查看: 6160|回复: 4
用stm32f4控制商用电调的问题
85
303
303
2015-9-2
83 小时
发表于 2015-10-13 16:30:28 | 显示全部楼层 |阅读模式
[mw_shl_code=c,true]void GPIO_INIT() { GPIO_InitTypeDef GPIO_A; GPIO_InitTypeDef GPIO_B; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE); //GPIO时钟使能 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE); GPIO_PinAFConfig(GPIOA,GPIO_PinSource6,GPIO_AF_TIM3); //GPIO复用映射 GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_TIM3); GPIO_PinAFConfig(GPIOB,GPIO_PinSource0,GPIO_AF_TIM3); GPIO_PinAFConfig(GPIOB,GPIO_PinSource1,GPIO_AF_TIM3); GPIO_A.GPIO_Pin =GPIO_Pin_6|GPIO_Pin_7; GPIO_A.GPIO_Mode =GPIO_Mode_AF; //GPIOA初始化 GPIO_A.GPIO_OType =GPIO_OType_PP; GPIO_A.GPIO_Speed =GPIO_Speed_50MHz; GPIO_A.GPIO_PuPd =GPIO_PuPd_UP; GPIO_B.GPIO_Pin =GPIO_Pin_0|GPIO_Pin_1; GPIO_B.GPIO_Mode =GPIO_Mode_AF; GPIO_B.GPIO_OType =GPIO_OType_PP; //GPIOB初始化 GPIO_B.GPIO_Speed =GPIO_Speed_50MHz; GPIO_B.GPIO_PuPd =GPIO_PuPd_UP; GPIO_Init(GPIOA,&GPIO_A); GPIO_Init(GPIOB,&GPIO_B); } void Time_PWM_Init() { TIM_TimeBaseInitTypeDef TIM_3; TIM_OCInitTypeDef oc1,oc2,oc3,oc4; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE); TIM_3.TIM_ClockDivision =TIM_CKD_DIV1; TIM_3.TIM_CounterMode =TIM_CounterMode_Up; TIM_3.TIM_Period =19999; TIM_3.TIM_Prescaler =83; TIM_TimeBaseInit(TIM3,&TIM_3); oc1.TIM_OCMode =TIM_OCMode_PWM1; oc1.TIM_OutputState =TIM_OutputState_Enable; oc1.TIM_OCPolarity =TIM_OCNPolarity_High; oc2.TIM_OCMode =TIM_OCMode_PWM1; oc2.TIM_OutputState =TIM_OutputState_Enable; oc2.TIM_OCPolarity =TIM_OCNPolarity_High; oc3.TIM_OCMode =TIM_OCMode_PWM1; oc3.TIM_OutputState =TIM_OutputState_Enable; oc3.TIM_OCPolarity =TIM_OCNPolarity_High; oc4.TIM_OCMode =TIM_OCMode_PWM1; oc4.TIM_OutputState =TIM_OutputState_Enable; oc4.TIM_OCPolarity =TIM_OCNPolarity_High; TIM_OC1Init(TIM3,&oc1); //四条通道初始化 TIM_OC1PreloadConfig(TIM3,TIM_OCPreload_Enable); TIM_OC2Init(TIM3,&oc2); TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable); TIM_OC3Init(TIM3,&oc3); TIM_OC3PreloadConfig(TIM3,TIM_OCPreload_Enable); TIM_OC4Init(TIM3,&oc4); TIM_OC4PreloadConfig(TIM3,TIM_OCPreload_Enable); TIM_ARRPreloadConfig(TIM3,ENABLE); TIM_Cmd(TIM3, ENABLE); } void PWM(u16 p1,u16 p2,u16 p3,u16 p4) { TIM_SetCompare1(TIM3,p1); TIM_SetCompare2(TIM3,p2); TIM_SetCompare3(TIM3,p3); TIM_SetCompare4(TIM3,p4); }[/mw_shl_code] [mw_shl_code=c,true]我知道商用电调的信号为50HZ,1ms-2ms,所以我这里在 84MHZ的情况下 TIM_3.TIM_Prescaler 设为83,时钟为1us。[/mw_shl_code] [mw_shl_code=c,true]TIM_3.TIM_Period =19999;周期为20ms[/mw_shl_code] [mw_shl_code=c,true]然后在程序一开始设置油门,全都拉到2ms 等按键按下后降到1ms再慢慢往上加油门,可是并没有什么用。[/mw_shl_code] [mw_shl_code=c,true]电机动是动的但是是在我加油门加到很高的时候才开始慢慢加速,这就让我搞不懂,他的油门信号到底是怎么设的[/mw_shl_code] [mw_shl_code=c,true]我用的是好盈乐天20A的电调,求大神指教 [/mw_shl_code]
85
303
303
2015-9-2
83 小时
 楼主| 发表于 2015-10-13 16:32:08 | 显示全部楼层
上面的文字有点乱我整理一下
我知道商用电调的信号为50HZ,1ms-2ms,所以我这里在 84MHZ的情况下TIM_3.TIM_Prescaler 设为83,时钟为1us。
35
151
151
2014-1-2
14 小时
发表于 2015-10-13 16:47:30 | 显示全部楼层
回复【2楼】MasterSU:
  电调启动PWM占空比大于50%,1.1ms启动
你可以仿真一下,或者用示波器看一下波形
PWM输出实验 - 副本.rar
461.04 KB, 下载次数: 190
85
303
303
2015-9-2
83 小时
 楼主| 发表于 2015-10-13 17:10:35 | 显示全部楼层
回复【3楼】帅的被人砍1203:
仿真怎么看,示波器太贵
35
151
151
2014-1-2
14 小时
发表于 2015-10-14 10:51:12 | 显示全部楼层
回复【4楼】MasterSU:
这种情况,建议买一个逻辑分析仪,很便宜,很实用!
GMT+8, 2026-11-11 00:34
