查看: 12592|回复: 4
DMA读ADC引脚悬空时读数不为0,约1.6V,求高手分析
40
158
158
2015-4-12
发表于 2015-6-2 23:20:50 | 显示全部楼层 |阅读模式
//#include "stm32f10x_conf.h"                //这个头文件包括 STM32F10x 所有外围寄存器、位、内存映射的定义
#include "usart.h"
#include <stdio.h>
#define    N    50            //每通道采 50 次
#define    M    12            //为 12 个通道
#define  ADC1_DR_Address  (u32)0x4001244c
vu16    AD_Value[N][M];      //用来存放 ADC 转换结果,也是 DMA 的目标地址
vu16    After_filter[M];        //用来存放求平均值之后的结果
int    i;
void delay_us(u32 n)//最大可以147000ns,时钟为系统时钟72M
u32 temp;
SysTick->LOAD = 72 * n;
SysTick->VAL = 0X00;
SysTick->CTRL = 0x00000005;
do
temp = SysTick->CTRL;
} while (temp & 0x01 && !(temp&(1 << 16)));//等待时间到达
SysTick->CTRL = 0x00000004;
void delay_ms(u16 t)//最大可以147ms
u16 i;
if (t > 147)
for ( i = 0; i < t; i++)
delay_us(1000);
delay_us(t * 1000);
#pragma import(__use_no_semihosting)
//标准库需要的支持函数
struct __FILE
int handle;
FILE __stdout;
//定义_sys_exit()以避免使用半主机模式
_sys_exit(int x)
x = x;
//重定义fputc函数
int fputc(int ch, FILE *f)
while((USART1->SR&0X40)==0);//循环发送,直到发送完毕
    USART1->DR = (u8) ch;
return ch;
void UART_Init(u32 bound)
USART_InitTypeDef USART_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
USART_DeInit(USART1);
USART_InitStructure.USART_BaudRate=bound;
USART_InitStructure.USART_StopBits=USART_StopBits_1;
USART_InitStructure.USART_WordLength=USART_WordLength_8b;
USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
USART_InitStructure.USART_Parity=USART_Parity_No;
USART_Init(USART1,&USART_InitStructure);
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
USART_Cmd(USART1,ENABLE);
NVIC_InitStructure.NVIC_IRQChannel=USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority=3;
/*GPIO 管脚的配置
选用 ADC 的通道 0    1    2    8    9    10    11    12    13    14    15,分别对应的管脚为 PA0    A1
PA2    B0    B1    C0    C1    C2    C3    C4    C5
串口使用 USART1 其中 TX 为 PA9, RX 为 PA10 */
void GPIO_Configuration(void)
// PA0/1/2作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;    //模拟输入引脚
//PB0/1 作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
//PC0/1/2/3/4/5 作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/*配置 ADC1*/
void ADC1_Configuration(void)
    ADC_InitTypeDef    ADC_InitStructure;
    ADC_DeInit(ADC1);    //将外设 ADC1 的全部寄存器重设为缺省值
/* ADC1 configuration ‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐‐*/
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC 工作模式:ADC1 和 ADC2工作在独立模式
ADC_InitStructure.ADC_ScanConvMode =ENABLE; //模数转换工作在扫描模式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //模数转换工作在连续转换模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; // 外 部 触 发 转 换关闭
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC 数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = M; //顺序进行规则转换的 ADC 通道的数目
ADC_Init(ADC1, &ADC_InitStructure); //根据 ADC_InitStruct 中指定的参数初始化外设ADCx 的寄存器
/* ADC1 regular channel11 configuration */
//设置指定 ADC 的规则组通道,设置它们的转化顺序和采样时间
//ADC1,ADC 通道 x,规则采样顺序值为 y,采样时间为 239.5 周期
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 5, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 6, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 7, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 8, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 9, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 10, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 11, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 12, ADC_SampleTime_239Cycles5 );
