查看: 17646|回复: 24
自制四轴飞行器飞行控制器
181
311
1055
1055
2012-8-26
52 小时
发表于 2014-6-23 20:30:04 | 显示全部楼层 |阅读模式
下一步打算做机架和电调,不过先学STM32F4
话不多说,直接上视频,从头到尾电路板制作过程和调试过程,到最后的加上图传飞行。
主控程序如下
#include "aquanjubianliang.c"
#include "usart.h"
#include "delay.h"
#include "led.h"
#include "key.h"
#include "exti.h"
#include "wdg.h"
#include "timer.h"
#include "lcd.h"
#include "rtc.h"
#include "wkup.h"
#include "adc.h"
#include "dma.h"
#include "24cxx.h"
#include "flash.h"
#include "24l01.h"
#include "mmc_sd.h"
#include "remote.h"
#include "ds18b20.h"
#include "mouse.h"
#include "text.h"
#include "fat.h"
#include "fontupd.h"
#include "IIC.h"
#include "inv_mpu.h"
#include "inv_mpu_dmp_motion_driver.h"
#include "math.h"
zhinengchuankou();
#define duoji1 PAout(5)// PA8
#define duoji2 PAout(1)
#define duoji3 PAout(0)
#define duoji4 PAout(2)
s16 duojipianyi[4];
//u16 jiaosuduchangshu=50,jieshoulingmin=4,shijijiaosuduchangshu=50,zuidaxiuzhengsudu=60,zuixiaotiaozhengshudu=10,weitiaoweizhi=10,jiaosuduqudiancishu=5,zuidatiaozhengsudu=40;//可用
//jiaosuduchangshu计算出各轴需要的理论角速度用;jieshoulingmin由于接收机定时器有误差,消除误差用,会消除精度; shijijiaosuduchangshu用于取得角速度之后除数;zuidaxiuzhengsudu自稳系统的最大旋转速度
//zuixiaotiaozhengshudu当调整速度小于此数值时,增加调整速度,weitiaoweizhi当调整速度小于此数值时 进行微调就可以,jiaosuduqudiancishu角速度的次数累加,越多越准确,但反应越慢,zuidatiaozhengsudu表示最大稳定时的速度
u16 jiaosuduchangshu=100,jieshoulingmin=4,shijijiaosuduchangshu2=50,zuidaxiuzhengsudu=250,zuixiaotiaozhengshudu=6,weitiaoweizhi=2,jiaosuduqudiancishu=2,zuidatiaozhengsudu=60;
//kongzhilingmin接收机的灵敏度用
u32 kongzhilingmin=30000;
u16 jieshouji[6],wei=0,jiesuo=0,jiaosuducishu=0,shijijiaosuduchangshu=20;
s32 h,duojikongzhi[8],i,zhongduancishu,xlilunjiaosudu,ylilunjiaosudu,zlilunjiaosudu,xpianyijiaosudu,ypianyijiaosudu,zpianyijiaosudu,xjiaosudu,yjiaosudu,zjiaosudu,lingshijiaosudu,xjsd[100],yjsd[100],zjsd[100];
double shurufuyi,shurushengjiang,shurufangxiang,shuruyoumen,t,pi=3.14159,youmen[10];
double nifuyi=0,nishengjiang=0,nifangxiang=0,niyoumen=0;
double lilunfuyi,lilunshengjiang,lilunfangxiang,lilunyoumen,chafuyi,chashengjiang,chafangxiang,chayoumen,shijiyoumen;
u8 shuruyinjiao=10,suo=0,SendBuff[256]={97};
int main(void)
//    u16 i;
duojipianyi[0]=0;
duojipianyi[1]=0;
duojipianyi[2]=0;
duojipianyi[3]=0;
  duojikongzhi[0]=1100;
duojikongzhi[1]=1100;
duojikongzhi[2]=1100;
duojikongzhi[3]=1100;
duojikongzhi[4]=2000;
   Stm32_Clock_Init(9); //系统时钟设置
delay_init(72); //延时初始化
uart_init(72,1600);  //串口1初始化
//USART1->DR=SendBuff[1];
gpioshezhi(); //引脚设置
led4=0;
// LED_Init();          //LED初始化
i2cInit(); //I2C接口设置
//Timer4_Init(7199,1000);
