查看: 10859|回复: 4
STM32F407用FSMC配置LCD失败,求指教
98
366
366
2012-5-23
123 小时
发表于 2015-4-21 09:33:03 | 显示全部楼层 |阅读模式
以下是端口及FSMC配置。LCD指令没有问题,STM32F103测试过,可以点亮液晶屏。液晶RS端口用的FSMC的A16,也就是PD11, [mw_shl_code=c,true]使用NE1,液晶寄存器地址为0x60000000,数据地址为0x60020000。请教这样配置是否有问题。[/mw_shl_code]
[mw_shl_code=c,true]GPIO_InitTypeDef GPIO_InitStructure; FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure; FSMC_NORSRAMTimingInitTypeDef readWriteTiming; FSMC_NORSRAMTimingInitTypeDef writeTiming; /* Enable the FSMC Clock */ RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);//使能FSMC时钟 /* Enable the gpio clock */ RCC_APB1PeriphClockCmd( RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE , ENABLE); /* BL PA1*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;//PA1 推挽输出,控制背光 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//50MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化 //PA1 推挽输出,控制背光 /* RESET PD13*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;//PD13 推挽输出,控制复位 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//50MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化 //PD13 /*FSMC * data lines,FSMC-D0~D15: PD 14 15 0 1,PE 7 8 9 10 11 12 13 14 15,PD 8 9 10 * PD4-FSMC_NOE CD-RD * PD5-FSMC_NWE CD-WR * PD7-FSMC_NE1 CD-CS * PD11-FSMC_A16 CD-DC */ //PD0,1,8,9,10,14,15 AF OUT GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10| GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化 //PE 7-15 AF OUT GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOE, &GPIO_InitStructure);//初始化 GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC); /* SRAM Address lines configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_Init(GPIOF, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOD,GPIO_PinSource11, GPIO_AF_FSMC); /* NOE and NWE configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 |GPIO_Pin_5; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOD,GPIO_PinSource4, GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource5, GPIO_AF_FSMC); /* NE1 configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOD, GPIO_PinSource7, GPIO_AF_FSMC); // /* tft control gpio init */ // GPIO_SetBits(GPIOA, GPIO_Pin_1); // BL = 1 // GPIO_SetBits(GPIOD, GPIO_Pin_4); // RD = 1 // GPIO_SetBits(GPIOD, GPIO_Pin_5); // WR = 1 // GPIO_SetBits(GPIOD, GPIO_Pin_7); // CS = 1 // GPIO_SetBits(GPIOD, GPIO_Pin_11); // RS // GPIO_SetBits(GPIOD, GPIO_Pin_13); // RST readWriteTiming.FSMC_AddressSetupTime = 0XF; //地址建立时间(ADDSET)为16个HCLK 1/168M=6ns*16=96ns readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(ADDHLD)模式A未用到 readWriteTiming.FSMC_DataSetupTime = 60; //数据保存时间为60个HCLK =6*60=360ns readWriteTiming.FSMC_BusTurnAroundDuration = 0x00; readWriteTiming.FSMC_CLKDivision = 0x00; readWriteTiming.FSMC_DataLatency = 0x00; readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A; //模式A writeTiming.FSMC_AddressSetupTime =9; //地址建立时间(ADDSET)为9个HCLK =54ns writeTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(A writeTiming.FSMC_DataSetupTime = 8; //数据保存时间为6ns*9个HCLK=54ns writeTiming.FSMC_BusTurnAroundDuration = 0x00; writeTiming.FSMC_CLKDivision = 0x00; writeTiming.FSMC_DataLatency = 0x00; writeTiming.FSMC_AccessMode = FSMC_AccessMode_A; //模式A FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;// 这里我们使用NE1 FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; // 不复用数据地址 FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM; //SRAM //FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_NOR;// FSMC_MemoryType_SRAM; //SRAM FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable; FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; // 存储器写使能 FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable; FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable; // 读写使用不同的时序 FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable; FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; //读写时序 FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &writeTiming; //写时序 FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); //初始化FSMC配置 FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE); // 使能BANK1 [/mw_shl_code]
发表于 2015-4-21 23:51:55 | 显示全部楼层
参考下我们的例程。
98
366
366
2012-5-23
123 小时
 楼主| 发表于 2015-4-22 08:23:19 | 显示全部楼层
回复【2楼】正点原子:
我这个就是参考的原子哥的例程配置的。昨天晚上量了下端口电压,发现端口根本没有翻转。JTAG仿真内部工作是正常的,1S的延时很准确。
38
110
110
2017-7-13
27 小时
发表于 2017-9-15 14:03:51 | 显示全部楼层
119
332
332
2016-10-12
53 小时
发表于 2017-9-15 15:42:31 | 显示全部楼层
写地址那里,配的地址是多少?
GMT+8, 2026-10-31 11:25
