查看: 6542|回复: 5
用共阴极数码管显示ds1302不好用
64
64
2015-3-23
发表于 2015-5-20 20:29:45 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit sck=P3^0;
sbit io=P3^1;
sbit rst=P3^2;
sbit smgen=P3^3;
unsigned char code smg_du[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};
unsigned char code smg_we[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
uchar time_data[7]={10,6,4,17,11,58,30};
uchar time_add[7]={0x8c,0x8a,0x88,0x86,0x84,0x82,0x80};
uchar read_add[7]={0x8d,0x8b,0x89,0x87,0x85,0x83,0x81};
uchar disp[8];
void write_ds1302_byte(uchar dat);
void write_ds1302(uchar add,uchar dat);
uchar read_ds1302(uchar add);
void set_rtc(void);
void read_rtc(void);
void time_pros(void);
void delay_50ms(uint t)
uint j;
for(;t>0;t--)
for(j=6245;j>0;j--);
uchar i;
for(i=0;i<8;i++)
sck=0;
io=dat&0x01;
dat=dat>>1;
sck=1;
rst=0;
_nop_();
sck=0;
_nop_();
rst=1;
_nop_();
write_ds1302_byte(add);
write_ds1302_byte(dat);
rst=0;
_nop_();
io=1;
sck=1;
uchar i;
uchar value;
rst=0;
_nop_();
sck=0;
_nop_();
rst=1;
_nop_();
for(i=0;i<8;i++)
value=value>>1;
sck=0;
if(io)
value=value|0x80;
sck=1;
rst=0;
_nop_();
sck=0;
_nop_();
sck=1;
io=1;
return value;
void set_rtc(void)
  uchar i,j;
  for(i=0;i<7;i++)
   j=time_data/10;
   time_data=time_data%10;
   time_data=time_data+j*16;
  write_ds1302(0x8e,0x00);
  for(i=0;i<7;i++)
write_ds1302(time_add,time_data);
   write_ds1302(0x8e,0x80);
void read_rtc(void)
uchar i;
for(i=0;i<7;i++)
time_data=read_ds1302(read_add);
disp[0]=time_data[6]%16;
disp[1]=time_data[6]/16;
disp[2]=10;
disp[3]=time_data[5]%16;
disp[4]=time_data[5]/16;
disp[5]=10;
disp[6]=time_data[4]%16;
disp[7]=time_data[4]/16;
void display(void)
  uchar i;
  for(i=0;i<8;i++)
P2=smg_we;
smgen=1;
P1=smg_du[disp];
smgen=0;
delay_50ms(20);
void main(void)
set_rtc();
read_rtc();
time_pros();
display();
这是我参考网上自己改的,但是用proteus仿真就是不好用我也不知道出错在哪
数码管.DSN
176.91 KB, 下载次数: 210
头像被屏蔽
6167
7031
19705
19705
2012-12-27
25 小时
发表于 2015-5-20 21:41:08 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
64
64
2015-3-23
 楼主| 发表于 2015-5-21 07:33:10 | 显示全部楼层
回复【2楼】xouou_53320:
--------------------------------那你能帮我看看么,到底是什么地方出错了,proteus 我也上传了
36
36
2015-2-12
发表于 2015-5-21 08:14:21 | 显示全部楼层
这个问题我遇到过。不一定是程序的问题,主要是因为proteus的屏幕刷新速率过慢,导致数码管的显示不正常。但是我也不知道在哪里调。我觉得可能最初用硬件跑更好一些。就像楼上说的,玩到一定程度,再用软件仿真才好。
不做浮躁的嵌入式攻城狮。。。。
69
6727
13713
13713
2012-11-26
3874 小时
发表于 2015-5-21 08:20:38 | 显示全部楼层
proteus仿真并不能代表在板子上运行的情况
学无止境
49
84
84
2015-5-23
发表于 2015-5-23 10:12:22 | 显示全部楼层
没听说过啊!
GMT+8, 2026-11-14 09:03