Timer3_Init(10000,72); //定时器3,中断开启,时间不定,输出PWM信号控制螺旋桨转速   抢断优先级
Timer2_Init(7199,70); //定时器2,有中断,70毫秒读取陀螺仪数据
Timer1_Init(60000,72);TIM1->CR1|=0x01;//定时器一,没有中断,用于计时接收机信号
EXTI15_10_Init(); //10-15中断 接收机信号中断 抢断优先级
delay_ms(100); //延时300MS
chuankoufasong(36,1); //串口发送,检测芯片是否运行
result = mpu_init(); //dmp读出
{//去角速度偏移量,MPU6050制造误差
xpianyijiaosudu=dumpu6050jicunqi(0);
ypianyijiaosudu=dumpu6050jicunqi(1);
zpianyijiaosudu=dumpu6050jicunqi(2);
if(!result)
chuankoufasong(36,2);
mpufifo_init(); //dmp——fifo设置
MYDMA_Enable(DMA1_Channel4);
chuankoufasong(37,4);
USART1->DR=SendBuff[chuankoufasongwei];
{ //计算出理论飞行角度
lilunyoumen=shuruyoumen;
lilunfuyi=0.4*(shurufuyi/300);
lilunshengjiang=0.4*(shurushengjiang/300);
lilunfangxiang=lilunfangxiang+nifangxiang*2 ;
nifuyi=0;
nishengjiang=0;
nifangxiang=0;
if(lilunshengjiang>3.14159/2){lilunfuyi=lilunfuyi+3.14159;lilunfangxiang=lilunfangxiang-3.14159;lilunshengjiang=3.1415/2;}
if(lilunshengjiang<-3.14159/2){lilunfuyi=lilunfuyi+3.14159;lilunfangxiang=lilunfangxiang-3.14159;lilunshengjiang=-3.1415/2;}
if(lilunfangxiang>2*3.14159)lilunfangxiang=lilunfangxiang-2*3.14159;
if(lilunfangxiang<0)lilunfangxiang=lilunfangxiang+3.14159*2;
if(lilunfuyi>3.14159)lilunfuyi=lilunfuyi-3.14159*2;
if(lilunfuyi<-3.14159)lilunfuyi=lilunfuyi+3.14159*2;
{ //计算出实际坐标和理论坐标差
chafuyi=Roll-lilunfuyi;
if(chafuyi>pi)chafuyi-=2*pi;
if(chafuyi<-pi)chafuyi+=2*pi;
//if(chafuyi>(pi/8))chafuyi=pi/8;
//if(chafuyi<(-pi)/8)chafuyi=-pi/8;
chashengjiang=-(Pitch-lilunshengjiang);
if(chashengjiang>(pi))chashengjiang-=2*pi;
if(chashengjiang<-(pi))chashengjiang+=2*pi;
//if(chashengjiang>(pi/8))chashengjiang=pi/8;
//if(chashengjiang<(-pi)/8)chashengjiang=-pi/8;
chafangxiang=-(Yaw-lilunfangxiang);
if(chafangxiang>pi)chafangxiang-=2*pi;
if(chafangxiang<-pi)chafangxiang+=2*pi;
//if(chafangxiang>(pi/8))chafangxiang=pi/8;
//if(chafangxiang<(-pi)/8)chafangxiang=-pi/8;
{ //计算出飞行器各个轴需要的理论角速度
xlilunjiaosudu=(chafuyi )*jiaosuduchangshu;
ylilunjiaosudu=(chashengjiang*cos(Roll)+chafangxiang*sin(Roll))*jiaosuduchangshu;
zlilunjiaosudu=(chafangxiang*cos(Roll)-chashengjiang*sin(Roll))*jiaosuduchangshu;
if(xlilunjiaosudu>zuidatiaozhengsudu)xlilunjiaosudu=zuidatiaozhengsudu;
if(xlilunjiaosudu<-zuidatiaozhengsudu)xlilunjiaosudu=-zuidatiaozhengsudu;
if(ylilunjiaosudu>zuidatiaozhengsudu)ylilunjiaosudu=zuidatiaozhengsudu;
if(ylilunjiaosudu<-zuidatiaozhengsudu)ylilunjiaosudu=-zuidatiaozhengsudu;
if(zlilunjiaosudu>zuidatiaozhengsudu)zlilunjiaosudu=zuidatiaozhengsudu;
if(zlilunjiaosudu<-zuidatiaozhengsudu)zlilunjiaosudu=-zuidatiaozhengsudu;
