查看: 10496|回复: 3
以太网从lan8720修改成dp83848后数据不通
153
784
784
2012-6-14
206 小时
发表于 2015-10-16 17:45:09 | 显示全部楼层 |阅读模式
之前调试以前的机器的时候,调试lan8720a成功,功能都齐全,这次将这个lan8720修改成了dp83848之后,就基本不通了,由于本人不太了解硬件,所以请各位帮忙看看,使用的依然是RMII模式
PC连接状态:
电脑状态:
然后使用wireshark截取报文,不停的发送arp报文:
以太网硬件如下:
本人修改过的地方,就是管脚相关的配置,PHY地址改成了0x01,部分寄存器改成了dp83848自己的,软件方面检查过多遍:
[mw_shl_code=c,true]void ETH_GPIO_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Enable GPIOs clocks */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOC /*| RCC_AHB1Periph_GPIOI | RCC_AHB1Periph_GPIOG | RCC_AHB1Periph_GPIOH | RCC_AHB1Periph_GPIOF*/, ENABLE); /* Enable SYSCFG clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); /* Configure MCO (PA8) ?±????*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ; GPIO_Init(GPIOA, &GPIO_InitStructure); /* MII/RMII Media interface selection --------------------------------------*/ #ifdef MII_MODE /* Mode MII with STM322xG-EVAL */ #ifdef PHY_CLOCK_MCO /* Output HSE clock (25MHz) on MCO pin (PA8) to clock the PHY */ RCC_MCO1Config(RCC_MCO1Source_HSE, RCC_MCO1Div_1); #endif /* PHY_CLOCK_MCO */ SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_MII); #elif defined RMII_MODE /* Mode RMII with STM322xG-EVAL */ // RCC_MCO1Config(RCC_MCO1Source_PLLCLK/*RCC_MCO1Source_HSE*/, RCC_MCO1Div_2); SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_RMII); #endif /* Configure PA1, PA2 and PA7 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_ETH); /* Configure PB11,PB12 and PB13 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_ETH); /* Configure PC1, PC4 and PC5 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_ETH); }[/mw_shl_code]
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2015-10-16 17:50:57 | 显示全部楼层
ST官方的例程都是DP83848的啊
开往春天的手扶拖拉机
153
784
784
2012-6-14
206 小时
 楼主| 发表于 2015-10-19 08:43:07 | 显示全部楼层
回复【2楼】zuozhongkai:
嗯,关键是我们做硬件的是按照自己的想法做的硬件,我自己也查不出问题在那里来着,所以上来问问,我只看了我的软件部分,硬件方面不怎么懂
55
55
2020-1-2
发表于 2020-5-28 10:16:12 | 显示全部楼层
zuozhongkai 发表于 2015-10-16 17:50
ST官方的例程都是DP83848的啊
朋友    能加个好友吗    我找了好久DP83848的例程   都没找到
GMT+8, 2026-11-4 04:43
