查看: 5600|回复: 7
外扩SRAM读数不正确
68
68
2015-7-20
12 小时
发表于 2015-7-20 21:06:28 | 显示全部楼层 |阅读模式
各位大大,请教下,我使用STM32F103ZET6,IS61LV51216BLL的SRAM,使用FSMC的NE2作为片选控制,FSMC配置如下:
#define Bank1_SRAM2_ADDR    ((u32)(0x64000000))
//初始化外部SRAM
void FSMC_SRAM_Init(void)
 FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE|RCC_APB2Periph_GPIOF|RCC_APB2Periph_GPIOG|RCC_APB2Periph_AFIO,ENABLE);
   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4  | GPIO_Pin_5  | GPIO_Pin_8 |
                               GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 |GPIO_Pin_12 |
                            GPIO_Pin_13| GPIO_Pin_14| GPIO_Pin_15 ; //PORTD复用推挽输出
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出
  GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0  | GPIO_Pin_1  | GPIO_Pin_7  | GPIO_Pin_8  |
                                GPIO_Pin_9  | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 |
                                GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; //PORTE复用推挽输出
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0  | GPIO_Pin_1 | GPIO_Pin_2  | GPIO_Pin_3  |
                                GPIO_Pin_4  | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 |
                                GPIO_Pin_14 | GPIO_Pin_15; //PORTF复用推挽输出
  GPIO_Init(GPIOF, &GPIO_InitStructure);
                                GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_9 ; //PORTG复用推挽输出
  GPIO_Init(GPIOG, &GPIO_InitStructure);
    readWriteTiming.FSMC_AddressSetupTime = 0x00; //地址建立时间(ADDSET)为1个HCLK 1/36M=27ns
    readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(ADDHLD)模式A未用到
    readWriteTiming.FSMC_DataSetupTime = 0x03; //数据保持时间(DATAST)为3个HCLK 4/72M=55ns(对EM的SRAM芯片)
    readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
    readWriteTiming.FSMC_CLKDivision = 0x00;
    readWriteTiming.FSMC_DataLatency = 0x00;
    readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A; //模式A
    FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM2;//  这里我们使用NE3 ,也就对应BTCR[4],[5]。
    FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
    FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;//SRAM
    FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
    FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
 FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
    FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; //存储器写使能
    FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // 读写使用相同的时序
    FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; // 读写使用相同的时序
    FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming;  // 读写使用相同的时序
    FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //初始化FSMC配置
    FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM2, ENABLE);  // 使能BANK3
为什么初始化后0X64000000到0X67FFFFFF中的数全是00 10 00 10………………不是应该全是00么,搞了两天了,没找到问题,大家帮忙下!!
发表于 2015-7-20 22:01:10 | 显示全部楼层
可以参考下我们的sram例程。
68
68
2015-7-20
12 小时
 楼主| 发表于 2015-7-20 22:12:07 | 显示全部楼层
回复【2楼】正点原子:
原子哥,我就是在你的例程基础上改的,只是把例程中的片选改成NE2,启用NORSRAM2了,当然地址也修改成64000000,其他的都没变,但读出的数据就是不正确,WHY?SRAM芯片也换了,难道是因为我PCB板的布线太乱了?
发表于 2015-7-20 23:15:04 | 显示全部楼层
回复【3楼】amethysthj:
sram对布线要求不高的。。。
一般只要连线正常,都OK啊。
linxindong 该用户已被删除
发表于 2017-2-5 14:26:54 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
57
291
291
2017-5-9
153 小时
发表于 2017-7-12 12:34:47 | 显示全部楼层
linxindong 发表于 2017-2-5 14:26
我也出现同样的问题,只要使能了存储器就数据就开始错乱了,初始化后出现的也是00,10,00,10.....请问是怎么解 ...
我也出现了,00 F0 00 F0这种,还没找到原因,楼主找到了吗?
2016-4-7
发表于 2017-7-25 23:05:49 | 显示全部楼层
求问楼主问题解决了吗?我也遇到了同样问题,sram初始化后为00 08 00 08.........求解答???thx
162
1214
1407
1407
2014-5-21
343 小时
发表于 2017-8-30 10:53:23 | 显示全部楼层
求解答
GMT+8, 2026-10-31 07:11