if(xlilunjiaosudu<zuixiaotiaozhengshudu&&xlilunjiaosudu>weitiaoweizhi)xlilunjiaosudu=zuixiaotiaozhengshudu;
if(ylilunjiaosudu<zuixiaotiaozhengshudu&&ylilunjiaosudu>weitiaoweizhi)ylilunjiaosudu=zuixiaotiaozhengshudu;
if(zlilunjiaosudu<zuixiaotiaozhengshudu&&zlilunjiaosudu>weitiaoweizhi)zlilunjiaosudu=zuixiaotiaozhengshudu;
if(xlilunjiaosudu>-zuixiaotiaozhengshudu&&xlilunjiaosudu<-weitiaoweizhi)xlilunjiaosudu=-zuixiaotiaozhengshudu;
if(ylilunjiaosudu>-zuixiaotiaozhengshudu&&ylilunjiaosudu<-weitiaoweizhi)ylilunjiaosudu=-zuixiaotiaozhengshudu;
if(zlilunjiaosudu>-zuixiaotiaozhengshudu&&zlilunjiaosudu<-weitiaoweizhi)zlilunjiaosudu=-zuixiaotiaozhengshudu;
{   //计算角速度平均数
xjiaosudu=0;
yjiaosudu=0;
zjiaosudu=0;
for(i=0;i<jiaosuduqudiancishu;i++)
xjiaosudu+=xjsd;
yjiaosudu+=yjsd;
zjiaosudu+=zjsd;
xjiaosudu/=jiaosuduqudiancishu;
yjiaosudu/=-jiaosuduqudiancishu;
zjiaosudu=zjiaosudu/jiaosuduqudiancishu;
if(shuruyoumen>1200) //如果油门处于激活状态
{ //从理论角速度计算功电机运行的信号强度
shijijiaosuduchangshu=shijijiaosuduchangshu2*(lilunyoumen-800)/1000*(lilunyoumen-600)/1000;
lingshijiaosudu=(-xjiaosudu)/shijijiaosuduchangshu;
if(lingshijiaosudu>zuidaxiuzhengsudu)lingshijiaosudu=zuidaxiuzhengsudu;
if(lingshijiaosudu<-zuidaxiuzhengsudu)lingshijiaosudu=-zuidaxiuzhengsudu;
//xjiaosudu=-shurufuyi/jiaosuduchangshu-lingshijiaosudu;//角速度调整模式时 jiaosuduchangshu=15
//xlilunjiaosudu=-shurufuyi/jiaosuduchangshu;
xjiaosudu=xlilunjiaosudu-lingshijiaosudu;
lingshijiaosudu=(yjiaosudu)/shijijiaosuduchangshu;
//yjiaosudu=shurushengjiang/jiaosuduchangshu-lingshijiaosudu;
//ylilunjiaosudu=shurushengjiang/jiaosuduchangshu;
yjiaosudu=ylilunjiaosudu-lingshijiaosudu;
lingshijiaosudu=(zjiaosudu)/shijijiaosuduchangshu;
//zjiaosudu=shurufangxiang/jiaosuduchangshu-lingshijiaosudu;
//zlilunjiaosudu=shurufangxiang/jiaosuduchangshu;
zjiaosudu=zlilunjiaosudu-lingshijiaosudu;
if(lilunyoumen>1700)lilunyoumen=1700;
duojikongzhi[0]=lilunyoumen+xjiaosudu+yjiaosudu+zjiaosudu*3+duojipianyi[0];
duojikongzhi[1]=lilunyoumen-xjiaosudu+yjiaosudu-zjiaosudu*3+duojipianyi[1];
duojikongzhi[2]=lilunyoumen-xjiaosudu-yjiaosudu+zjiaosudu*3+duojipianyi[2];
duojikongzhi[3]=lilunyoumen+xjiaosudu-yjiaosudu-zjiaosudu*3+duojipianyi[3];
for(i=0;i<4;i++)
if(duojikongzhi<1200)duojikongzhi=1200;
else { //如果油门为0
duojikongzhi[0]=duojikongzhi[1]=duojikongzhi[2]=duojikongzhi[3]=1100;
lilunfuyi=Roll;
lilunshengjiang=Pitch;
lilunfangxiang=Yaw;
//t=double(jieshouji[0])/100;
for(i=0;i<6;i++){
chuankoufasong(36,shurufuyi);
chuankoufasong(37,shurushengjiang);
chuankoufasong(38,shuruyoumen);
chuankoufasong(39,shurufangxiang);delay_ms(30);
{ //发送串口数据,功电脑读取.
