查看: 13427|回复: 14
有关SPI的双机通信
85
132
132
2014-8-14
发表于 2015-3-20 15:41:25 | 显示全部楼层 |阅读模式
两个f407用SPI进行通信,一个主机,一个从机,我是这样想的,主机先发送一个字节0xff,告诉从机要通信了,从机接到数据,进入接收缓存区非空中断,在中断中发送一个字节0xa0,同时主函数接收,但是接收到的数据左移了一位,请问是什么原因呢?
[mw_shl_code=c,true]void spi1_init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOA时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);//使能SPI1时钟 //GPIOFB3,4,5初始化设置 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;//PB3~5复用功能输出 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//PB3~5复用功能输出 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化 GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_SPI1); //PA5复用为 SPI1_SCK GPIO_PinAFConfig(GPIOB,GPIO_PinSource4,GPIO_AF_SPI1); //PB4复用为 SPI1_MISO GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_SPI1); //PA7复用为 SPI1_MOSI //GPIO_PinAFConfig(GPIOA,GPIO_PinSource15,GPIO_AF_SPI1); //PA15复用为 SPI1_NSS //这里只针对SPI口初始化 RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//复位SPI1 RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//停止复位SPI1 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Slave; //设置SPI工作模式:设置为主SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平 SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //定义波特率预分频的值:波特率预分频值为256 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 NVIC_InitStructure.NVIC_IRQChannel = SPI1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); //SPI_TIModeCmd(SPI1, ENABLE); SPI_ITConfig(SPI1, SPI_I2S_IT_RXNE, ENABLE); SPI_Cmd(SPI1, ENABLE); //使能SPI外设 } [/mw_shl_code]
最近没吃药,感觉自己萌萌哒!
85
132
132
2014-8-14
 楼主| 发表于 2015-3-20 15:45:49 | 显示全部楼层
上边是spi从机配置,下边是从机中断函数
[mw_shl_code=c,true]u8 SPI1_RX[3]; void SPI1_IRQHandler(void) { if (SPI_GetITStatus(SPI1,SPI_I2S_IT_RXNE) != RESET) { SPI_ClearITPendingBit(SPI1,SPI_I2S_IT_RXNE); SPI1_ReadWriteByte(0xa0); // SPI1_RX[1] = SPI1_ReadWriteByte(0x77); // SPI1_RX[2] = SPI1_ReadWriteByte(0x88); } return; }[/mw_shl_code]
从机主函数是while死循环
主机没有中断函数,配置如下
[mw_shl_code=c,true]void spi1_init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; // NVIC_InitTypeDef NVIC_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOA时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);//使能SPI1时钟 //GPIOFB3,4,5初始化设置 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;//PB3~5复用功能输出 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//PB3~5复用功能输出 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化 GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_SPI1); //PA5复用为 SPI1_SCK GPIO_PinAFConfig(GPIOB,GPIO_PinSource4,GPIO_AF_SPI1); //PB4复用为 SPI1_MISO GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_SPI1); //PA7复用为 SPI1_MOSI GPIO_PinAFConfig(GPIOA,GPIO_PinSource15,GPIO_AF_SPI1); //PA15复用为 SPI1_NSS //这里只针对SPI口初始化 RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//复位SPI1 RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//停止复位SPI1 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平 SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //定义波特率预分频的值:波特率预分频值为256 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 // NVIC_InitStructure.NVIC_IRQChannel = SPI1_IRQn; // NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; // NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; // NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; // NVIC_Init(&NVIC_InitStructure); //SPI_TIModeCmd(SPI1, ENABLE); //SPI_ITConfig(SPI1, SPI_I2S_IT_RXNE, ENABLE); SPI_Cmd(SPI1, ENABLE); //使能SPI外设 } [/mw_shl_code]
主机的主函数:
[mw_shl_code=c,true]int main() { NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2 delay_init(168); uart_init(115200); //初始化串口波特率为115200 spi1_init(); SPI1_SetSpeed(SPI_BaudRatePrescaler_8); //设置为42M时钟,高速模式 // spi1_dma_init((u32)SPI1_RX_Buff, (u32)SPI1_TX_Buff, 10, 10); // spi1_dma_enable(); SPI1_ReadWriteByte(0xff); while(1) { temp[1] = SPI1_ReadWriteByte(0xff); delay_ms(10); temp[2] = SPI1_ReadWriteByte(0xff); delay_ms(10); temp[3] = SPI1_ReadWriteByte(0xff); delay_ms(10); } }[/mw_shl_code]
最近没吃药,感觉自己萌萌哒!
85
132
132
2014-8-14
 楼主| 发表于 2015-3-20 15:49:06 | 显示全部楼层
这个是spi双机通信的keil工程
spi双机通信.zip
7.74 MB, 下载次数: 6494
最近没吃药,感觉自己萌萌哒!
发表于 2015-3-20 22:46:46 | 显示全部楼层
85
132
132
2014-8-14
 楼主| 发表于 2015-3-23 07:56:22 | 显示全部楼层
回复【4楼】正点原子:
可以,就是从机给主机发送的数据左移了一位
最近没吃药,感觉自己萌萌哒!
发表于 2015-3-23 16:13:41 | 显示全部楼层
回复【5楼】barryotugh:
额额
50
148
148
2014-5-10
12 小时
发表于 2015-3-24 16:08:35 | 显示全部楼层
回复【5楼】barryotugh:
这个问题我以前遇到过,时钟问题,没法解决。改成发送方主动切换成Master模式。至于何时切换,用一个IO口通知,协议根据应用定义了。
85
132
132
2014-8-14
 楼主| 发表于 2015-3-25 15:15:32 | 显示全部楼层
回复【7楼】jinfeng:
那这样的话,就不能全双工通信了是不是
最近没吃药,感觉自己萌萌哒!
50
148
148
2014-5-10
12 小时
发表于 2015-3-25 20:58:32 | 显示全部楼层
回复【8楼】barryotugh:
是的,如果是同一个厂家的芯片获取可以做到。但是不同的厂家的话就不一定了。
2016-3-15
发表于 2016-3-15 16:23:35 | 显示全部楼层
请问楼主,为什么作为从机的时钟还需要进行设置呢?从机的时钟不是由主机来提供的吗
225
225
2015-7-9
85 小时
发表于 2016-7-23 21:06:59 | 显示全部楼层
从机时钟需要配置,但是通信用主机时钟,从机时钟口变成主机时钟的输入口。但从机时钟配置不得高于主机时钟,主机时钟不得高于从机的最高时钟。
134
134
2016-9-6
25 小时
发表于 2017-2-16 09:06:36 | 显示全部楼层
jinfeng 发表于 2015-3-24 16:08
回复【5楼】barryotugh:
这个问题我以前遇到过,时钟问题,没法解 ...
你好,我现在也用双机SPI通信,可是在从机切换为主机后需要延时才能继续发送数据,你有遇到这种问题吗?
2017-4-7
21 小时
发表于 2017-6-10 15:57:42 | 显示全部楼层
jinfeng 发表于 2015-3-25 20:58
回复【8楼】barryotugh:
是的,如果是同一个厂家的芯片获取可以做到。 ...
stm32f7和stm32f1之间,能不能进行spi的双机通信?两者的主频不一样。
50
148
148
2014-5-10
12 小时
发表于 2017-9-9 16:27:00 | 显示全部楼层
这个最好找懂硬件的,做FPGA的人去问,或者去这种论坛去问。
50
148
148
2014-5-10
12 小时
发表于 2017-9-9 16:27:12 | 显示全部楼层
GMT+8, 2026-10-31 08:55
