查看: 6503|回复: 5
淘宝买了个电机驱动板,程序是UV2,打开一看,是汇编语言,望指导编译
2015-8-4
发表于 2015-8-4 19:10:42 | 显示全部楼层 |阅读模式
网上买的L298N的电机驱动板,但是程序是汇编的,希望大神看一看,在keil里怎么设置才能编译和下载。[/mw_shl_code]
本人QQ,879361388,希望大神指导。[/mw_shl_code]
[/mw_shl_code]
程序如下:[/mw_shl_code]
$NOMOD51
;  This file is part of the C51 Compiler package
;  Copyright (c) 1988-2005 Keil Elektronik GmbH and Keil Software, Inc.
;  Version 8.01
;  *** <<< Use Configuration Wizard in Context Menu >>> ***
;  STARTUP.A51:  This code is executed after processor reset.
;  To translate this file use A51 with the following invocation:
;     A51 STARTUP.A51
;  To link the modified STARTUP.OBJ file to your application use the following
;  Lx51 invocation:
;     Lx51 your object file list, STARTUP.OBJ  controls
;  User-defined <h> Power-On Initialization of Memory
;  With the following EQU statements the initialization of memory
;  at processor reset can be defined:
; <o> IDATALEN: IDATA memory size <0x0-0x100>
;     <i> Note: The absolute start-address of IDATA memory is always 0
;     <i>       The IDATA space overlaps physically the DATA and BIT areas.
IDATALEN        EQU     80H
; <o> XDATASTART: XDATA memory start address <0x0-0xFFFF>
;     <i> The absolute start address of XDATA memory
XDATASTART      EQU     0
; <o> XDATALEN: XDATA memory size <0x0-0xFFFF>
;     <i> The length of XDATA memory in bytes.
XDATALEN        EQU     0
; <o> PDATASTART: PDATA memory start address <0x0-0xFFFF>
;     <i> The absolute start address of PDATA memory
PDATASTART      EQU     0H
; <o> PDATALEN: PDATA memory size <0x0-0xFF>
;     <i> The length of PDATA memory in bytes.
PDATALEN        EQU     0H
;</h>
;<h> Reentrant Stack Initialization
;  The following EQU statements define the stack pointer for reentrant
;  functions and initialized it:
; <h> Stack Space for reentrant functions in the SMALL model.
;  <q> IBPSTACK: Enable SMALL model reentrant stack
;     <i> Stack space for reentrant functions in the SMALL model.
IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
;  <o> IBPSTACKTOP: End address of SMALL model stack <0x0-0xFF>
;     <i> Set the top of the stack to the highest location.
IBPSTACKTOP     EQU     0xFF +1     ; default 0FFH+1
; </h>
; <h> Stack Space for reentrant functions in the LARGE model.
;  <q> XBPSTACK: Enable LARGE model reentrant stack
;     <i> Stack space for reentrant functions in the LARGE model.
XBPSTACK        EQU     0       ; set to 1 if large reentrant is used.
;  <o> XBPSTACKTOP: End address of LARGE model stack <0x0-0xFFFF>
XBPSTACKTOP     EQU     0xFFFF +1   ; default 0FFFFH+1
; </h>
; <h> Stack Space for reentrant functions in the COMPACT model.
;  <q> PBPSTACK: Enable COMPACT model reentrant stack
;     <i> Stack space for reentrant functions in the COMPACT model.
PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
;   <o> PBPSTACKTOP: End address of COMPACT model stack <0x0-0xFFFF>
PBPSTACKTOP     EQU     0xFF +1     ; default 0FFH+1
; </h>
;</h>
;  Memory Page for Using the Compact Model with 64 KByte xdata RAM
;  <e>Compact Model Page Definition
;  <i>Define the XDATA page used for PDATA variables.
;  <i>PAGE must conform with the PPAGE set in the linker invocation.
; Enable pdata memory page initalization
PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
; <o> PPAGE number <0x0-0xFF>
; <i> uppermost 256-byte address of the page used for PDATA variables.
PPAGE           EQU     0
; <o> SFR address which supplies uppermost address byte <0x0-0xFF>
; <i> most 8051 variants use P2 as uppermost address byte
PPAGE_SFR       DATA    0A0H
; </e>
; Standard SFR Symbols
ACC     DATA    0E0H
B       DATA    0F0H
SP      DATA    81H
DPL     DATA    82H
DPH     DATA    83H
                NAME    ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE
?STACK          SEGMENT   IDATA
                RSEG    ?STACK
                DS      1
                EXTRN CODE (?C_START)
                PUBLIC  ?C_STARTUP
                CSEG    AT      0
?C_STARTUP:     LJMP    STARTUP1
                RSEG    ?C_C51STARTUP
STARTUP1:
IF IDATALEN <> 0
                MOV     R0,#IDATALEN - 1
                CLR     A
IDATALOOP:      MOV     @R0,A
                DJNZ    R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
                MOV     DPTR,#XDATASTART
                MOV     R7,#LOW (XDATALEN)
  IF (LOW (XDATALEN)) <> 0
                MOV     R6,#(HIGH (XDATALEN)) +1
  ELSE
                MOV     R6,#HIGH (XDATALEN)
  ENDIF
                CLR     A
XDATALOOP:      MOVX    @DPTR,A
                INC     DPTR
                DJNZ    R7,XDATALOOP
                DJNZ    R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
                MOV     PPAGE_SFR,#PPAGE
ENDIF
IF PDATALEN <> 0
                MOV     R0,#LOW (PDATASTART)
                MOV     R7,#LOW (PDATALEN)
                CLR     A
PDATALOOP:      MOVX    @R0,A
                INC     R0
                DJNZ    R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
EXTRN DATA (?C_IBP)
                MOV     ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0
EXTRN DATA (?C_XBP)
                MOV     ?C_XBP,#HIGH XBPSTACKTOP
                MOV     ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0
EXTRN DATA (?C_PBP)
                MOV     ?C_PBP,#LOW PBPSTACKTOP
ENDIF
                MOV     SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
;<h> Code Banking
; <q> Select Bank 0 for L51_BANK.A51 Mode 4
#if 0
;     <i> Initialize bank mechanism to code bank 0 when using L51_BANK.A51 with Banking Mode 4.
EXTRN CODE (?B_SWITCH0)
                CALL    ?B_SWITCH0      ; init bank mechanism to code bank 0
#endif
;</h>
                LJMP    ?C_START
                END
[/mw_shl_code]
楼主在干嘛,L298N就是个驱动板子而已啊,可以和任何MCU搭配啊,自己写程序就行,很简单的
39
598
875
875
2013-12-18
41 小时
发表于 2015-8-4 19:10:43 | 显示全部楼层
2015-8-4
 楼主| 发表于 2015-8-4 19:55:29 | 显示全部楼层
回复【2楼】w417074951:
新手,用什么语言写都可以?怎么下载到那个板子里面啊,还是不用下载,这个板子只要和muc通信就ok了?
39
598
875
875
2013-12-18
41 小时
发表于 2015-8-4 20:22:09 | 显示全部楼层
372
1346
1346
2014-7-23
427 小时
发表于 2015-8-4 21:09:36 | 显示全部楼层
ddzz.c才是。。。哪个是添加的启动文件
2015-8-4
 楼主| 发表于 2015-8-6 16:25:28 | 显示全部楼层
麻烦各位, 。这个已经ok了,谢谢大家
GMT+8, 2026-11-5 20:28
