查看: 6253|回复: 6
LWIP移植一直死在startup_stm32f10x_hd.s里面324行,具体见正文,谢谢。
37
160
160
2014-9-7
18 小时
发表于 2015-11-5 10:09:35 | 显示全部楼层 |阅读模式
在原子哥的基础上将lwip裸移植到mini板上,仿真发现一直死在了下面这里:
网上搜索有人说是中断部分的问题,但是看了下,感觉没问题啊?
u8 ENC28J60_Init(void)
u8 version;
u16 retry=0;
u32 temp;
SPI_InitTypeDef  SPI_InitStructure;
EXTI_InitTypeDef EXTI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC |RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU ;
  GPIO_SetBits(GPIOA,GPIO_Pin_10);
GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_8);
GPIO_EXTILineConfig(GPIO_PortSourceGPIOA,GPIO_PinSource10);
EXTI_InitStructure.EXTI_Line = EXTI_Line10;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
EXTI_ClearITPendingBit(EXTI_Line10);
NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
SPI1_Init();
SPI_Cmd(SPI2, DISABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
SPI_Cmd(SPI2, ENABLE);
串口中断:
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
找到问题了,在初始化的时候将中断线由NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn;改为NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;,但是在后面的中断服务函数那边没有改,导致了程序进入中断但是没有处理函数,从而挂在了startup里面的324行。谢谢各位。
37
160
160
2014-9-7
18 小时
 楼主| 发表于 2015-11-5 10:09:36 | 显示全部楼层
37
160
160
2014-9-7
18 小时
 楼主| 发表于 2015-11-5 10:11:57 | 显示全部楼层
void sys_timeouts_init(void)
#if IP_REASSEMBLY
  sys_timeout(IP_TMR_INTERVAL, ip_reass_timer, NULL);
#endif /* IP_REASSEMBLY */
#if LWIP_ARP
  sys_timeout(ARP_TMR_INTERVAL, arp_timer, NULL);
#endif /* LWIP_ARP */
#if LWIP_DHCP
  sys_timeout(DHCP_COARSE_TIMER_MSECS, dhcp_timer_coarse, NULL);
  sys_timeout(DHCP_FINE_TIMER_MSECS, dhcp_timer_fine, NULL);
#endif /* LWIP_DHCP */
#if LWIP_AUTOIP
  sys_timeout(AUTOIP_TMR_INTERVAL, autoip_timer, NULL);
#endif /* LWIP_AUTOIP */
#if LWIP_IGMP
  sys_timeout(IGMP_TMR_INTERVAL, igmp_timer, NULL);
#endif /* LWIP_IGMP */
#if LWIP_DNS
  sys_timeout(DNS_TMR_INTERVAL, dns_timer, NULL);
#endif /* LWIP_DNS */
#if NO_SYS
  /* Initialise timestamp for sys_check_timeouts */
  timeouts_last_time = sys_now();
#endif
是在这个函数里面跑挂的。
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2015-11-5 10:13:54 | 显示全部楼层
这个问题你只能自己硬件仿真检查了,看看具体是在哪个函数里面死掉的
开往春天的手扶拖拉机
1043
3752
3752
2011-5-23
2018 小时
发表于 2015-11-5 10:20:10 | 显示全部楼层
看IPSR就知道哪个ISR末实现
37
160
160
2014-9-7
18 小时
 楼主| 发表于 2015-11-5 10:26:43 | 显示全部楼层
回复【3楼】zuozhongkai:
netif_set_default(struct netif *netif)
  if (netif == NULL) {
    /* remove default route */
    snmp_delete_iprteidx_tree(1, netif);
  } else {
    /* install default route */
    snmp_insert_iprteidx_tree(1, netif);
  netif_default = netif;
  LWIP_DEBUGF(NETIF_DEBUG, ("netif: setting default interface %c%c\n",
           netif ? netif->name[0]: '\'', netif ? netif->name[1]: '\''));
在这个函数里面挂掉呢?
37
160
160
2014-9-7
18 小时
 楼主| 发表于 2015-11-5 10:31:04 | 显示全部楼层
回复【4楼】aozima:
netif_set_default  查出来 是在这个函数里面挂的,是啥问题?
GMT+8, 2026-11-4 03:45
