查看: 11544|回复: 2
DMA doublebuffer问题求助
38
38
2014-4-17
发表于 2014-6-19 13:36:25 | 显示全部楼层 |阅读模式
片子是smt32F407 程序目的是通过UART4接收数据,积攒到5个的时候,由CAN按顺序发出,采用DMA doublebuffer模式。
现在遇到一个问题,buffer2的时候CAN发出的数据全是0,buffer1正常,发送数据的数目也正常
代码如下
[mw_shl_code=c,true]void DMA1_Stream2_IRQHandler(void) { if(DMA_GetITStatus(DMA1_Stream2,DMA_IT_TCIF2)!=RESET) { if(DMA_FreeBuffer_No==1) { DMA_FreeBuffer_No=0; DMA_ClearITPendingBit(DMA1_Stream2,DMA_IT_TCIF2); k=0; for(k=0;k<13;k+=3) { j++; Can_send(0x0203,UART4_RECIEVE_DATA[k],UART4_RECIEVE_DATA[k+1],UART4_RECIEVE_DATA[k+2],0,0,0,0,j); Delay(4000); } j=0; } else { DMA_FreeBuffer_No=1; DMA_ClearITPendingBit(DMA1_Stream2,DMA_IT_TCIF2); n=0; for(n=0;n<13;n+=3) { j++; Can_send(0x0204,UART4_RECIEVE_DATA2[n],UART4_RECIEVE_DATA2[n+1],UART4_RECIEVE_DATA2[n+2],0,0,0,0,j); Delay(4000); } j=0; }}}[/mw_shl_code]
[mw_shl_code=c,true] DMA_DeInit(DMA1_Stream2); DMA_StructInit(&DMA_InitStructure); DMA_InitStructure.DMA_Channel = DMA_Channel_4; DMA_InitStructure.DMA_PeripheralBaseAddr = UART4_DR_Addr; //UART4_DR_Addr; DMA_InitStructure.DMA_Memory0BaseAddr =(uint32_t)UART4_RECIEVE_DATA; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; DMA_InitStructure.DMA_BufferSize =ReBufferSize; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable ; DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull ; DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single ; DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; DMA_Init(DMA1_Stream2, &DMA_InitStructure); DMA_ITConfig(DMA1_Stream2, DMA_IT_TC, ENABLE); DMA_Cmd(DMA1_Stream2,ENABLE); DMA_DoubleBufferModeConfig(DMA1_Stream2,(uint32_t)UART4_RECIEVE_DATA2,DMA_Memory_0); DMA_DoubleBufferModeCmd(DMA1_Stream2,ENABLE); DMA_FreeBuffer_No=1;[/mw_shl_code]
[mw_shl_code=c,true]int main(void) {NVIC_Config(); TIM_Config(); CAN1_Config(); DMA_Config(); while(1) {}}[/mw_shl_code]
刚才看到stm32f4的dma库函数上有一句话是Configures, when the DMAy Streamx is disabled, the double buffer mode  and the current memory target.灵机一动又试了试,好使了 DMA_DoubleBufferModeConfig(DMA1_Stream2,(uint32_t)UART4_RECIEVE_DATA2,DMA_Memory_0); DMA_DoubleBufferModeCmd(DMA1_Stream2,ENABLE); DMA_FreeBuffer_No=1; 放在 ...
38
38
2014-4-17
 楼主| 发表于 2014-6-19 13:36:26 | 显示全部楼层
放在
之前就行了。细节啊细节
58
102
102
2014-11-3
发表于 2014-11-14 13:33:52 | 显示全部楼层
回复【2楼】ritiange:
请问楼主DMA_FreeBuffer_No=1;
是你自己定义的,还是在库函数里面有?您是如何实现双缓存时,对已存满数组的操作的?现在急需指点,望楼主赐教!
GMT+8, 2026-11-22 21:05
