查看: 11729|回复: 6
Vs1053的 驱动代码直接可以用在VS1003芯片上吗?
54
152
152
2012-6-10
发表于 2015-3-14 15:33:00 | 显示全部楼层 |阅读模式
我从旗舰版移植过来的VS10XX的驱动代码(旗舰版是Vs1053), 移植到 F407开发板上。外部拉几根杜邦线连到是VS1003芯片模块。 不知道为什么一直不行? 正选波测试的时候 有 2下声音输出。 后面就没有任何东西了。 程序在旗舰版上测试 连接 VS1053正常的。
是不是VS1053和VS1003 的驱动不通用?
这个是F407上 对 XDCS  XCS 和DREQ的 初始化
[mw_shl_code=c,true]void VS_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC|RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOE|RCC_AHB1Periph_GPIOF, ENABLE); //使能PB端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //PC13 dreq GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//输入功能 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //速度50MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉 GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //PE6 RST GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOB, &GPIO_InitStructure); //PF6,PF7 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOC, &GPIO_InitStructure); SPI1_Init(); } [/mw_shl_code]
以下是 SPI初始化端口
[mw_shl_code=c,true]void SPI1_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOB, ENABLE );//PORTB时钟使能 RCC_APB2PeriphClockCmd( RCC_APB2Periph_SPI1, ENABLE );//SPI1时钟使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度50MHz GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉 GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOB,GPIO_PinSource3,GPIO_AF_SPI1); //PB3复用为 SPI1 GPIO_PinAFConfig(GPIOB,GPIO_PinSource4,GPIO_AF_SPI1); //PB4复用为 SPI1 GPIO_PinAFConfig(GPIOB,GPIO_PinSource5,GPIO_AF_SPI1); //PB5复用为 SPI1 // //这里只针对SPI口初始化 // RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//复位SPI1 // RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//停止复位SPI1 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平 SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //定义波特率预分频的值:波特率预分频值为256 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 SPI_Cmd(SPI1, ENABLE); //使能SPI外设 SPI1_ReadWriteByte(0xff);//启动传输 } [/mw_shl_code]
驱动通用的 你检查送给VS1003的数据正常不 能听到正弦测试的声音,说明底层驱动基本OK了。
发表于 2015-3-14 15:33:01 | 显示全部楼层
驱动通用的
你检查送给VS1003的数据正常不
54
152
152
2012-6-10
 楼主| 发表于 2015-3-14 15:33:01 | 显示全部楼层
回复【2楼】正点原子:
可以了 。  是我吧 SPI 低速模式 设置成256分频  SPI 高速模式设置成2分频了,, 修改成  32 和8 分频就可以了 。。既然没注意到,失误啊~
61
61
2015-7-22
发表于 2015-11-25 08:34:21 | 显示全部楼层
回复【3楼】幽灵骑士:
能不能共享一下你的VS1003的程序啊?我最近也遇到很多个问题啊!
你要知道别人已经很优秀却还那么努力,你凭什么停下你的脚步去骄傲。。。。。。
23
131
329
329
2015-6-23
68 小时
发表于 2016-5-8 23:43:49 | 显示全部楼层
我播AVI视音频交错文件时,图像显示正常,但没有声音,放到计算机上播是都有的,然后我用例程的MP3音乐代替AVI中的MP3声音数据就能放出声音了,一直不知道为什么?
174
174
2014-12-10
42 小时
发表于 2016-12-3 15:53:38 | 显示全部楼层
正点原子 发表于 2015-3-14 15:33
驱动通用的
你检查送给VS1003的数据正常不
原子哥,我也是外接VS1003到mini板上,用你们的程序,我能听到正弦的声音,但是总是说MUSIC文件夹错误,解决方法,我先把SD卡的时钟线拔掉,等读取完字库后再把W25Q64的时钟线拔掉同时把SD卡的时钟线插上,接下来再把W25Q64的时钟线插上就正常播放了,请问是什么问题?好急啊,几天都解决不了,麻烦你了
127
127
2017-8-29
37 小时
发表于 2017-8-30 17:31:45 | 显示全部楼层
能不能分享下源程序啊  最近也在弄相同的东西
GMT+8, 2026-10-31 07:12
