查看: 57394|回复: 28
stm32+lwip作为tcp客户端无法连接到服务器!!!
2012-5-4
发表于 2012-5-4 13:46:17 | 显示全部楼层 |阅读模式
我的stm32107+lwip作为tcp服务器端可以跟pc客户端正常通信,而如果作为tcp客户端则无法连接到pc服务器。这是哪里出了问题啊?希望有这方面经验的指导一下小弟,先谢谢了!
代码如下:
#include "lwip/tcp.h"
#include "lwip/ip_addr.h"
#include <string.h>
#define GREETING "Hello. \r\n"
#define HELLO "Hello "
#define MAX_NAME_SIZE 32
struct name
  int length;
  char bytes[MAX_NAME_SIZE];
void tcp_client_init(void);
err_t tcp_client_connect(void *arg, struct tcp_pcb *pcb, err_t err);
static void tcpaa_conn_err(void *arg, err_t err);
static err_t tcpaa_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err);
 tcp_write(pcb, GREETING, strlen(GREETING), 1);
   return ERR_OK;
   err_t ret;
   struct tcp_pcb *pcb=NULL;
   IP4_ADDR(&client_addr, 192, 168, 0, 192);
   IP4_ADDR(&server_addr, 192, 168, 0, 32);
   /* Create a new TCP control block  */
   pcb = tcp_new();
 if(pcb!=NULL)
    /* Assign to the new pcb a local IP address and a port number */
    tcp_bind(pcb, &client_addr, 1010);//客户端端口号为33
    //注册连接出错处理函数
    tcp_err(pcb, tcpaa_conn_err); //hrz
    tcp_recv(pcb, tcpaa_recv);//接收到数据的回调函数设置
    /* Connect to the server: send the SYN */
    ret=tcp_connect(pcb, &server_addr, 1010, tcp_client_connect);//服务器端口号为25
 tcp_arg(pcb, mem_calloc(sizeof(struct name), 1));
   return ERR_OK;
  struct name *name;
  name = (struct name *)arg;
  mem_free(name);
  while(1);
2017-12-1
发表于 2020-3-24 15:33:50 | 显示全部楼层
关闭PC防火墙,原因是PC机的windows防火墙拒绝了lwIP的TCP连接请求
回复 支持 2 反对 0
124
260
260
2013-1-10
10 小时
发表于 2016-4-21 14:41:41 | 显示全部楼层
void TCP_Client_Init()
  struct tcp_pcb *Clipcb;
  struct ip_addr ipaddr;
  u8 ret;
        struct ip_addr serverip;           //目标机IP
        static unsigned short serverport;       //目标机端口号
        serverip.addr = htonl(0xC0A8019A);       //192.168.1.154
        serverport=20002;
        Clipcb = tcp_new();                       // 建立通信的TCP控制块(Clipcb)
        tcp_bind(Clipcb,IP_ADDR_ANY,20002);       // 绑定本地IP地址和端口号
        iris_pcb=Clipcb;  //the mathod is wrong //by iris 2013.6.3
        //tcp_recv
        ret= tcp_connect(Clipcb,&serverip,20002,TcpCli_Connected_callback);
   tcp_recv(iris_pcb,tcp_recv_fn recv);
        if(ret==ERR_OK)
        Debugout(0,"connect oko tcp");
        //tcp_recv(iris_pcb,TcpCli_Received_callback);
个人博客www.xiaovdiy.cn
https://shop100764513.taobao.com/
回复 支持 0 反对 1
发表于 2012-5-4 17:37:15 | 显示全部楼层
56
56
2011-1-15
发表于 2012-7-28 13:42:37 | 显示全部楼层
谁在在做STM32F407关于网络通信的东西啊,一起讨论啊,我的QQ:253416737
39
111
111
2012-10-12
发表于 2012-12-27 09:49:34 | 显示全部楼层
回复【楼主位】hrz2ml:
悲剧啊,我也碰上这个问题了。。。
新人求指导~~~
2012-9-21
发表于 2013-5-6 21:01:37 | 显示全部楼层
楼主的问题,解决没?我用STM32F107+Lwip,遇到了同样的问题,求指点
2013-7-30
发表于 2013-7-30 16:09:13 | 显示全部楼层
我最近也在搞stm32f107+LWIP作为TCP客户端,发现使用ST公司提供的测试软件和LwIP应用指南 V0.01.pdf这个文章里面提到的软件,都可以测试成功。但使用正常的window API接口实现的程序,一连接上服务器就马上断开了。后来使用科来分析软件看了下,结果发现:在TCP的第三次握手那里,客户端这边不仅仅是发了ACK,还发了数据。
在调用函数:tcp_connect(pcb, &server_addr, 1010, tcp_client_connect); 如果在tcp_client_connect函数里面使用了 tcp_write(pcb, GREETING, strlen(GREETING), 1);就会出现这种情况,导致TCP的state为SYNC,而不是establish。
