查看: 13608|回复: 2
STM8L FLASH 读写问题
51
292
292
2014-3-6
31 小时
发表于 2014-9-1 14:07:54 | 显示全部楼层 |阅读模式
写了个stm8l52c6 的block读写代码,用的是IAR.按照官方提示步骤更改过RAM方面的配置:
- For IAR Compiler:
    1- Define a location FLASH_CODE before each code function by the mean of
    " #pragma location = "FLASH_CODE"".
    This location is defined in the stm8l15x_flash.c file, and it's conditionned
    by IAR_RAM_EXECUTION definifition.
  2- Uncomment the "#define IAR_RAM_EXECUTION  (1)" line in the stm8l15x.h file,
    or define it in IAR compiler preprocessor to enable the FLASH_CODE location
    definition.
  3- Edit the linker file lnkstm8l15xxx.icf available under
    "$\IAR Systems\Embedded Workbench 6.0\stm8\config\lnkstm8l15xxx.icf"
       by updating the line "initialize by copy { rw, ro section .tiny.rodata };"
       with the the following one:
       "initialize by copy { rw, ro section .tiny.rodata, section FLASH_CODE};".
  4- The speed optimization is required to ensure proper execution from RAM.
    -> In IAR Embedded workbench IDE Select Project\Options\C/C++ Compiler\Optimizations
    select speed optimization
代码如下:
#pragma location="MY_RAM_FUNC"
void LPR_Ram(void)
  uint8_t i = 0;
/* To reduce consumption to minimal
  Swith off the Flash */
  FLASH->CR1 = 0x08;
  while(((CLK->REGCSR)&0x80)==0x80);
/* Swith off the Regulator*/
  CLK->REGCSR = 0x02;
  while(((CLK->REGCSR)&0x01)==0x01);
/* Set trigger on GPIOE pin6*/
  WFE->CR2 = 0x04;
  GPIOE->CR2 = 0x44;
  for (i=0; i<100; i++);
/* To start counter on falling edge*/
//  GPIO_LOW(CTN_GPIO_PORT,CTN_CNTEN_GPIO_PIN);
/*Wait for end of counter */
  wfe();
  EXTI->SR1 |= 0x40;
  WFE->CR2 = 0x00;
  //Switch on the regulator
  CLK->REGCSR = 0x00;
  while(((CLK->REGCSR)&0x1) != 0x1);
lnkstm8l152c6.icf
initialize by copy { rw section .far.bss,
                     rw section .far.data,
                     rw section .far_func.textrw,
                     rw section .huge.bss,
                     rw section .huge.data,
                     rw section .huge_func.textrw,
                     rw section .iar.dynexit,
                     rw section .near.bss,
                     rw section .near.data,
                     rw section .near_func.textrw,
                     rw section .tiny.bss,
                     rw section .tiny.data,
                     ro section .tiny.rodata, section MY_RAM_FUNC
在Embedded Workbench 6.5里面加了这个
运行之后
Error[Lc036]: no block or place matches the pattern "ro code section MY_RAM_FUNC_init in lowpower.o"
Error[Lc036]: no block or place matches the pattern "rw code section MY_RAM_FUNC in lowpower.o"
这个是什么原因呢?有没有遇到过这样的问题,改怎么解决啊?
发表于 2014-9-1 22:58:23 | 显示全部楼层
帮顶....
54
54
2014-9-1
发表于 2014-9-10 16:14:29 | 显示全部楼层
楼主解决了吧?突然发现 这个论坛里面,好多人提问的都没有解决哦,我是新手,还没有学到flash,帮不到你。遗憾?
谦虚使人退步,短暂的激情是不值钱的,持久的激情才是赚钱的!持续改善LED电子技术研发!
GMT+8, 2026-11-12 13:02
