查看: 4427|回复: 1
在移植UCOSII+LWIP中出现内存错误,哪位大神帮我看看
50
166
166
2014-11-21
10 小时
发表于 2015-10-27 16:00:54 | 显示全部楼层 |阅读模式
移植UCOSII+LWIP,开始没有添加其他任务的时候创建TCP服务器可以和PC正常收发数据,但是我增加了三个任务之后,就出现内存错误,在调用OS_MEM  *OSMemCreate (void *addr, INT32U nblks, INT32U blksize, INT8U *perr)创建内存分区的时候
    OS_MEM    *pmem;
    INT8U     *pblk;
    void     **plink;
    INT32U     i;
#if OS_CRITICAL_METHOD == 3                           /* Allocate storage for CPU status register      */
    OS_CPU_SR  cpu_sr = 0;
#endif
#if OS_ARG_CHK_EN > 0
    if (perr == (INT8U *)0) {                         /* Validate 'perr'                               */
        return ((OS_MEM *)0);
    if (addr == (void *)0) {                          /* Must pass a valid address for the memory part.*/
        *perr = OS_ERR_MEM_INVALID_ADDR;
    if (((INT32U)addr & (sizeof(void *) - 1)) != 0){  /* Must be pointer size aligned                  */
    if (nblks < 2) {                                  /* Must have at least 2 blocks per partition     */
        *perr = OS_ERR_MEM_INVALID_BLKS;
    if (blksize < sizeof(void *)) {                   /* Must contain space for at least a pointer     */
        *perr = OS_ERR_MEM_INVALID_SIZE;
#endif
    OS_ENTER_CRITICAL();
    pmem = OSMemFreeList;                             /* Get next free memory partition                */
    if (OSMemFreeList != (OS_MEM *)0) {               /* See if pool of free partitions was empty      */
        OSMemFreeList = (OS_MEM *)OSMemFreeList->OSMemFreeList;
    OS_EXIT_CRITICAL();
    if (pmem == (OS_MEM *)0) {                        /* See if we have a memory partition             */
        *perr = OS_ERR_MEM_INVALID_PART;        //在这里跳了出来
    plink = (void **)addr;                            /* Create linked list of free memory blocks      */
    pblk  = (INT8U *)((INT32U)addr + blksize);
    for (i = 0; i < (nblks - 1); i++) {
       *plink = (void *)pblk;                         /* Save pointer to NEXT block in CURRENT block   */
        plink = (void **)pblk;                        /* Position to  NEXT      block                  */
        pblk  = (INT8U *)((INT32U)pblk + blksize);    /* Point to the FOLLOWING block                  */
    *plink              = (void *)0;                  /* Last memory block points to NULL              */
    pmem->OSMemAddr     = addr;                       /* Store start address of memory partition       */
    pmem->OSMemFreeList = addr;                       /* Initialize pointer to pool of free blocks     */
    pmem->OSMemNFree    = nblks;                      /* Store number of free blocks in MCB            */
    pmem->OSMemNBlks    = nblks;
    pmem->OSMemBlkSize  = blksize;                    /* Store block size of each memory blocks        */
    *perr               = OS_ERR_NONE;
    return (pmem);
没有内存分区了吗,在哪里设置这些参数,怎么解决
50
166
166
2014-11-21
10 小时
 楼主| 发表于 2015-10-27 16:01:55 | 显示全部楼层
在线等,卡了两天了
GMT+8, 2026-11-4 03:42
