查看: 7157|回复: 3
C8051f340的clock用timer1来控制,时钟频率控制的问题
37
37
2015-1-5
发表于 2015-1-5 19:44:37 | 显示全部楼层 |阅读模式
我这个timer1时钟对其设置时钟频率怎么不对啊,怎么改?我就想输入50000的时候时钟频率就是50k(Hz)输入30000就是30k(Hz)
#define SYSCLS 12000000
void Timer1_Init(ulong SMB_FQ)
    uchar SCALE;
    if ((SYSCLS/SMB_FQ/3) < 255)
        SCALE = 1;
        CKCON |= 0x08 ;
    else if ((SYSCLS/SMB_FQ/3/4) < 255)//使用4分频
        SCALE = 4;
        CKCON |= 0x01;
        CKCON &= ~0x0A;
    else if ((SYSCLS/SMB_FQ/3/8) < 255)//使用8分频
        SCALE = 8;
        CKCON |= 0x03;
        CKCON &= ~0x08;
    else if ((SYSCLS/SMB_FQ/3/12) < 255)//使用12分频
        SCALE = 12;
        CKCON |= 0x03;
        CKCON &= ~0x0B;
    else if ((SYSCLS/SMB_FQ/3/48) < 255)//使用48分频
        SCALE = 48;
        CKCON |= 0x03;
        CKCON &= ~0x09;
    TMOD = 0x20;
    TH1  = 256 -(SYSCLS/SMB_FQ/SCALE/12);
    TL1  = TH1;
    TR1  = 1;
发表于 2015-1-5 22:46:22 | 显示全部楼层
帮顶....
37
37
2015-1-5
 楼主| 发表于 2015-1-6 10:22:20 | 显示全部楼层
回复【2楼】正点原子:
原子哥,这个clock能设置出来了,但是有个问题,见下楼
37
37
2015-1-5
 楼主| 发表于 2015-1-6 11:26:55 | 显示全部楼层
这里用到预分频计数器,看资料是说Timer1 configured to overflow at 1/3 the rate defined by SMB_FREQUENCY,但是为什么scl的最大频率为timer1的溢出频率的三分之一啊?                                       现在已经可以随意改时钟了,就是这个问题没解决,代码如下
     PCA0MD &= ~0x40;    //stop WDT
    OSCICN |= 0x83;        //SYSCLK为内部高频正当期输出
    RSTSRC = 0x04;        //使能丢失时钟监测器
   uchar SCALE = 1;
        SCALE = 1;
        CKCON |= 0x08 ;
        SCALE = 4;
        CKCON |= 0x01;
        CKCON &= ~0x0A;
        SCALE = 8;
        CKCON |= 0x03;
        CKCON &= ~0x08;
        SCALE = 12;
        CKCON |= 0x03;
        CKCON &= ~0x0B;
        SCALE = 48;
        CKCON |= 0x03;
        CKCON &= ~0x09;
    CKCON |= 0x08 ;
    TMOD = 0x20;
    TH1  = -(SYSCLS/SMB_FQ/3/SCALE);
    TL1  = TH1;
    TR1  = 1;
GMT+8, 2026-11-14 09:03
