查看: 5900|回复: 1
单片机通讯遇到的问题
53
53
2015-3-22
发表于 2015-3-31 10:30:01 | 显示全部楼层 |阅读模式
两单片机通信,STC15F2k60s2作为主机,STC80C52RC作为从机,操作主机,从机数据传输不对应,求解
主机程序
#include <stc15.h>     //15系列单片机头文件
#define uchar unsigned char
#define uint unsigned int
sbit buzzer=P4^1;
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)      //i=xms即延时约xms毫秒
for(j=110;j>0;j--);
/************蜂鸣器*****************/
void di()
  buzzer=0;
  delayms(60);
  buzzer=1;
void send(uchar key_num)
 // di();
  SBUF=key_num;
  while(!TI);
  TI=0;
void matrixkeyscan()
uchar temp,key;
    P1=0xfe;
    temp=P1;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delayms(10);
 temp=P1;
 temp=temp&0xf0;
      if(temp!=0xf0)
        temp=P1;
        switch(temp)
          case 0xee:
  key=1;
               break;
          case 0xde:
  key=2;
               break;
          case 0xbe:
  key=3;
               break;
          case 0x7e:
    key=4;
               break;
         while(temp!=0xf0)
           temp=P1;
           temp=temp&0xf0;
// di();
send(key);
    P1=0xfd;
    temp=P1;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delayms(10);
      temp=P1;
      temp=temp&0xf0;
      if(temp!=0xf0)
        temp=P1;
        switch(temp)
          case 0xed:
  key=5;
               break;
          case 0xdd:
  key=6;
               break;
          case 0xbd:
  key=7;
               break;
          case 0x7d:
  key=8;
               break;
         while(temp!=0xf0)
           temp=P1;
           temp=temp&0xf0;
send(key);
    P1=0xfb;
    temp=P1;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delayms(10);
     temp=P1;
      temp=temp&0xf0;
      if(temp!=0xf0)
        temp=P1;
        switch(temp)
          case 0xeb:
  key=9;
               break;
          case 0xdb:
  key=10;
               break;
          case 0xbb:
  key=11;
               break;
          case 0x7b:
      key=12;
               break;
         while(temp!=0xf0)
           temp=P1;
           temp=temp&0xf0;
send(key);
    P1=0xf7;
    temp=P1;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delayms(10);
      temp=P1;
      temp=temp&0xf0;
      if(temp!=0xf0)
        temp=P1;
        switch(temp)
          case 0xe7:
  key=13;
               break;
          case 0xd7:
  key=14;
               break;
          case 0xb7:
  key=15;
               break;
          case 0x77:
  key=16;
               break;
         while(temp!=0xf0)
           temp=P1;
           temp=temp&0xf0;
send(key);
void main()
TI=0;
TMOD=0x20;//设置定时器1为工作方式2
SCON=0x50;
AUXR=0x00;
TH1=0xfd; //波特率设置为9600
TL1=0xfd;
TR1=1;
EA=1;
ES=1;
matrixkeyscan();//不停调用键盘扫描程序
从机程序:
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit buzzer=P2^3;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uint i,j;
for(j=110;j>0;j--);
void di()
  buzzer=0;
  delayms(60);
  buzzer=1;
void display(uchar num)
  P0=table[num];
  dula=1;
  dula=0;
//  di();
void main()
TMOD=0x20;
SCON=0x50;
PCON=0x80;
// AUXR=0x00;
TH1=0xfd;
TL1=0xfd;
TR1=1;
SM0=0;
SM1=1;
REN=1;
EA=1;
ES=1;
P0=0xc0;
wela=1;
wela=0;
P0=table[10];
// di();
while(1);
void serial() interrupt 4
    uchar a;
// di();
RI=0;
a=SBUF;
    display(a);
90
90
2012-9-10
发表于 2015-3-31 14:12:56 | 显示全部楼层
问题重点不突出。
GMT+8, 2026-11-14 09:02
