查看: 6636|回复: 2
请教各路神仙stm32f0 DMA传送数据到外设TIM1遇到的奇怪问题
2015-2-15
发表于 2015-2-15 16:20:40 | 显示全部楼层 |阅读模式
我希望通过DMA 把Buffer数组的值传到TIM1的CCR3,但发现每次传过去的值都不对。为了方便debug,我把DMA_InitStructure.DMA_BufferSize设为1,如果Buffer[0]=0x01,则TIM1_DMAR和TIM1_CCR3的值变成0x0101,如果Buffer[0]=0x1234,则TIM1_DMAR和TIM1_CCR3的值变成0x3434,DMA传送的时候把我的数据的高8位丢掉了,然后高8位的值变成了低8位的复制。我又把DMA关掉,发现TIM1_DMAR和TIM1_CCR3的值又是正常的。因此怀疑是DMA的问题,但又不知道问题出在哪里?请各位大侠指点,多谢!
代码如下:
uint16_t Buffer[10] = { 0x1234, 164, 328, 328 , 164, 164, 164, 164, 328, 328 };
void TIM1_Init(void)
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  TIM_ARRPreloadConfig(TIM1, ENABLE);
  TIM_OCInitTypeDef TIM_OCInitStructure;
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 164;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Disable);
  TIM_DMAConfig(TIM1, TIM_DMABase_CCR3, TIM_DMABurstLength_1Byte);
  TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
  TIM_Cmd(TIM1, ENABLE);
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
static void DMA_Config(void)
  DMA_InitTypeDef DMA_InitStructure;
  DMA_DeInit(DMA1_Channel5);
  DMA_StructInit(&DMA_InitStructure);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM1_DMAR_ADDRESS;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)Buffer;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel5, &DMA_InitStructure);
  DMA_ITConfig(DMA1_Channel5, DMA_IT_TC | DMA_IT_TE, ENABLE);
  DMA_ClearITPendingBit(DMA1_IT_TC5);
static void NVIC_Configuration(void)
  NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel4_5_6_7_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
int main(void)
  RCC_Configuration();
  GPIO_InitTypeDef  GPIO_InitStructure;
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOC | RCC_AHBPeriph_DMA1, ENABLE);
  delay_nms(100);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG | RCC_APB2Periph_TIM1, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_2);
  NVIC_Configuration();
  DMA_Config();
  TIM1_Init();
  DMA_Cmd(DMA1_Channel5, ENABLE);
  while (1)
    delay_nms(100);
发表于 2015-2-16 15:12:07 | 显示全部楼层
帮顶....
2017-7-20
发表于 2017-8-1 09:43:48 | 显示全部楼层
我想请教个问题,为什么用DMA的通道5可以,其他通道不可以呢?
GMT+8, 2026-10-30 09:36
