查看: 15798|回复: 9
TIM2 TIM3两个定时器中断 无法配置
82
82
2014-8-12
发表于 2014-11-5 16:47:40 | 显示全部楼层 |阅读模式
TIM2、TIM3两个定时器一起配置中断,无法实现。
但配置TIM2的NVIC则不会出错,但加上TIM3的NVIC则会出错。
TIM2配置
[mw_shl_code=c,true]void TIM2_Config(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; printf("\r\nTIM2_CONFIG_IN!\n"); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE); TIM_DeInit(TIM2); TIM_TimeBaseStructure.TIM_Period = 7199; TIM_TimeBaseStructure.TIM_Prescaler = 39; TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure); TIM_ClearFlag(TIM2, TIM_FLAG_Update); TIM_ITConfig(TIM2,TIM_IT_Update|TIM_IT_Trigger,ENABLE);// TIM_Cmd(TIM2, ENABLE); printf("\r\nTIM2_CONFIG_OK!\n"); } void TIM2_NVIC(void) { NVIC_InitTypeDef NVIC_InitStructure; printf("\r\nTIM2_NVIC_IN!\n"); NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1; NVIC_InitStructure.NVIC_IRQChannelSubPriority=1; NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE; NVIC_Init(&NVIC_InitStructure); }[/mw_shl_code]
TIM3配置
[mw_shl_code=c,true]void TIM3_NVIC(void) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0); NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); NVIC_InitStructure.NVIC_IRQChannel=TIM3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0; NVIC_InitStructure.NVIC_IRQChannelSubPriority=0; NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE; NVIC_Init(&NVIC_InitStructure); } void TIM3_GPIO_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; //?????¨?±?÷3???±?? RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE); //????PINA,PINB???±?? RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA,&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_Init(GPIOB,&GPIO_InitStructure); printf("\r\nTIM3 GPIO OK\n"); } void TIM3_Mode_Config(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; printf("\r\nTIM3_MODE_IN!\n"); TIM_TimeBaseStructure.TIM_Period = 35999; TIM_TimeBaseStructure.TIM_Prescaler = 39; TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure); //????TIM3?????? TIM_ClearFlag(TIM3, TIM_FLAG_Update); TIM_ITConfig(TIM3,TIM_IT_Update|TIM_IT_Trigger,ENABLE); TIM_Cmd(TIM3, ENABLE); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = servox_pulse; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM3, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable); TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = servoy_pulse; TIM_OC2Init(TIM3, &TIM_OCInitStructure); TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable); TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = servoz_pulse; TIM_OC3Init(TIM3, &TIM_OCInitStructure); TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable); // TIM_ARRPreloadConfig(TIM3, ENABLE); /* TIM3 enable counter */ printf("\r\nTIM3 MODE OK\n"); }[/mw_shl_code]
麻烦各位帮我看一下,谢谢!
回复【7楼】Croatoan: --------------------------------- 后来发现不是优先级的问题,而是中断处理函数写错了。
82
82
2014-8-12
 楼主| 发表于 2014-11-5 16:47:41 | 显示全部楼层
回复【7楼】Croatoan:
82
82
2014-8-12
回复【9楼】Croatoan:
正确: void TIM3_IRQHandler(void)   错误:正确: void TIM3_IRQnHandler(void)
多加了一个n。
81
1002
1876
1876
2014-9-10
208 小时
发表于 2014-11-5 19:33:52 | 显示全部楼层
小小蜗牛
发表于 2014-11-5 22:56:10 | 显示全部楼层
现象是什么?
82
82
2014-8-12
 楼主| 发表于 2014-11-6 09:15:26 | 显示全部楼层
回复【3楼】正点原子:
配置完毕后,TIM2可以进入有限次中断(不超过5次),然后就结束了,主函数有while(1)语句让程序循环运行的。
82
82
2014-8-12
 楼主| 发表于 2014-11-6 09:26:28 | 显示全部楼层
回复【3楼】正点原子:
用JTAG仿真单步执行,配置完后进入while循环,一次中断都没进去,停止Debug后,函数停在startup_stm32f10x_hd.s里面的B    .  指令,我用的芯片是STM32103FZET.
82
82
2014-8-12
 楼主| 发表于 2014-11-6 14:57:16 | 显示全部楼层
回复【2楼】jiutianshenjian:
去掉Printf,没有解决问题哦。
46
46
2014-9-3
发表于 2014-11-13 14:30:16 | 显示全部楼层
使用F407也 出现过这种问题,貌似是优先级问题?
46
46
2014-9-3
发表于 2014-11-13 17:03:32 | 显示全部楼层
回复【8楼】iseafish:
--------------------------------求分享错误程序,我当时重新写了一个绕过去了。。还不知道哪里错了
GMT+8, 2026-10-29 19:12
