14-evk.dtb; fi; if test $fdt_file = undefined; then echo WARNING: Could not determine dtb to use; fi; fi;
gatewayip=192.168.1.1
image=zImage
initrd_addr=0x83800000
initrd_high=0xffffffff
ip_dyn=yes
ipaddr=192.168.1.26
loadaddr=0x80800000
loadbootscript=fatload mmc ${mmcdev}{mmcpart} ${loadaddr} ${script};
loadfdt=fatload mmc ${mmcdev}{mmcpart} ${fdt_addr} ${fdt_file}
loadimage=fatload mmc ${mmcdev}{mmcpart} ${loadaddr} ${image}
mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.file=/fat g_mass_storage.ro=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber="" clk_ignore_unused
mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot}
mmcautodetect=yes
mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}{nfsroot},v3,tcp
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
netmask=255.255.255.0
panel=TFT7016
script=boot.scr
serverip=192.168.1.25
262
262
2019-7-20
62 小时
发表于 2026-1-20 15:51:45 | 显示全部楼层
大概率是目标主机防火墙拦截 ICMP 请求,其次是 DHCP 与静态 IP 冲突。
关闭目标主机防火墙,直连网线;
U-Boot 中关闭动态 IP(ip_dyn=no),重新配置并保存静态网络参数;
优先用 TFTP 验证网络(比 ping 更可靠)。
2026-1-3
 楼主| 发表于 2026-1-24 17:02:39 | 显示全部楼层
关闭目标主机防火墙,直连网线;
版本低的还是没弄好,我换了版本高一点的可以了
GMT+8, 2026-10-30 21:52
