查看: 15919|回复: 5
通过FSMC与FPGA进行通信
84
84
2015-2-7
发表于 2015-4-6 20:32:01 | 显示全部楼层 |阅读模式
芯片型号:STM32F407VG,100脚
把FPGA当做SRAM,407对其进行读写,配置如下:
原理图上是24根数据/地址线外加cs,oe,we与fpga相连,系统时钟168M
#define Bank1_SRAM1_ADDR    ((u32)(0x60000000))
//初始化外部SRAM
void FSMC_SRAM_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE, ENABLE);//使能PD,PE时钟
RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);//使能FSMC时钟
//GPIO_InitStructure.GPIO_Pin = (3<<0)|(3<<4)|(1<<7)|(0XFF<<8);//PD0,1, 4,5, 7, 8~15 AF OUT
GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_7
                             |GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化
// GPIO_InitStructure.GPIO_Pin = 0X3FFF<<2;//PE2~15,AF OUT
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8
GPIO_Init(GPIOE, &GPIO_InitStructure);//初始化
GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);//PD0,AF12
GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);//PD1,AF12
GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource7,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource11,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource12,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC);//PD15,AF12
GPIO_PinAFConfig(GPIOE,GPIO_PinSource2,GPIO_AF_FSMC);//PE2,AF12
GPIO_PinAFConfig(GPIOE,GPIO_PinSource3,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource4,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource5,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource6,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC);//PE15,AF12
readWriteTiming.FSMC_AddressSetupTime = 0x00; //地址建立时间(ADDSET)为1个HCLK 1/36M=27ns
readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(ADDHLD)模式A未用到
readWriteTiming.FSMC_DataSetupTime = 0x08; //数据保持时间(DATAST)为9个HCLK 6*9=54ns
readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
readWriteTiming.FSMC_CLKDivision = 0x08;
readWriteTiming.FSMC_DataLatency = 0x00;
readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A; //模式A
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;//这里我们使用NE1,也就对应BTCR[0],[1]。
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Enable;  //地址和数据复用数据线
FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;  //SRAM
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;//突发访问模式
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; //设置WAIT信号的有效电平
FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait= FSMC_AsynchronousWait_Disable;//是否使用异步等待信号
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;   //是否使用回环模式
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;  //设置WAIT信号有效时机
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; //存储器写使能
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;  //是否使用WAIT信号
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; //是否使用扩展模式,扩展模式用于访问不同读写操作时序的存储器
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;  //是否使用迸发写模式
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming; //读写同样时序
    FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //初始化FSMC配置
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);  // 使能BANK1区域1
在main函数里对地址0x60000000地址进行读写
目前的问题是,别说读写数据了,连最基本的CS,OE,WE信号都没有,请各位大侠帮忙分析一下原因
建议参考下别人的LCD代码,比如骤雨龙元的 F407开发板就有FSMC配置,用的也是VGT6,参考下他的了。论坛有,自己搜索。
发表于 2015-4-6 20:32:02 | 显示全部楼层
84
84
2015-2-7
 楼主| 发表于 2015-4-6 20:32:02 | 显示全部楼层
已经解决,按照NOR flash或者PSRAM都可以实现与FPGA的通信,前期是示波器没有调节好
89
89
2016-8-5
27 小时
发表于 2016-9-16 09:21:10 | 显示全部楼层
163luheng 发表于 2015-4-6 20:32
已经解决,按照NOR&nbsp;flash或者PSRAM都可以实现与FPGA的通信,前期是示波器没有调节好
楼主,可以说一下怎么做的吗?
70
844
844
2016-1-5
208 小时
发表于 2017-7-4 18:14:07 | 显示全部楼层
你好 怎么用示波器调试呀
2017-8-7
发表于 2017-8-7 19:57:04 来自手机 | 显示全部楼层
请问FPGA用的是什么类型的?
GMT+8, 2026-10-30 21:52