// 开启 ADC 的 DMA 支持(要实现 DMA 功能,还需独立配置 DMA 通道等参数)
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE);        //使能指定的 ADC1
/* Enable ADC1 reset calibaration register */
ADC_ResetCalibration(ADC1);     //复位指定的 ADC1 的校准寄存器
/* Check the end of ADC1 reset calibration register */
while(ADC_GetResetCalibrationStatus(ADC1)); //获取 ADC1 复位校准寄存器的状态,设置状态则等待
/* Start ADC1 calibaration */
ADC_StartCalibration(ADC1);   //开始指定 ADC1 的校准状态
/* Check the end of ADC1 calibration */
while(ADC_GetCalibrationStatus(ADC1));    //获取指定 ADC1 的校准程序,设置状态则等待
/*配置 DMA*/
void DMA_Configuration(void)
/* ADC1    DMA1 Channel Config */
DMA_InitTypeDef DMA_InitStructure;
DMA_DeInit(DMA1_Channel1);      //将 DMA 的通道 1 寄存器重设为缺省值
DMA_InitStructure.DMA_PeripheralBaseAddr =ADC1_DR_Address;// ;    //DMA 外设 ADC 基地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value;    //DMA 内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;    //内存作为数据传输的目的地
DMA_InitStructure.DMA_BufferSize = N*M;    //DMA 通道的 DMA 缓存的大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;    //内存地址寄存器递增
DMA_InitStructure.DMA_PeripheralDataSize =DMA_PeripheralDataSize_HalfWord;    //数据宽度为 16 位
DMA_InitStructure.DMA_MemoryDataSize =DMA_MemoryDataSize_HalfWord; //数据宽度为 16 位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;    //工作在循环缓存模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA 通道 x 拥有高优先级
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;    //DMA 通道 x 没有设置为内存到内存传输
DMA_Init(DMA1_Channel1, &DMA_InitStructure); //根据 DMA_InitStruct 中指定的参数初始化 DMA 的通道
void RCC_Configuration()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB
|RCC_APB2Periph_GPIOC |RCC_APB2Periph_ADC1 | RCC_APB2Periph_AFIO
|RCC_APB2Periph_USART1, ENABLE );
RCC_ADCCLKConfig(RCC_PCLK2_Div6);      //72M/6=12,ADC 最大时间不能超过 14M
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能 DMA 传输
//配置所有外设
void Init_All_Periph(void)
RCC_Configuration();
GPIO_Configuration();
ADC1_Configuration();
DMA_Configuration();
UART_Init(115200);
/*获取 ADC 的值,将二进制换算为十进制*/
u16 GetVolt(u16 advalue)
      return (u16)(advalue * 330 / 4096);    //求的结果扩大了 100 倍,方便下面求出小数
/*求平均值函数*/
void filter(void)
      int    sum = 0;
      u8    count ;
      for(i=0;i<12;i++)
 for ( count=0;count<N;count++)
 sum += AD_Value[count];
After_filter=sum/N;
sum=0;
int main(void)
    u16 value[M];
Init_All_Periph();
    /* Start ADC1 Software Conversion */
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
DMA_Cmd(DMA1_Channel1, ENABLE);   //启动 DMA 通道
while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//等待传输完成否则第一位数据容易丢失
filter();
 for(i=0;i<12;i++)
 value= GetVolt(After_filter);
 printf("value[%d]:\t%d.%dv\n",i,value/100,value%100) ;
 delay_ms(100);
悬空引脚处于不确定状态,这个本身不是程序问题
71
2706
3505
3505
2014-8-4
696 小时
发表于 2015-6-2 23:20:51 | 显示全部楼层
以我资质之鲁钝,当尽平心静气、循序渐进、稳扎稳打之力。
72
72
2015-5-21
发表于 2015-6-3 11:00:17 | 显示全部楼层
fficeffice" />
  看看图片吧
72
72
2015-5-21
发表于 2015-6-3 11:00:40 | 显示全部楼层
150
1181
1181
2015-12-28
132 小时
发表于 2017-9-14 10:47:11 | 显示全部楼层
ADC的管脚设成悬浮输入,其IO口对电源及对地的电阻(是由于泄漏电流引起的)不是无穷大,如果它对地及对电源的电阻大致相等,则它的电压就很有可能是接近电源的一半,只要你的万用表的输入阻抗远大于IO的电阻,则有可能比较准确地测量出这个电压了
越努力,越优秀;越独立,越自由
GMT+8, 2026-10-31 10:57
