查看: 6648|回复: 3
51程序移植到430上无法显示,求大神指导
2014-7-19
发表于 2014-7-19 10:41:12 | 显示全部楼层 |阅读模式
#include "msp430g2553.h"
#define high 1
#define low 0
/*************Pin Define***************/
#define SCL_l P2OUT&=~BIT1
#define SCL_h P2OUT|=BIT1  //SCL接P2.1
#define SDA_l P2OUT&=~BIT2
#define SDA_h P2OUT|=BIT2 //SCL接P2.2
#define ulong unsigned long
void Initial_LY096BG30();
#define MCLK 1000//KHz
#define delay_ms(x) __delay_cycles((ulong)x*MCLK)
void fill_picture(unsigned char fill_Data);
void IIC_Start();
void IIC_Stop();
void Write_IIC_Command(unsigned char IIC_Command);
void Write_IIC_Data(unsigned char IIC_Data);
void Write_IIC_Byte(unsigned char IIC_Byte);
/***********************Initial code*********************/
    P2DIR|=BIT1 +BIT2;
Write_IIC_Command(0xAE);   //display off
Write_IIC_Command(0x20); //Set Memory Addressing Mode
Write_IIC_Command(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
Write_IIC_Command(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
Write_IIC_Command(0xc8); //Set COM Output Scan Direction
Write_IIC_Command(0x00);//---set low column address
Write_IIC_Command(0x10);//---set high column address
Write_IIC_Command(0x40);//--set start line address
Write_IIC_Command(0x81);//--set contrast control register
Write_IIC_Command(0x7f);
Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
Write_IIC_Command(0xa6);//--set normal display
Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
Write_IIC_Command(0x3F);//
Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
Write_IIC_Command(0xd3);//-set display offset
Write_IIC_Command(0x00);//-not offset
Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
Write_IIC_Command(0xf0);//--set divide ratio
Write_IIC_Command(0xd9);//--set pre-charge period
Write_IIC_Command(0x22); //
Write_IIC_Command(0xda);//--set com pins hardware configuration
Write_IIC_Command(0x12);
Write_IIC_Command(0xdb);//--set vcomh
Write_IIC_Command(0x20);//0x20,0.77xVcc
Write_IIC_Command(0x8d);//--set DC-DC enable
Write_IIC_Command(0x14);//
Write_IIC_Command(0xaf);//--turn on oled panel
/***********************Picture Code**************************/
unsigned char  const show1[]=
0x00,0x06,0x0A,0xFE,0x0A,0xC6,0x00,0xE0,0x00,0xF0,0x00,0xF8,0x00,0x00,0x00,0x00,
0x00,0x00,0xFE,0x7D,0xBB,0xC7,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xC7,0xBB,0x7D,
0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,
0x0C,0xFE,0xFE,0x0C,0x08,0x20,0x60,0xFE,0xFE,0x60,0x20,0x00,0x00,0x00,0x78,0x48,
0xFE,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xFE,0x00,
0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFF,
0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFF,0x00,0x00,0xFE,0xFF,0x03,
0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFE,0x00,0x00,0x00,0x00,0xC0,0xC0,
0xC0,0x00,0x00,0x00,0x00,0xFE,0xFF,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
0xFF,0xFE,0x00,0x00,0xFE,0xFF,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x0C,
0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFF,0xFF,0x00,0x00,0x00,0x00,0xE1,0xE1,
0xE1,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFF,
0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,
0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,0x0F,0x00,0x00,0x0F,0x1F,0x18,
0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,
0x1F,0x0F,0x00,0x00,0x0F,0x1F,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,
0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xE2,0x92,0x8A,0x86,0x00,0x00,0x7C,0x82,0x82,0x82,0x7C,
0x00,0xFE,0x00,0x82,0x92,0xAA,0xC6,0x00,0x00,0xC0,0xC0,0x00,0x7C,0x82,0x82,0x82,
0x7C,0x00,0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0xC0,0xC0,0x00,0x7C,0x82,0x82,0x82,
0x7C,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x24,0xA4,0x2E,0x24,0xE4,0x24,0x2E,0xA4,0x24,0x00,0x00,0x00,0xF8,0x4A,0x4C,
0x48,0xF8,0x48,0x4C,0x4A,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,
0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,0x20,0x10,0x10,0x10,0x10,0x20,0xC0,0x00,0x00,
0x00,0x12,0x0A,0x07,0x02,0x7F,0x02,0x07,0x0A,0x12,0x00,0x00,0x00,0x0B,0x0A,0x0A,
0x0A,0x7F,0x0A,0x0A,0x0A,0x0B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x40,0x40,
0x40,0x50,0x20,0x5F,0x80,0x00,0x1F,0x20,0x40,0x40,0x40,0x50,0x20,0x5F,0x80,0x00,
//IIC Start
void IIC_Start()
   SCL_h;
   //Delay_us(1);
   SDA_h;
   //Delay_us(1);
   SDA_l;
  // Delay_us(1);
   SCL_l;
  // Delay_us(1);
//IIC Stop
void IIC_Stop()
   SCL_l;
   //Delay_us(1);
   SDA_l;
   //Delay_us(1);
   SCL_h;
   //Delay_us(1);
   SDA_h;
   //Delay_us(1);
// IIC Write byte
    P2DIR|=BIT1 +BIT2;
unsigned char i;
for(i=0;i<8;i++)
if(IIC_Byte & 0x80) //1?0?