头像被屏蔽
88
231
845
845
2013-4-11
41 小时
发表于 2013-7-30 17:46:40 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
48
167
380
380
2013-6-27
17 小时
发表于 2013-8-1 10:09:33 | 显示全部楼层
回复【7楼】aa421701136:
我在做103+ENC28J60+LWIP+DHCP,之前这样103+ENC28J60+LWIP可以同时实现client 和server,现在加上DHCP,成功分配IP后,server功能能行,但client却connect不上;我在tcp_connect(client_pcb, &destip, 1206, tcp_client_connected);中调用的tcp_client_connected里面有用tcp_write,并没有你所说的连上断的现象。而且这个返回值也是ERR_OK,成功调用tcp_output,pcb->state == SYN_SENT;
  ret = tcp_enqueue(pcb, NULL, 0, TCP_SYN, 0, TF_SEG_OPTS_MSS
#if LWIP_TCP_TIMESTAMPS
                    | TF_SEG_OPTS_TS
#endif);
调试发现,tcp_output,输出调试信息nothing to send
48
167
380
380
2013-6-27
17 小时
发表于 2013-8-1 11:14:56 | 显示全部楼层
这个问题会是网卡设置的问题么,进入SYN_SENT后,就待ACK,可是跟踪发现,网卡并没接收到包,这个原因是什么呢,是SERVER没发包,还是网卡没收到。
48
167
380
380
2013-6-27
17 小时
发表于 2013-8-2 10:19:06 | 显示全部楼层
回复【8楼】nonplus:
你有没有遇到connect不上的问题呢,怎么解决。
之前没加DHCP,能成功的连上,无论是用作CLIENT还是SERVER都能通过路由和PC连上,两个功能同时运行也可以,用的TCP&UDP测试工具。
现在在原代码的基础上加上DHCP功能(代码改动很小,client和server相关的代码就没改,只#define LWIP_DHCP 1和在netconfig.c里加上dhcp_start),
现在能成功分配IP,能够PING通,用做server时,能成功连上,但是,做client时,连不上了。tcp_connect内调用的tcp_enqueue的返回值也是ERR_OK,并成功调用tcp_output。现在是问题出在哪儿都不知道。
2013-8-13
发表于 2013-8-13 19:01:05 | 显示全部楼层
我也在弄stm32+lwip来实现tcp的client,也遇到上面的问题,有人解决了?求指教啊
Yanxp 该用户已被删除
发表于 2013-8-14 09:38:07 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
Yanxp 该用户已被删除
发表于 2013-8-14 09:44:06 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
35
35
2013-8-17
发表于 2013-8-17 16:41:07 | 显示全部楼层
我也写了个STM32F107+LWIP客户端程序,用RawAPI在connected中调用tcp_write,服务器用TCP/UDP测试工具,发现一个不正常的地方就是:在connected用tcp_writ输出的内容服务器收不到。其他的收发都正常,感觉很迷惑。
23
23
2013-9-27
发表于 2013-9-27 11:10:51 | 显示全部楼层
我现在也遇到这个问题了,请问你解决了没,能把你的解决方案说一下吗
195
195
2012-4-4
46 小时
发表于 2014-3-26 15:15:59 | 显示全部楼层
请在tcp_write(pcb, GREETING, strlen(GREETING), 1);后加一句pbuf_free(p);
pbuf_free(p);
   return ERR_OK;
2014-9-2
发表于 2014-9-2 13:58:25 | 显示全部楼层
回复【11楼】can123dao:
我也遇到client端连不上pc的问题,可以交流下。qq531486448
2014-9-2
发表于 2014-9-2 14:01:44 | 显示全部楼层
回复【18楼】molin2015:
还有人遇到类似问题吗。我的是作为服务端都正常,客户端不正常啊。tcp_connect返回ok,可是pc收不到syn包。强制pcb-》state=established,之后tcp_write 也抓不到包。总之就是作为客户端。没有抓到任何包
95
748
1886
1886
2012-9-16
296 小时
发表于 2014-9-2 14:25:43 | 显示全部楼层
   pcb = tcp_new();
 if(pcb!=NULL)
    //注册连接出错处理函数
这是两个线程,客户端和服务器端分开初始化?
纵浪大化中,不喜亦不惧;应尽便须尽,无复独多虑!
39
39
2014-9-2
发表于 2014-9-2 21:59:56 | 显示全部楼层
求交流这个通讯的知识   q327413510
2015-4-2
发表于 2015-4-9 11:40:44 | 显示全部楼层
回复【21楼】知嗅:
请问你现在关于这个以太网通信有进展么
2015-4-2
发表于 2015-4-9 11:41:34 | 显示全部楼层
回复【7楼】aa421701136:
请问你现在作为客户端程序成功了么?可否分享一下经验
51
51
2019-5-21
18 小时
发表于 2020-4-24 13:33:11 | 显示全部楼层
can123dao 发表于 2013-8-2 10:19
回复【8楼】nonplus:
之 ...
你好,我也遇上跟你一样的问题,请问你的解决了吗
51
51
2019-5-21
18 小时
发表于 2020-4-24 13:35:03 | 显示全部楼层
aa421701136 发表于 2013-7-30 16:09
**** 作者被禁止或删除 内容自动屏蔽 ****
你好,请问你的问题解决了吗?我碰上一样的问题了。找不到原因
2020-4-21
发表于 2020-7-8 09:33:12 | 显示全部楼层
25楼说的关闭防火墙,解决了
2020-7-28
发表于 2020-9-23 16:03:41 | 显示全部楼层
今天我也遇到了,结果搞了半天是防火墙的问题,关闭防火墙就可以接通了
2017-7-16
发表于 2021-3-5 15:05:33 | 显示全部楼层
谢谢大佬,你的方法就是正确的。
GMT+8, 2026-11-4 02:52
