查看: 11852|回复: 9
请教仿真问题
58
286
815
815
2012-3-29
81 小时
发表于 2012-4-2 09:13:47 | 显示全部楼层 |阅读模式
    用仿真的时候出现这样的错误:*** error 65: access violation at 0x0000000C : no 'read' permission。是哪里设置出了问题呢?我在keil里面已经设置仿真了。
86
984
1852
1852
2013-4-15
164 小时
发表于 2015-10-27 21:07:40 | 显示全部楼层
回复【9楼】小学生一号:
我调试是M0+内核的STM32L051K6T6
Dialog DLL 分别为:DARMSTM.DLL
和 TARMSTM.DLL, arameter 均为: -pSTM32L051K6
可还是报同样的错误
合肥-文盲
回复 支持 1 反对 0
64
64
2012-4-2
14 小时
发表于 2012-4-2 09:54:02 | 显示全部楼层
回复【楼主位】业未央:
CAUSE
When the ?Vision Debugger loads an executable program, it creates a memory map using the program and data segments from the program. Code segments are marked as executable while data segments are marked as read/write. All other memory is unmapped and is, therefore, not marked for any type of access.
The ?Vision Debugger checks that all memory accesses are made to objects that are defined in your C program. For any access that is outside of a defined C object, the ?Vision debugger generates an error 65: access violation message.
By default, the debugger allows only memory accesses to valid data objects. This is useful for finding uninitialized or incorrectly initialized pointers, for example. Usually, there is a programming error when you try to access unexpected locations.
RESOLUTION
Enable memory regions for absolute memory accesses using the MAP debugger command or the Debug - Memory Map dialog. Define all the memory ranges that your program is permitted to access. Ensure that you set the permissions (read, write, execute) for each range to match your actual hardware.
You may put the required MAP commands into a debugger INI file that can be entered under roject -> Options for Target -> Debug -> Initialization file. For example, the content of such a file may be:
MAP  0xF800, 0xF8FF  READ WRITE  // allow R/W access to IO space
试下
发表于 2012-4-2 10:50:40 | 显示全部楼层
58
286
815
815
2012-3-29
81 小时
 楼主| 发表于 2012-4-4 23:19:24 | 显示全部楼层
回复【3楼】正点原子:
嗯
58
286
815
815
2012-3-29
81 小时
 楼主| 发表于 2012-4-4 23:25:56 | 显示全部楼层
回复【2楼】mculove:
在JLinkSettings.ini中添加吗?
79
167
167
2012-8-7
发表于 2012-8-13 10:18:13 | 显示全部楼层
我也遇到了这个问题,请问楼主解决了吗????????解决了分享下哦。。。
【好好学习天天向上】
48
48
2015-2-12
发表于 2015-4-8 11:55:46 | 显示全部楼层
我用keil5 仿真 选use Simulator 然后debug就出现这个错误,使用keil4 时没有问题的,有哪位大神知道怎么解决了吗?
48
48
2015-2-12
发表于 2015-4-8 15:26:34 | 显示全部楼层
找到一个解决问题的,楼主说是在原子哥视频里有讲过,我还没找到视频里说的那段,不过确实解决我的问题了,分享给大家。 http://blog.csdn.net/stephen_yu/article/details/7725247
50
2017-9-6
23 小时
发表于 2017-9-7 14:41:05 | 显示全部楼层
合肥-文盲 发表于 2015-10-27 21:07
回复【9楼】小学生一号:
Dialog&nbsp ...
请问应该怎么设置呢 谢谢了
GMT+8, 2026-10-31 08:55
