查看: 1244|回复: 0
为何ESP32 AI CHAT ROBOT的xiaozhi-esp32-2.0.3工程文件,在vscode + idf5.5.2环境下编译失败?
49
49
2019-5-16
11 小时
发表于 2026-6-21 10:45:48 | 显示全部楼层 |阅读模式
为何ESP32 AI CHAT ROBOT的xiaozhi-esp32-2.0.3工程文件,在vscode + idf5.5.2环境下编译失败?下面是出错的日志:
Executing task: d:\Espressif\V5.5\esp-idf\tools\tools\cmake\3.30.2\bin\cmake.exe -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -B e:\esp32_prj\xiaozhi-esp32-2.0.3\build -S e:\esp32_prj\xiaozhi-esp32-2.0.3
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.54.0.windows.1")
-- Minimal build - OFF
-- The C compiler identification is GNU 14.2.0
-- The CXX compiler identification is GNU 14.2.0
-- The ASM compiler identification is GNU
-- Found assembler: D:/Espressif/V5.5/esp-idf/tools/tools/xtensa-esp-elf/esp-14.2.0_20251107/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: D:/Espressif/V5.5/esp-idf/tools/tools/xtensa-esp-elf/esp-14.2.0_20251107/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: D:/Espressif/V5.5/esp-idf/tools/tools/xtensa-esp-elf/esp-14.2.0_20251107/xtensa-esp-elf/bin/xtensa-esp32-elf-g++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Building ESP-IDF components for target esp32
NOTICE: Dependencies lock doesn't exist, solving dependencies.
NOTICE: Skipping optional dependency: espressif/esp_lcd_st7701
NOTICE: Skipping optional dependency: wvirgil123/sscma_client
NOTICE: Skipping optional dependency: waveshare/esp_lcd_jd9365_10_1
NOTICE: Skipping optional dependency: waveshare/esp_lcd_st7703
NOTICE: Skipping optional dependency: espressif/esp_lcd_ili9881c
NOTICE: Skipping optional dependency: espressif/esp_hosted
NOTICE: Skipping optional dependency: espressif/esp_wifi_remote
NOTICE: Skipping optional dependency: espfriends/servo_dog_ctrl
.....................................................................CMake Error at D:/Espressif/V5.5/esp-idf/tools/frameworks/esp-idf-v5.5.2/tools/cmake/build.cmake:629 (message):
  WARNING: Component "espressif2022/image_player" not found
  ERROR: Version solving failed:
      - no versions of espressif2022/image_player match ==1.1.0~1
      - project depends on espressif2022/image_player (==1.1.0~1)
  Result: Because project depends on espressif2022/image_player (==1.1.0~1)
  which doesn't match any versions, version solving failed.
Call Stack (most recent call first):
  D:/Espressif/V5.5/esp-idf/tools/frameworks/esp-idf-v5.5.2/tools/cmake/project.cmake:740 (idf_build_process)
  CMakeLists.txt:13 (project)
-- Configuring incomplete, errors occurred!
*  The terminal process "d:\Espressif\V5.5\esp-idf\tools\tools\cmake\3.30.2\bin\cmake.exe '-G', 'Ninja', '-DPYTHON_DEPS_CHECKED=1', '-DESP_PLATFORM=1', '-B', 'e:\esp32_prj\xiaozhi-esp32-2.0.3\build', '-S', 'e:\esp32_prj\xiaozhi-esp32-2.0.3'" terminated with exit code: 1.
GMT+8, 2026-10-30 18:09
