查看: 1514|回复: 1
STM32F103中断开启失败(寄存器写法)
2026-8-3
发表于 2026-8-18 08:26:05 | 显示全部楼层 |阅读模式
8金钱
为,求帮助
什么不对呀
(๑•́ ₃ •̀๑)
现象是两个灯亮了两次,然后按按键没有反应
#include "Key.h"
#include "Delay.h"
// 添加这个函数
void SystemClock_Init(void)
    // 1. 开启HSE(外部8MHz晶振)
    RCC->CR |= RCC_CR_HSEON;
    while(!(RCC->CR & RCC_CR_HSERDY));
    // 2. 配置PLL: HSE 8MHz * 9 = 72MHz
    RCC->CFGR |= RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9;
    // 3. 配置AHB/APB预分频
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;    // AHB = SYSCLK
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV2;   // APB1 = HCLK/2
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV1;   // APB2 = HCLK
    // 4. 开启PLL
    RCC->CR |= RCC_CR_PLLON;
    while(!(RCC->CR & RCC_CR_PLLRDY));
    // 5. 切换系统时钟到PLL
    RCC->CFGR |= RCC_CFGR_SW_PLL;
    while((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_PLL);
void Key_Init(void)
    // 开启GPIOE和AFIO时钟
    RCC->APB2ENR |= RCC_APB2ENR_IOPEEN;
    RCC->APB2ENR |= RCC_APB2ENR_AFIOEN;
    // PE3 (KEY1), PE4 (KEY0) 输入上拉
    GPIOE->CRL &= ~(GPIO_CRL_MODE3 | GPIO_CRL_CNF3);
    GPIOE->CRL |= GPIO_CRL_CNF3_1;        // 上拉输入
    GPIOE->CRL &= ~(GPIO_CRL_MODE4 | GPIO_CRL_CNF4);
    GPIOE->CRL |= GPIO_CRL_CNF4_1;        // 上拉输入
    // AFIO映射 - PE3 -> EXTI3, PE4 -> EXTI4
    AFIO->EXTICR[0] &= ~(0xF << 12);
    AFIO->EXTICR[0] |= (0x4 << 12);       // PE3 -> EXTI3
    AFIO->EXTICR[1] &= ~(0xF << 0);
    AFIO->EXTICR[1] |= (0x4 << 0);        // PE4 -> EXTI4
    // EXTI配置 - 下降沿触发(按键按下)
    EXTI->FTSR |= EXTI_FTSR_TR3 | EXTI_FTSR_TR4;
    EXTI->IMR |= EXTI_IMR_MR3 | EXTI_IMR_MR4;
    // NVIC配置
    NVIC_SetPriorityGrouping(3);
    NVIC_SetPriority(EXTI3_IRQn, 2);
    NVIC_EnableIRQ(EXTI3_IRQn);
    NVIC_SetPriority(EXTI4_IRQn, 2);
    NVIC_EnableIRQ(EXTI4_IRQn);
// ========== KEY1 (PE3) 中断服务函数 ==========
void EXTI3_IRQHandler(void)
    // &#9989; 步骤1:先检查中断标志
    if(EXTI->PR & EXTI_PR_PR3)
        // &#9989; 步骤2:清除中断标志(立即清除,防止重复进入)
        EXTI->PR |= EXTI_PR_PR3;
        // &#9989; 步骤3:简单硬件消抖(不使用Delay_ms)
        for(volatile int i = 0; i < 10000; i++);
        // &#9989; 步骤4:再次读取GPIO电平,确认按键确实按下
        if((GPIOE->IDR & GPIO_IDR_IDR3) == 0)  // 低电平表示按下
            LED_Toggle(LED0);  // 翻转红色LED
// ========== KEY0 (PE4) 中断服务函数 ==========
void EXTI4_IRQHandler(void)
    if(EXTI->PR & EXTI_PR_PR4)
        EXTI->PR |= EXTI_PR_PR4;
        if((GPIOE->IDR & GPIO_IDR_IDR4) == 0)  // 低电平表示按下
            LED_Toggle(LED1);  // 翻转绿色LED
#include "Key.h"
#include "Delay.h"
#include "LED.h"
int main(void)
    // 初始化LED和按键
        void SystemClock_Init();
    LED_Init();
    Key_Init();
    // 开机指示:两个LED闪烁一下
    LED_AllOn();
    Delay_ms(500);
    LED_AllOff();
    Delay_ms(500);
    LED_AllOn();
    Delay_ms(500);
    LED_AllOff();
        // 主循环可以执行其他任务
        // 所有LED控制都在中断中完成
Elite_DNF103 V2.6.pdf
1.3 MB, 下载次数: 0
2026-8-3
 楼主| 发表于 2026-8-18 09:36:34 | 显示全部楼层
对不起,对不起,是我发现我写错了,因为我这里都用了很多led,但是我发现我没有引用led的头文件,我忘记引用了
GMT+8, 2026-10-30 06:48