h=shurufangxiang;
chuankoufasong(36,xjiaosudu); delay_ms(10);
h=shuruyoumen;
chuankoufasong(37,yjiaosudu); delay_ms(10);
h=chafangxiang*57;
chuankoufasong(38,zjiaosudu);
delay_ms(10);
chuankoufasong(39,duojikongzhi[3]);
delay_ms(10);
//duojikongzhi[0]=duojikongzhi[1]=duojikongzhi[2]=duojikongzhi[3]=shuruyoumen+1100;
h=xjiaosudu;
chuankoufasong(36,h);
h=yjiaosudu;
chuankoufasong(37,h); delay_ms(10);
h=zjiaosudu;
chuankoufasong(38,h);
h=shurufangxiang;
chuankoufasong(39,h);
h=shuruyoumen;
chuankoufasong(39,jieshouji[4]);
h= dumpu6050jicunqi(0);
h= dumpu6050jicunqi(1);
h= dumpu6050jicunqi(2);
chuankoufasong(36,jieshouji[3]);
chuankoufasong(37,jieshouji[2]);
chuankoufasong(38,jieshouji[4]);
if((USART1->SR&0X40)!=0)
zhinengchuankou();
void TIM2_IRQHandler(void) //定时器2 ,用于读取DMP数据
TIM2->SR&=~(1<<0);//清除中断标志位
 dmp_read_fifo(gyro, accel, quat, &sensor_timestamp, &sensors,&more);
     if (sensors & INV_WXYZ_QUAT )
   q0=quat[0] / q30;
 q1=quat[1] / q30;
 q2=quat[2] / q30;
 q3=quat[3] / q30;
 Roll = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1); // roll副翼
 itch  = asin(-2 * q1 * q3 + 2 * q0* q2); // pitch升降
   Yaw =  atan2(2*(q1*q2 + q0*q3),q0*q0+q1*q1-q2*q2-q3*q3) ;//方向
 //h=Roll*57295;
 //chuankoufasong(36,h);
 //h=Pitch*57295;
 //chuankoufasong(37,h);
 //h=Yaw*57295;
// chuankoufasong(38,h);
// PrintChar("nihao\n");
xjsd[jiaosuducishu]=(gyro[0]-0);
yjsd[jiaosuducishu]=-(gyro[1]-0);
zjsd[jiaosuducishu]=(gyro[2]-0);
jiaosuducishu++;
if(jiaosuducishu>=jiaosuduqudiancishu)jiaosuducishu=0;
void EXTI15_10_IRQHandler(void) //接收机信号接收中断         耗时2微秒  以内
u8 jicixunhuan;
for(jicixunhuan=12;jicixunhuan<16;jicixunhuan++)
if(((GPIOB->IDR>>jicixunhuan)&1)){
shuruyinjiao=jicixunhuan;
TIM1->CNT=0;
if(!(GPIOB->IDR>>12&0xf)){ //如果接收机发送结束
if(TIM1->CNT>1000&&TIM1->CNT<2000)
jieshouji[shuruyinjiao-10]=TIM1->CNT; //将接收机变量保存到变量
jieshouji[shuruyinjiao-10]/=jieshoulingmin;
jieshouji[shuruyinjiao-10]*=jieshoulingmin;
if(shuruyinjiao==15)
//计算得到每个摇杆的行程
if((youmen[0]-jieshouji[3])<100&&(shuruyoumen-jieshouji[3])<100)
shurufuyi=1492-jieshouji[3];
youmen[0]=jieshouji[3];
shurushengjiang=1492-jieshouji[2];
shurufangxiang=1492-jieshouji[5];
shuruyoumen=jieshouji[4];
//每个遥感的行程转化成每次的偏移量
nifuyi=nifuyi+shurufuyi/kongzhilingmin;
nishengjiang=nishengjiang+shurushengjiang/kongzhilingmin;
nifangxiang=nifangxiang+shurufangxiang/kongzhilingmin;
if(shuruyoumen<1190){jiesuo++;
if(shurufangxiang>200){
if(jiesuo>700) {
jiesuo=0;
suo=0;
if(shurufangxiang<-200){
if(jiesuo>700){
jiesuo=0;
suo=1;
else jiesuo=0;
zhongduancishu++;
EXTI->R=1<<10;
EXTI->R=1<<11;
