查看: 11194|回复: 7
大家对四轴的YAW是怎么处理的
43
124
124
2013-10-7
发表于 2015-1-22 18:28:47 | 显示全部楼层 |阅读模式
我看很多资料多数是四元数处理。例子如下
void IMUupdate(float gx, float gy, float gz, float ax, float ay, float az)
  float norm;
//int16_t Xr,Yr;
  float vx, vy, vz;// wx, wy, wz;
  float ex, ey, ez;
  float q0q0 = q0*q0;
  float q0q1 = q0*q1;
  float q0q2 = q0*q2;
  //  float q0q3 = q0*q3;//
  float q1q1 = q1*q1;
  //  float q1q2 = q1*q2;//
  float q1q3 = q1*q3;
  float q2q2 = q2*q2;
  float q2q3 = q2*q3;
  float q3q3 = q3*q3;
if(ax*ay*az==0)
  return;
  norm = Q_rsqrt(ax*ax + ay*ay + az*az);       //acc?????é????
  ax = ax *norm;
  ay = ay * norm;
  az = az * norm;
  // estimated direction of gravity and flux (v and w)              ????????·??ò???÷??/±??¨
  vx = 2*(q1q3 - q0q2); //????????xyz??±í??
  vy = 2*(q0q1 + q2q3);
  vz = q0q0 - q1q1 - q2q2 + q3q3 ;
  // error is sum of cross product between reference direction of fields and direction measured by sensors
  ex = (ay*vz - az*vy) ;                           //?ò?????????à????????·??????ó??
  ey = (az*vx - ax*vz) ;
  ez = (ax*vy - ay*vx) ;
  exInt = exInt + VariableParameter(ex) * ex * Ki;  //???ó????????·?
  eyInt = eyInt + VariableParameter(ey) * ey * Ki;
  ezInt = ezInt + VariableParameter(ez) * ez * Ki;
// adjusted gyroscope measurements
  gx = gx + Kp *  VariableParameter(ex) * ex + exInt;
gy = gy + Kp *  VariableParameter(ey) * ey + eyInt;
gz = gz + Kp *  VariableParameter(ez) * ez + ezInt;
  // integrate quaternion rate and normalise   //??????????·?·???
  q0 = q0 + (-q1*gx - q2*gy - q3*gz)*halfT;
  q1 = q1 + (q0*gx + q2*gz - q3*gy)*halfT;
  q2 = q2 + (q0*gy - q1*gz + q3*gx)*halfT;
  q3 = q3 + (q0*gz + q1*gy - q2*gx)*halfT;
  // normalise quaternion
  norm = Q_rsqrt(q0q0 + q1q1 + q2q2 + q3q3);
  q0 = q0 * norm;
  q1 = q1 * norm;
  q2 = q2 * norm;
  q3 = q3 * norm;
   qa0 = q0;
  qa1 = q1;
  qa2 = q2;
  qa3 = q3;
  angle.roll = atan2(2*q2q3 + 2*q0q1, -2*q1q1 - 2*q2q2 + 1); // roll
angle.pitch = asin(-2*q1q3 + 2*q0q2); // pitch
/*????  http://baike.baidu.com/view/1239157.htm?fr=aladdin */
//Xr = X_HMC * COS(angle.pitch/AtR) + Y_HMC * SIN(-angle.pitch/AtR) * SIN(-angle.roll/AtR) - Z_HMC * COS(angle.roll/AtR) * SIN(-angle.pitch/AtR);
//Yr = Y_HMC * COS(angle.roll/AtR) + Z_HMC * SIN(-angle.roll/AtR);
//angle.yaw = atan2((double)Yr,(double)Xr) * RtA; // yaw
angle.yaw  = atan2(2*(q1*q2 + q0*q3),q0*q0+q1*q1-q2*q2-q3*q3) * RtA;
angle.roll *= RtA;
angle.pitch *= RtA;
但是我发现YAW角度一只在漂移,平均每5秒偏向0.1度左右,我查过很多资料说是MPU6050的一个硬件缺陷,应该用地磁来补偿误差例如HWM5883l,大家的看法的看法是怎么样的?
146
896
896
2014-1-2
156 小时
发表于 2015-1-22 18:48:05 | 显示全部楼层
感觉YAW直接用陀螺仪数据积分会挺好的(小四轴)。
68
版主
114
114
2014-12-25
发表于 2015-1-22 20:53:34 | 显示全部楼层
mpu6000本来就不是计算航向的,这不算是它的缺陷,陀螺仪本就有温漂。
165779
165779
发表于 2015-1-22 21:48:42 | 显示全部楼层
68
版主
114
114
2014-12-25
发表于 2015-1-23 18:41:11 | 显示全部楼层
mpu6000矫正得好,航向漂移做个业余的完全可以接受。航向要是矫正不好或者处理不完善的话还不如不要磁航向。当然,能处理好,当然是最好了。
225
623
623
2014-7-8
26 小时
发表于 2015-1-26 19:39:20 | 显示全部楼层
额。。一般小四不用罗盘,效果不好。。。
67
99
99
2013-10-5
发表于 2015-2-22 23:03:51 | 显示全部楼层
回复【4楼】正点原子:
用磁力计又很容易受软磁、硬磁干扰 好难矫正
165779
165779
发表于 2015-2-26 18:28:53 | 显示全部楼层
回复【7楼】岁月已无声:
这个我也没有研究了,呵呵。
GMT+8, 2026-10-23 07:04