SDA_h;
SDA_l;
//Delay_us(1);
SCL_h;
//Delay_us(1);
SCL_l;
//Delay_us(1);
IIC_Byte<<=1; //loop
SDA_h;
//Delay_us(1);
SCL_h;
//Delay_us(1);
SCL_l;
//Delay_us(1);
// IIC Write Command
   2DIR|=BIT1 +BIT2;
   IIC_Start();
   Write_IIC_Byte(0x78);            //Slave address,SA0=0
   Write_IIC_Byte(0x00); //write command
   Write_IIC_Byte(IIC_Command);
   IIC_Stop();
// IIC Write Data
   2DIR|=BIT1 +BIT2;
   IIC_Start();
   Write_IIC_Byte(0x40); //write data
   Write_IIC_Byte(IIC_Data);
   IIC_Stop();
// fill_Picture
   2DIR|=BIT1 +BIT2;
unsigned char m,n;
for(m=0;m<8;m++)
Write_IIC_Command(0xb0+m); //page0-page1
Write_IIC_Command(0x00); //low column start address
Write_IIC_Command(0x10); //high column start address
for(n=0;n<128;n++)
  Write_IIC_Data(fill_Data);
// picture
void picture_1()
{ P2DIR|=BIT1 +BIT2;
  unsigned char x,y;
  unsigned int i=0;
  for(y=0;y<8;y++)
     Write_IIC_Command(0xb0+y);
      for(x=0;x<128;x++)
          Write_IIC_Data(show1[i++]);
/***********************Delay****************************************/
/*void Delay_50ms(unsigned int Del_50ms)
unsigned int m;
for(;Del_50ms>0;Del_50ms--)
for(m=6245;m>0;m--);
void Delay_1ms(unsigned int Del_1ms)
unsigned char j;
while(Del_1ms--)
for(j=0;j<123;j++);
/*******************************Main*******************************/
void main(void)
delay_ms(5);
fill_picture(0xff); delay_ms(1250);
fill_picture(0xf0); delay_ms(1250);
picture_1(); delay_ms(1250);
 你这样子写肯定是不行的啊,应为51单片机的IO口是双向IO,可以输出也可以读取输入,不用配置; 但是430的话就不是了,输出的话是:    2DIR|=BIT1 +BIT2;  然后使用 P2OUT |= BITx + BITx; 进行输出; 但是你要读取IO口的话,得先配置成输入模式,如:  2DIR &= ~(BIT1+BIT2);  然后读出 P2IN  的值; 给你分享一个我之前自己写的读取AT24C256 的IIC程序,可以参考一下(用的也是模拟I ...
459
1688
1688
2014-2-25
231 小时
发表于 2014-7-19 10:41:13 | 显示全部楼层
给你分享一个我之前自己写的读取AT24C256 的IIC程序,可以参考一下(用的也是模拟IIC)
i2c.h
1.37 KB, 下载次数: 92
i2c.c
4.84 KB, 下载次数: 84
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2014-7-19 16:42:21 | 显示全部楼层
这个。。木有搞过430,绑定
开往春天的手扶拖拉机
2014-9-7
发表于 2014-9-11 11:36:28 | 显示全部楼层
MSP430是对寄存器的直接操作,,,,,这51程序直接移植肯定会有问题的额
GMT+8, 2026-10-24 08:40