EXTI->R=1<<12;
EXTI->R=1<<13;
EXTI->R=1<<14;
EXTI->R=1<<15;
void TIM3_IRQHandler(void) //定时器3,用于输出PWM信号   耗时1微秒 以内
if(suo==1){
if(shuruyoumen<1200)duojikongzhi[0]=duojikongzhi[1]=duojikongzhi[2]=duojikongzhi[3]=1100;
TIM3->CNT=duojikongzhi[wei];
if(wei==0){duoji1=0;duoji2=0;duoji3=0;duoji4=0;duoji1=1;}
if(wei==1){duoji1=0;duoji2=0;duoji3=0;duoji4=0;duoji2=1;}
if(wei==2){duoji1=0;duoji2=0;duoji3=0;duoji4=0;duoji3=1;}
if(wei==3){duoji1=0;duoji2=0;duoji3=0;duoji4=0;duoji4=1;led4=!led4;}
if(wei==4){duoji1=0;duoji2=0;duoji3=0;duoji4=0; }
wei++;
if(wei>4)wei=0;
if(suo==0)led4=0;
TIM3->SR&=~(1<<0);//清除中断标志位
void TIM4_IRQHandler(void)
TIM4->SR&=~(1<<0);//清除中断标志?
zhinengchuankou()
USART1->SR&=~(1<<6);
chuankoufasongwei++;
if(chuankoufasongwei>=20){chuankoufasongge=1;
if(chuankoufasongcishu==36){
SendBuff[0]=36;
chuankoufasongshuju=Roll*572957;
chuankoufasongcishu=37;
}else
if(chuankoufasongcishu==37){
SendBuff[0]=37;
chuankoufasongshuju=Pitch*572957;
chuankoufasongcishu=38;
}else
if(chuankoufasongcishu==38){
SendBuff[0]=38;
chuankoufasongshuju=Yaw*572957;
chuankoufasongcishu=36;
if(chuankoufasongshuju<0){
SendBuff[chuankoufasongge]=45;  // 给SBUFA数据
chuankoufasongge++;
if(chuankoufasongshuju>=100000000){
SendBuff[chuankoufasongge]=(chuankoufasongshuju/100000000)%10+48;  // 给SBUFA数据
chuankoufasongge++;
if(chuankoufasongshuju>=10000000){
SendBuff[chuankoufasongge]=(chuankoufasongshuju/10000000)%10+48;  // 给SBUFA数据
chuankoufasongge++;
if(chuankoufasongshuju>=1000000) {SendBuff[chuankoufasongge]=(chuankoufasongshuju/1000000)%10+48;  // 给SBUFA数据
chuankoufasongge++;
if(chuankoufasongshuju>=100000) {SendBuff[chuankoufasongge]=(chuankoufasongshuju/100000)%10+48;  // 给SBUFA数据
chuankoufasongge++;
if(chuankoufasongshuju>=10000) {SendBuff[chuankoufasongge]=(chuankoufasongshuju/10000)%10+48;  // 给SBUFA数据
chuankoufasongge++;
if(chuankoufasongshuju>=1000) {SendBuff[chuankoufasongge]=(chuankoufasongshuju/1000)%10+48;  // 给SBUFA数据
chuankoufasongge++;
if(chuankoufasongshuju>=100) {SendBuff[chuankoufasongge]=(chuankoufasongshuju/100)%10+48;  // 给SBUFA数据
chuankoufasongge++;
if(chuankoufasongshuju>=10) {SendBuff[chuankoufasongge]=(chuankoufasongshuju/10)%10+48;  // 给SBUFA数据
chuankoufasongge++;
if(1) {SendBuff[chuankoufasongge]=(chuankoufasongshuju/1)%10+48;  // 给SBUFA数据
chuankoufasongge++;
for(;chuankoufasongge<20;chuankoufasongge++)
SendBuff[chuankoufasongge]=10;
chuankoufasongwei=0;
为了雅典娜?为了爱与正义
473
5074
5074
2013-10-4
654 小时
发表于 2014-6-23 20:46:51 | 显示全部楼层
不错,帮顶。。
希望可以共享下下
56
287
865
865
2012-11-16
65 小时
发表于 2014-6-23 20:50:56 | 显示全部楼层
很厉害!!!
