查看: 8606|回复: 4
求助 F4的usart1不能用 数据发不出去
85
85
2014-7-31
发表于 2014-7-31 11:46:05 | 显示全部楼层 |阅读模式
之前一直潜水学习 今天终于遇到问题 申请个号 我用开发板的usart3能正常收发数据 但是把板子上的程序改到usart1就不行 一直卡在这 while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET){}
找到错误了 就是始终哪里弄错了 RCC_APB1PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); 1跟2不能这样用
85
85
2014-7-31
 楼主| 发表于 2014-7-31 11:46:06 | 显示全部楼层
85
85
2014-7-31
 楼主| 发表于 2014-7-31 13:47:19 | 显示全部楼层
刚在审核 我现在贴下初始化其他代码
void uart_init(void)
USART_InitTypeDef USART_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_10;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
USART_InitStructure.USART_BaudRate   = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits   = USART_StopBits_1;
USART_InitStructure.USART_Parity     = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode                = USART_Mode_Tx | USART_Mode_Rx;
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void nvic_config(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* NVIC configuration */
/* Configure the riority Group to 2 bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/* Enable the USARTx Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
85
85
2014-7-31
 楼主| 发表于 2014-7-31 13:48:21 | 显示全部楼层
int main(void)
nvic_config();
uart_init();
    printf("hello!welcome to F4...\r\n ");
然后重定向print是这样的
int fputc(int ch, FILE *f)
/* lace your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(USART1, (uint8_t) ch);
/* Loop until the end of transmission */
//while(RESET == USART_GetFlagStatus(USART1,USART_FLAG_TXE));
return ch;
85
85
2014-7-31
 楼主| 发表于 2014-7-31 13:50:17 | 显示全部楼层
不知道F4的usart1跟其他是不是不一样 我是完全按照usart3改的 但是单步调试时候一直停在while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET){}  还有个问题 USART_FLAG_TXE 跟USART_FLAG_TC是不是一样的 我网上看usart1是用USART_FLAG_TC标志 但是这里我改到USART_FLAG_TC之后 这句话是跳过去 但是还没打印出来数据
GMT+8, 2026-10-26 19:19
