查看: 14076|回复: 10
用STM32F407的SPI来控制片外EEPROM(X25040)时,读出的数据是乱码,
54
54
2014-6-25
发表于 2014-7-14 21:48:57 | 显示全部楼层 |阅读模式
[mw_shl_code=c,true]void WRITE_X25042(uint8_t* pBuffer, uint8_t WriteAddr, uint16_t NumByteToWrite) { //sFLASH_WaitForWriteEnd(); /*!< Enable the write access to the FLASH */ sFLASH_WriteEnable(); /*!< Select the FLASH: Chip Select low */ sFLASH_CS_LOW(); /*!< Send "Write to Memory " instruction */ sFLASH_SendByte(sFLASH_CMD_WRITE); sFLASH_CS_HIGH(); for(Index=0;Index<10;Index++); sFLASH_CS_LOW(); /*!< Send WriteAddr high nibble address byte to write to */ // sFLASH_SendByte((WriteAddr & 0xFF0000) >> 16); /*!< Send WriteAddr medium nibble address byte to write to */ //sFLASH_SendByte((WriteAddr & 0x0100) >> 8); /*!< Send WriteAddr low nibble address byte to write to */ sFLASH_SendByte(WriteAddr & 0xFF); /*!< while there is data to be written on the FLASH */ while (NumByteToWrite--) { /*!< Send the current byte */ sFLASH_SendByte(*pBuffer); /*!< Point on the next byte to be written */ printf("%c",*pBuffer); pBuffer++; } /*!< Deselect the FLASH: Chip Select high */ sFLASH_CS_HIGH(); /*!< Wait the end of Flash writing */ sFLASH_WaitForWriteEnd(); } void READ_X25042(uint8_t* pBuffer, uint8_t ReadAddr, uint16_t NumByteToRead) { /*!< Select the FLASH: Chip Select low */ sFLASH_CS_LOW(); /*!< Send "Read from Memory " instruction */ sFLASH_SendByte(sFLASH_CMD_READ); /*!< Send ReadAddr high nibble address byte to read from */ //sFLASH_SendByte((ReadAddr & 0xFF0000) >> 16); /*!< Send ReadAddr medium nibble address byte to read from */ // sFLASH_SendByte((ReadAddr& 0x0100) >> 8); /*!< Send ReadAddr low nibble address byte to read from */ sFLASH_SendByte(ReadAddr & 0xFF); while (NumByteToRead--) /*!< while there is data to be read */ { /*!< Read a byte from the FLASH */ *pBuffer = sFLASH_SendByte(sFLASH_DUMMY_BYTE); /*!< Point to the next location where the byte read will be saved */ printf("%c",*pBuffer); pBuffer++; } /*!< Deselect the FLASH: Chip Select high */ sFLASH_CS_HIGH(); } int main(void) { STM_EVAL_LEDInit(LED1); STM_EVAL_LEDInit(LED2); USART_Config();//USART配置 /* Initialize the SPI FLASH driver */ sFLASH_Init(); /* Write Tx_Buffer data to SPI FLASH memory */ WRITE_X25042(Tx_Buffer, FLASH_WRITE_ADDRESS, BufferSize); printf("\n"); /* Read data from SPI FLASH memory */ READ_X25042(Rx_Buffer, FLASH_READ_ADDRESS, BufferSize); printf("\n"); /* Check the correctness of written dada */ TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize); /* TransferStatus1 = PASSED, if the transmitted and received data by SPI1 are the same */ /* TransferStatus1 = FAILED, if the transmitted and received data by SPI1 are different */ if(TransferStatus1 == PASSED) { STM_EVAL_LEDOn(LED1); printf("SPI_EEPROM demo is successful \n"); } else { STM_EVAL_LEDOn(LED2); printf("SPI_EEPROM demo is failed \n"); } while (1){} }[/mw_shl_code]
54
54
2014-6-25
 楼主| 发表于 2014-7-14 21:57:04 | 显示全部楼层
我发送的是123456789,
165779
165779
发表于 2014-7-14 22:42:13 | 显示全部楼层
帮顶,慢慢调试吧。
120
7861
12011
12011
2013-9-10
427 小时
发表于 2014-7-15 08:34:18 | 显示全部楼层
抓SPI发送和接收的波形,对比你发送的内容和要接收的数据,对比一下
2244
4522
4522
2013-4-22
338 小时
发表于 2014-7-15 09:01:52 | 显示全部楼层
1.时序可能不正确2.spi配置不正确
54
54
2014-6-25
 楼主| 发表于 2014-7-15 09:47:47 | 显示全部楼层
54
54
2014-6-25
 楼主| 发表于 2014-7-15 09:48:37 | 显示全部楼层
这是读写的时序图,大家帮忙分析下
54
54
2014-6-25
 楼主| 发表于 2014-7-16 09:40:36 | 显示全部楼层
回复【4楼】Badu_Space:
你好:用示波器测得发送和接受的数据是一致的,但是在kei编译器上显示接收到的数据确实乱码,
120
7861
12011
12011
2013-9-10
427 小时
发表于 2014-7-16 11:09:45 | 显示全部楼层
发送和接收的数据都是正确的话就是你显示操作不对了吧,分析一下那个波形数据内容,用逻辑分析仪抓
54
54
2014-6-25
 楼主| 发表于 2014-7-16 16:56:11 | 显示全部楼层
回复【9楼】Badu_Space:
我在使用逻辑分析仪时,怎么不显示GPIO
120
7861
12011
12011
2013-9-10
427 小时
发表于 2014-7-16 17:04:36 | 显示全部楼层
回复【10楼】tempting:
你是软件模拟的么?
GMT+8, 2026-10-25 09:31