发表于 2014-6-23 22:09:07 | 显示全部楼层
473
5074
5074
2013-10-4
654 小时
发表于 2014-6-25 15:25:31 | 显示全部楼层
谢谢分享。。。。。。。。。。。
2014-8-29
发表于 2014-8-30 10:32:08 | 显示全部楼层
赞,太感谢楼主了,雪中送炭
228
485
1689
1689
2012-4-10
105 小时
发表于 2014-8-30 14:00:14 | 显示全部楼层
楼主用的什么摄像模块
181
311
1055
1055
2012-8-26
52 小时
 楼主| 发表于 2014-8-31 18:23:40 | 显示全部楼层
回复【7楼】344864311:
柏通图传模块
为了雅典娜?为了爱与正义
228
485
1689
1689
2012-4-10
105 小时
发表于 2014-8-31 19:56:33 | 显示全部楼层
能给个链接吗,我需要买一个。
181
311
1055
1055
2012-8-26
52 小时
 楼主| 发表于 2014-8-31 22:13:22 | 显示全部楼层
回复【9楼】344864311:
http://item.taobao.com/item.htm?spm=a1z09.2.9.11.YdWvN1&id=25409468806&_u=v7hq0tl0460
为了雅典娜?为了爱与正义
2014-7-11
发表于 2014-10-28 08:15:23 | 显示全部楼层
Mark,谢谢分享
2015-8-15
发表于 2015-9-6 10:44:00 | 显示全部楼层
mark
谢谢分享!!
2016-4-4
发表于 2016-4-4 18:00:56 | 显示全部楼层
你好,能不能给我发一份第一个视频呢?460339847@qq.com
35
241
241
2016-1-6
33 小时
发表于 2016-4-5 08:18:51 | 显示全部楼层
2016-4-8
发表于 2016-4-8 21:51:41 | 显示全部楼层
大神你好,能给发一下第一个视频吗???  谢谢啦
454
454
2015-11-29
50 小时
发表于 2016-4-16 08:17:48 | 显示全部楼层
不错,,
2016-4-19
发表于 2016-4-19 10:55:31 | 显示全部楼层
楼主的电调驱动用的是哪一家的
各位大侠帮忙看看此款电调驱动怎么样
FD6288是一款集成了三个独立的半桥栅极驱动集成电路芯片,专为高压、高速驱动MOSFET和IGBT设计,可在高达+250V电压下工作。FD6288内置VCC/VBS欠压(UVLO)保护功能,防止功率管在过低的电压下工作。FD6288内置直通防止和死区时间,防止被驱动的高低侧MOSFET或IGBT直通,有效保护功率器件。FD6288内置输入信号滤波,防止输入噪声干扰
130
130
2015-5-26
22 小时
发表于 2016-4-25 14:17:05 | 显示全部楼层
楼主你好,能给发一下第一个视频吗?  谢谢啦!邮箱:778261169@qq.com
181
311
1055
1055
2012-8-26
52 小时
 楼主| 发表于 2016-7-19 17:13:39 | 显示全部楼层
是制作飞控的过程,被封了。。。为何天朝做个飞控都要和谐
为了雅典娜?为了爱与正义
92
288
288
2016-7-20
33 小时
发表于 2016-8-13 00:50:20 | 显示全部楼层
哼!天朝这里不清真啊,我就觉得该鼓励自己做飞控的
42
145
353
353
2016-7-17
59 小时
发表于 2016-8-16 17:17:39 | 显示全部楼层
楼主,解释一下MPU6050姿态解算部分的代码吧,不懂四元素解算啊
42
145
353
353
2016-7-17
59 小时
发表于 2016-8-16 17:19:24 | 显示全部楼层
楼主给我发个飞控自作视频呗,谢谢2336599635@qq。com
2016-12-7
发表于 2016-12-7 00:25:19 | 显示全部楼层
谢谢分享!!
38
38
2016-12-12
发表于 2016-12-12 22:29:44 | 显示全部楼层
楼主伟大,发个制作过程视频,和详细点的资料可以不,初学者太薄弱了,谢谢啦。邮箱:2820048139@qq.com
181
311
1055
1055
2012-8-26
52 小时
 楼主| 发表于 2016-12-18 21:53:56 | 显示全部楼层
详细制作过程已被和谐
为了雅典娜?为了爱与正义
GMT+8, 2026-11-11 00:26
