查看: 3166|回复: 1
STM32L4R5ZIT6用DMA把存储器里的数据发往串口的·问题
99
224
815
815
2014-10-15
192 小时
发表于 2026-6-10 15:40:10 | 显示全部楼层 |阅读模式
我试图用STM32L4R5ZIT6的DMA功能把存储器里的数据发往串口1
用串口可以发数据:、
比如这句:
  1. HAL_UART_Transmit(&huart1,buffer,1,1000);
用这句就不行:
  1. HAL_UART_Transmit_DMA(&huart1, (uint8_t *)Buffer, 4);
我的DMA配置函数如下:
  1. static void DMA_Config(void)
  2. {
  3.   /*## -1- Enable DMA1 clock #################################################*/
  4.   __HAL_RCC_DMA1_CLK_ENABLE();
  5.   /*##-2- Select the DMA functional Parameters ###############################*/
  6.   DmaHandle.Init.Direction = DMA_MEMORY_TO_PERIPH ;          /* M2M transfer mode                */
  7.   DmaHandle.Init.PeriphInc = DMA_PINC_DISABLE;               /* Peripheral increment mode Enable */
  8.         //DmaHandle.Init.PeriphInc = DMA_PINC_DISABLE;
  9.   DmaHandle.Init.MemInc = DMA_MINC_ENABLE;                  /* Memory increment mode Enable     */
  10.         //DmaHandle.Init.MemInc = DMA_MINC_DISABLE;
  11. //  DmaHandle.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD; /* Peripheral data alignment : Word */
  12. //  DmaHandle.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;    /* memory data alignment : Word     */
  13. //  DmaHandle.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; /* Peripheral data alignment : Word */
  14. //
  15. //  DmaHandle.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;    /* memory data alignment : Word     */
  16.         DmaHandle.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE  ; /* Peripheral data alignment : Word */
  17.   DmaHandle.Init.MemDataAlignment = DMA_PDATAALIGN_BYTE  ;    /* memory data alignment : Word     */
  18.         DmaHandle.Init.Mode = DMA_NORMAL;                         /* Normal DMA mode                  */
  19.   DmaHandle.Init.Priority = DMA_PRIORITY_HIGH;              /* priority level : high            */
  20.   /*##-3- Select the DMA instance to be used for the transfer : DMA1_Channel1 #*/
  21.   DmaHandle.Instance = DMA_INSTANCE;
  22.   /*##-4- Initialize the DMA channel ##########################################*/
  23.   if (HAL_DMA_Init(&DmaHandle) != HAL_OK)
  24.   {
  25.     /* Initialization Error */
  26.     Error_Handler();
  27.   }
  28.
  29.   /*##-5- Select Callbacks functions called after Transfer complete and Transfer error */
  30.   HAL_DMA_RegisterCallback(&DmaHandle, HAL_DMA_XFER_CPLT_CB_ID, TransferComplete);
  31.   HAL_DMA_RegisterCallback(&DmaHandle, HAL_DMA_XFER_ERROR_CB_ID, TransferError);
  32.   /*##-6- Configure NVIC for DMA transfer complete/error interrupts ##########*/
  33.   /* Set Interrupt Group Priority */
  34.   HAL_NVIC_SetPriority(DMA_INSTANCE_IRQ, 0, 0);
  35.   /* Enable the DMA STREAM global Interrupt */
  36.   HAL_NVIC_EnableIRQ(DMA_INSTANCE_IRQ);
  37.   /*##-7- Start the DMA transfer using the interrupt mode ####################*/
  38.   /* Configure the source, destination and buffer size DMA fields and Start DMA Channel transfer */
  39.   /* Enable All the DMA interrupts */
  40.   if (HAL_DMA_Start_IT(&DmaHandle, (uint32_t)&aSRC_Const_Buffer, (uint32_t)aDST_Buffer, 4) != HAL_OK)
  41.   {
  42.     /* Transfer Error */
  43.     Error_Handler();
  44.   }
  45. }
请高手指教,如何解决?谢谢!
23
23
2024-7-31
发表于 2026-6-24 15:37:29 | 显示全部楼层
这里不是已经指定了源地址和目的地址
GMT+8, 2026-10-22 11:26
